AC-130 Replacement Contemplated
Old February 7th 04, 01:43 AM
sid
Default AC-130 Replacement Contemplated
After having been excoriated for saying that civil designs such as
those envisioned for the MC2A and ACS have no business over the
battlefield, this article gives me a bit of gratification:
USAF Plans Serious Look At Replacing Special Ops Aircraft
By Marc Selinger
February 6, 2004
The U.S. Air Force plans to start taking a serious look at potential
replacements for several C-130 variants used by its special operations
forces, a service representative said Feb. 5.
Maj. Gen. John Dorris said the Bush Administration's fiscal 2005
budget request, submitted to Congress Feb. 2, contains "seed money" to
develop concepts for an "MX" aircraft, which would replace the
MC-130E/H airdrop/transport aircraft, and an "AX" which would replace
the AC-130 gunship. The analysis could take about two years.
With surface-to-air threats becoming increasingly sophisticated, the
Air Force Special Operations Command (AFSOC) believes it will need to
begin fielding the new aircraft in about 2015 as a replacement for its
aging Lockheed Martin C-130 variants, Dorris said. He spoke to
reporters after speaking at a special operations conference sponsored
by the National Defense Industrial Association (NDIA).
"After 2015, the ability of the C-130 as it's currently configured,
even with enhancements, is not going to be able to go into a lot of
the airspace that it needs to go into," he said.
The MX is envisioned as a long-range aircraft that is "able to do the
mission in one period of darkness," Dorris said. The latest thinking
for the AX is that it would be a "mothership that sends out sensors."
The sensors would then report back to the mothership, which would send
out "lethal and/or non-lethal projectiles," possibly small, guided
missiles.
A new aerial refueling capability will also be needed by AFSOC but
probably later than 2015, Dorris said.
To address AFSOC's tanker shortfall in the interim, about 27 MC-130H
Combat Talon IIs are being modified to be capable of refueling. That
work will be completed by about 2007. AFSOC's MC-130E Combat Talon Is
already can perform the tanker mission.
Old February 7th 04, 04:15 AM
Kevin Brooks
"sid" wrote in message
m...
There is quite a gulf between the kind of "battlefield" (or more
specifically "battle environment") that the special operations aircraft have
to operate in and that which the E-10 will be expected to survive. So I am
not really sure what your point here is...?
Brooks
By Marc Selinger
February 6, 2004
snip
Old February 7th 04, 04:23 AM
Les Matheson
Even though they say the C-130 isn't going to be capable, all the plans I've
seen for the AX and MX aircraft are based on a four engine turboprop design
that sure looks like a C-130J.
Les
F-4C(WW),D,E,G(WW)/AC-130A/MC-130E EWO (ret)
Old February 7th 04, 06:04 AM
Ragnar
m...
Yes! Finally, the AC-5 will get its day!
Old February 7th 04, 06:45 AM
Thomas Schoene
plans I've seen for the AX and MX aircraft are based on a four engine
turboprop design that sure looks like a C-130J.
Boeing has mentioned a tilt-wing design they call the Advanced Theater
Transport (aka Super Frog) that sure sounds like it fits the MX mission
description. Doesn't look all that much like a C-130J.
http://www.boeing.com/phantom/att.html
I wasn't able to find anything on Lockheed's ideas (MX is a hard term to
search on, even with modifiers)
Tom Schoene Replace "invalid" with "net" to e-mail
"If brave men and women never died, there would be nothing
special about bravery." -- Andy Rooney (attributed)
Old February 7th 04, 03:58 PM
Bill McClain
Hmm...no vert stab and rudder. Maybe the Navy will want some to
replace the C-2 Greyhound? If the wingspan isn't too great, they
might be able to put this on an aircraft carrier's deck elevator if
they have to strike it below; I think that was one of the issues with
using a C-130 for COD.
Old February 7th 04, 06:38 PM
John
is it just me, or does the ATT bear a strong resemblance to the
German Me 323 Gigant ?
Old February 7th 04, 07:05 PM
Andreas Parsch
Well ... it's just you ;-). Other than both being large transport aircraft,
I fail to see any commonality.
But it's possible that other individuals on r.a.m. will come forward and
explain that _every_ modern airlifter owes _a lot_ to German wartime
designs ;-)!
SCNR
Andreas
Old February 7th 04, 07:16 PM
Zamboni
"John" wrote in message
mission
The Gigant also came in a gunship configuration, so that would cover the AX
mission as well.
Old February 7th 04, 08:01 PM
John
designs ;-)!
SCNR
Andreas
I was referring to the sketches at the bottom on the Boeing webpage.
the multiwheel layout, the blunt bulbous shape .
FWIW: I spent many hours inside several variants of trash haulers
so I find them to be a fine aircraft, enough so, that I have
left
lot of them in mid-flight.. Airborne ;-) Herc's are
beautiful !
Magneto/comm interference on TKM MX-R Narco 120 replacement Eugene Wendland Home Built 5 January 13th 04 02:17 PM
Canada to order replacement for the Sea King Ed Majden Military Aviation 3 December 18th 03 07:02 PM
Replacement for C130? John Penta Military Aviation 24 September 29th 03 07:11 PM
Narco MK 16 replacement SoulReaver714 Aviation Marketplace 1 September 23rd 03 04:38 PM
Hellfire Replacement Eric Moore Military Aviation 6 July 2nd 03 02:22 AM
