OLC Scoring for 2011
Old October 21st 10, 03:52 PM posted to rec.aviation.soaring
Peter Scholz[_2_]
Default OLC Scoring for 2011
Am 21.10.2010 16:38, Cliff Hilty wrote:
I am really have trouble figuring out how the OLC is scoring the FAI
triangle points. Look at USA Ken Sorenson's flight on Tuesday out of
houston and tell me what you think? He did not get any points for the
triangle, yet I could have easily plotted close to the entire flight (if
not indeed the entire flight) as a FAI triangle? Yet my flight last
Saturday was scored with much higher FAI points with much less (if any at
all) triangle flight trace.
CH Bewildered in Phoenix
Quite simple: Ken's triangle wasn't closed. The start point is about 3
miles east to the landing point.
Peter Scholz
ASW24 JE
Old October 21st 10, 07:25 PM posted to rec.aviation.soaring
Ramy
On Oct 21, 7:52*am, Peter Scholz
Am 21.10.2010 16:38, Cliff Hilty wrote: I am really have trouble figuring out how the OLC is scoring the FAI
Peter Scholz
ASW24 JE
This brings up a good point. Previously for OLC classic points you did
not need to close your triangle. Now if you want to maximize your
points, you will need to close your triangle, which means always fly
back to your release point (within 1km lateral and vertical if I
recall correct).
This will complicate things since this may not always be possible or
desired especially if you take a long high tow.
Ramy
Old October 21st 10, 11:13 PM posted to rec.aviation.soaring
Peter Scholz[_2_]
Am 21.10.2010 20:25, Ramy wrote:
On Oct 21, 7:52 am, Peter
Peter Scholz
ASW24 JE
recall correct).
Ramy
Well, you still get the old "OLC Classic" points, even better, because
leg 5 and 6 are counted with factor 1. But you'll get the FAI triangle
bonus only if you close the triangle. --
Peter Scholz
ASW24 JE
  #24
Old October 21st 10, 11:34 PM posted to rec.aviation.soaring
Tony[_5_]
seems like with any competition its important to know the rules before
you go fly. at least if you want to be competitive.
OLC 2011 dhaluza Soaring 12 October 22nd 10 12:02 AM
OLC Scoring for 2011 Mike the Strike Soaring 9 October 17th 10 03:41 AM
2011 US Sports Nationals Tim[_2_] Soaring 4 September 15th 10 08:13 PM
2011 15M Nationals Andy[_10_] Soaring 10 August 19th 10 05:23 PM
2011 USA 18M Nationals 5 ugly Soaring 3 August 18th 10 04:52 AM
