Engine rebuild costs
Old November 8th 10, 06:36 PM posted to rec.aviation.soaring
Darryl Ramm
Default Engine rebuild costs
On Nov 8, 9:29*am, Craig wrote:
On Nov 8, 6:04*am, JJ Sinclair wrote:
... but does
ANYONE any longer answer a question rather than giving a reference?
Someone give the guy a figure please! *even if its a long shot rough
In the recent ASH-26 engine recall, it cost about $2800.00 to remove,
crate, ship, disassemble engine, replace crank, re-assemble, re-crate,
ship, install and test run the engine.
JJ
What were the reasons for the ASH-26 engine recall?
Thanks,
Craig
First - The reason for a recall of some of the AE50R engines was a
faulty dowel pin weld and is well documented on Schelicher's web site.
Anybody interested can read the service bulletin there.
The $2,800 cost that JJ mentioned is likely to give a serious
underestimate of costs of a significant service/rebuild on an AR50R
engine as used in the ASH-26E and I don't think is that relevant to
the question that was asked.
That $2,800 cost quoted was for work several owners (including me) had
done at the same time (and I'm not even going to bother going to check
what my actual cost was). That cost covered the removal of an engine,
removal of accessories from the core, constructing a custom crate,
airfreight shipping from the West Coast of the USA to Austro Engines
in Austria, return airfreight shipping, reassembling the engine core
and accessories, test running the complete engine in a test stand,
reinstalling the engine in the glider, etc.
Several owners in the Western USA banded together to do this and get
it to happen as quickly as possible working though Williams Soaring
who have a lot of expertise on the ASH-26E. Eastern Sailplane did
something similar for affected owners in the eastern part of the USA.
Overall I felt we got great support from Williams Soaring, Eastern
Sailplane and Schleicher.
The cost quoted did not include the replacement parts, engine core
teardown and reassembly or test running at Austro Engines (the engine
manufacturer). So it really gives little relevant information about
the cost of a serious engine rebuild/replacement.
Since I know which glider JJ is referring to the price mentioned was
for a glider no longer in warranty from Schleicher - those owners
(including me) picked up the periperal costs I mentioned above but
Austro still paid for the engine parts and core engine work. For
gliders in warranty Schleicher covered more or all of the costs.
Again I see these as largely irrelevant costs that don't really
answerer the original question, except if anything I'd point out with
a realtively maintenance heavy (compared to a conventional glider)
motorglider you really want a community of other users either locally
or online, to share experiences with, access to knowledgeable service
facilities and vendors (glider and engine) who are responsive, still
in business and likely to remain in business. I've participated in
both the ASH-26E and DG-80x/Solo users groups and both are invaluable
sources of information.
Costs of an AE50R major rebuild/replacement will vary widely depending
on what damage and exactly how much of the accessories and ancillary
systems need to be replaced in any rebuild. I would guess a
replacement engine is somewhere around $20k - but will vary widely
depending on exactly what needs to be replaced. But I am just
guessing. And I think there are probably more interesting questions
about buying/owning a motorglider (unless you are buying a motorglider
and know/really suspect the engine is dead - in which case go work up
a real quote with a service center).
I recommend reading the self launch glider guide Eric put together and
mentioned in this threat and finding owners of motorgliders similar to
the types you are interested in and going spending time talking to
them about the benefits/disadvantages of owning a motorglider and the
peculiarities of their particular type. I've noticed so many
misconceptions and misunderstandings about motorgliders that nothing
beats finding a friendly owner who is willing to spend a few hours
talking with you.
Darryl
Old November 9th 10, 04:41 AM posted to rec.aviation.soaring
Frank Whiteley
... but does
JJ
Thanks,
Craig
crank?
Old November 9th 10, 05:23 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
JJ
Thanks,
Craig
crank?
Yes, the rotor turns around the crankshaft, driving it with gear teeth.
The crankshaft delivers the power to the belt that drives the propeller.
Here's a good description of the Wankel:
http://en.wikipedia.org/wiki/Wankel_engine
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl
- "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz
Old November 9th 10, 05:30 AM posted to rec.aviation.soaring
Darryl Ramm
JJ
Thanks,
Craig
crank?
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarmhttp://tinyurl.com/yb3xywl
Oh the drive shaft. I thought he was talking about JJ. :-)
[Crank shaft | drive shaft | eccentric shaft] are perfectly
interchangeable names.
Darryl
Old November 9th 10, 01:26 PM posted to rec.aviation.soaring
Dave Nadler
On Nov 5, 2:51*pm, Z1 wrote:
Does anyone have an idea of costs on a engine reuild / new engine for:
*DG800/Ventus vs ASH26E
Ignore these guys !
The real answer is:
"If you have to ask..."
Contact me for info about a motorglider
with less likelihood of needing engine rebuild ;-)
Best Regards, Dave "YO electric"
PS: Latest Antares 20E owner in USA just put his
glider away for the winter. He received the glider
in June 2009, and has already flown it 475 hours
(including winning a couple days at the Sports Nats).
Only required maintenance ?
Pause, Ready, drum-roll...
Add air to the tires.
Old November 9th 10, 02:17 PM posted to rec.aviation.soaring
Andy[_10_]
Ignore these guys !
The real answer is:
It runs on air pressure? ;-)
9B
Old November 9th 10, 02:47 PM posted to rec.aviation.soaring
Dave Nadler
Ignore these guys !
The real answer is:
It runs on air pressure? *;-)
9B
Plugging it in at night is "fueling", not "maintenance"...
Old November 9th 10, 03:20 PM posted to rec.aviation.soaring
Andy[_10_]
Ignore these guys !
The real answer is:
9B
I know - I saw the big gasoline-powered generator sitting next to the
glider on the ramp.
Old November 9th 10, 04:30 PM posted to rec.aviation.soaring
Darryl Ramm
Ignore these guys !
The real answer is:
And what does a full set of new batteries cost?
Cruise range?
Price new?
If I see somebody with his head inside his electric glider saying
something about "bad cells", rebalancing blah blah blah what does that
mean?
All motorgliders have operational issues/limitations and all involve
more maintenance than conventional gliders and I hope all purchasers
go into this with their eyes open.
Now don't get me wrong, I am happy to spend weeks test flying an
Antares and provide feedback - I won't even charge for my time.
Darryl
Lycoming Engine Rebuild Seminar N523RV Home Built 0 August 18th 05 06:37 PM
Engine ( A-65) Propstrike and rebuild on cheap??? [email protected] Home Built 14 August 15th 05 02:59 PM
Help! rebuild or replace Stamo engine In Falke? Ian Walton Soaring 2 September 5th 04 07:02 AM
O-320 Engine Costs - 172 Jerry Napoliano Owning 6 June 24th 04 04:03 AM
Engine Replacement Labor costs.... [email protected] Owning 10 November 20th 03 12:14 PM
