#21
On Nov 15, 7:29*pm, sisu1a wrote:
One obvious master of the master class has not yet been mentioned: *the Frigate Bird. They not only out-soar all other forms of soaring birds, but steal their food from them as well! (hence the name, also called Man o' War birds). Well, another obvious bird not mentioned is the Albatross, which has the highest aspect of all birds (higher aspect then Frigatebirds, which hold the title for the lowest span loading, no doubt contributing to their ninja-like agility...). Sorry Frigates, but the Alby is the true unequivocal champion of *soaring, although in spirit of the OP's question, the Frigatebird may out perform it in a thermal ... Albatross circumnavigate the globe though, no doubt expertly working thermals the rare occasions they're available, but mostly use orthographic and different of modes of dynamic soaring (as do Frigatebirds) for their constant open water X/C trips, living life 'on the wing' stopping only to raise chicks from time to time. Frigatebirds are indeed amazing, and are definitely beautiful birds to share the air with as well as to watch from the ground. So far I have only soared with Frigatebirds, (Hawaii), but very much look forward to the day I share the air with an Alby... (not the bronze statue, although that'd be swell too ![]() They're both Peligoonformes though ![]() -Paul I've not seen too many frigate birds or albatrosses in Arizona. Maybe they are ill equipped to survive on a diet of lizards and pack rats! Mike |
sisu1a wrote:
Well, another obvious bird not mentioned is the Albatross, which has The original question was about birds to be useful markers for soaring. I'm not sure I would want to try and follow an albatross and cross the oceans with dynamic soaring a few feet above the water... |
On 15 Lis, 12:59, Scott Alexander
wrote: I thought it would be interesting to ask you good people if anyone has any knowledge on these issues. *Does anyone know which broad winged birds have better or worse centering techniques that you can use to your advantage? In Poland Hawks are very good thermal indicators and they're quite common. Most of the time I find better lift when I move closer to them. From what I've heard Eagles are even better but they're very rare here and I haven't had a pleasure of meeting one. I would avoid White Storks, especially on weak days - they're great soarers but they're low wing loading let's them use thermals that would just reduce glider's descent rate a bit. -- Wiktor |
#24
A few years ago I was sharing a thermal with three storks at 1800 m
and it seemed that one of them was very young and had not mastered its thermaling technique quite yet. It would make sudden corrections and flap a few times while the other two calmly circled and waited for it to catch up. When they got together they took off in tight formation. I was headed in about the same direction so I was able to watch them for several miles and I was amazed by their glide speed which appeared to be close to 80 km/h. Truly incredible birds.. I donīt know if they soar for fun but it looked like they were having a great time. Regards, Juan Carlos |
#25
On Tue, 16 Nov 2010 03:26:01 -0800, Wiktor Moskwa wrote:
I would avoid White Storks, especially on weak days - they're great soarers but they're low wing loading let's them use thermals that would just reduce glider's descent rate a bit. According to Henk Tennekes ("The simple science of flight") a bird can't make a living unless its min.sink speed is 1 m/s or less. I'd think that land birds are unlikely to be much better than that sinply because the amount of wing they'd need would make life awkward in trees, etc. Our gliders can certainly outperform some soaring birds. Some years ago on an almost flat calm evening I was sitting in a very weak thermal, flying an SZD 51-1 Junior slowly in fairly wide circles and climbing at half a knot or less, but hey, it was a nice evening and the drift wasn't taking me anywhere, so I was just enjoying my last flight of the day. After a while I was joined by a pair of black-backed gulls. They flew several turns without gaining on me and then left, coming back 5 minutes later and somewhat lower. This time they flew one turn and exited, not to be seen again. I could almost hear one of them saying as they flew off "See, I told you that thermal was too weak last time". -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
#26
On Nov 16, 4:03*am, JC wrote:
A few years ago I was sharing a thermal with three storks at 1800 m and it seemed that one of them was very young and had not mastered its thermaling technique quite yet. It would make sudden corrections and flap a few times while the other two calmly circled and waited for it to catch up. When they got together they took off in tight formation. I was headed in about the same direction so I was able to watch them for several miles and I was amazed by their glide speed which appeared to be close to 80 km/h. Truly incredible birds.. I donīt know if they soar for fun but it looked like they were having a great time. Regards, Juan Carlos a few years ago I shared a thermal with a whole flock of Geese. They were in a typical V formation then they hit the thermal, turned into the wind and just hung there, they did break formation a little. I circled around them as we all climbed together. It appeared they just sort of took a rest break in the air, hovering in one spot. After a while they turned back North and re-formed the V formation but seveal hundred feet higher. It was really cool to watch. Dan WO |
#27
I hear Gill Spreakley is pretty good!
#28
on my last flight in the Cherokee there were a bunch of seagulls
flying around. they thermal but they suck at it. the were never in the core and are a pain to gaggle with as they are just a huge blob of birds. I was at some times surrounded above and below and on all sides by hundreds of birds. one thing they are good at is getting out of the way |
#29
On Nov 17, 6:39*pm, Tony wrote:
on my last flight in the Cherokee there were a bunch of seagulls flying around. *they thermal but they suck at it. *the were never in the core and are a pain to gaggle with as they are just a huge blob of birds. *I was at some times surrounded above and below and on all sides by hundreds of birds. *one thing they are good at is getting out of the way When you see thermaling pelican, you can start very slow preparation for take-off ![]() Valid at Australia http://picasaweb.google.com/diana2.s...07300185961682 Greetings, Hana |
#30
Birds I have thermalled with -
Cape Griffon (White Backed Vultures) thermal very well, but you have to be careful there is a "vulture restaurant" near the Drakensberg Club outside Underberg. (Natal Province - South Africa) So sometimes you join them in a thermal, only to discover they have sought out the descending air so they can get on the ground for grub. They are gregarious and join the gliders quite happily. Occasionally you get one clown who thermals the wrong way and causes chaos. Bearded vulture - this is a huge bird, which I have only had the priviledge of flying with once as they don't like gliders and get aggressive - Based on a sample of one Two up in a K13, and trying to stay up in the only thermal in the sky trickling off a stony conical hill. Desperately clinging to about .5kt we got thrashed in the Grob 103 Twin Astir - The Cape Griffon with us were also left in his dust. One assumes that the massive wings help. I was interested to see the camber on the wings changing as the bird optimised the smallest variations in lift. They eat the marrow in bones, so meal times consist of descend to a carcass, lift off with a heavy ungainly load and climb high - then drop the bone onto rocks to break it - descend to eat - fly back to carcase. Repeat. Clearly those that can thermal well get to eat best. Tawny Eagle on the Platberg ridge also out climbed me - this time in a K13 - maybe it is the way I fly. We met doing the 180 turn at the end of one beat. The Eagle turned well inside us and was clearly able to stay in a very tight , very strong core of lift rising up from a gulley. Gymnogene - flew a couple of turns with me in a Bergfalke II-55. It was late afternoon, and I think the motivation was curiosity on the way to it's roost for the night. I got carefully inspected and then left - at about the same height. Sample of one does not say much, but despite the wing aspect ration he was not climbing well. Also - This is the only solo bird I have had join me in a thermal and turn opposite. Yellow Billed thermal very well. They have often helped me over the Vredefort dome - generally marking good lift.Problem is they are so agile they can use lift which even the Cirrus can't turn in... European swifts are often to be seen right in the core of strong thermals at high altitude. The seem to be able to combine hawking insects and thermalling with relatively little flapping in between the aerial gymnastics. They really get into the core of the thermal. Never flown with them but the Bateleur Eagles seem to thermal very well too. On 2010/11/15 1:59 PM, Scott Alexander wrote: So in a recent conversation with a greatly experienced soaring pilot, I was told that Buzzard's have terrible thermaling skills. I tend to agree with this as it sure seems Buzzards don't get into the core and stay there. The lesson learned was don't let Turkey Buzzard show you where the core is, just let them lead you to the thermal. I thought it would be interesting to ask you good people if anyone has any knowledge on these issues. Does anyone know which broad winged birds have better or worse centering techniques that you can use to your advantage? SA -- Bruce Greeff T59D #1771 & Std Cirrus #57 |
Got Big Thermals? | Bob D | Soaring | 14 | July 29th 09 02:34 AM |
Deadly Thermals!!!! | JGalban | Piloting | 6 | September 15th 07 03:30 AM |
Using thermals to climb? | Kees Mies | Piloting | 41 | April 27th 04 02:29 PM |
perfect thermals | Mike Stramba | Soaring | 0 | October 7th 03 07:09 AM |
