Ethanol fuel and deteriorating composite fuel tanks
Old November 18th 10, 01:48 AM posted to rec.aviation.soaring
Mark
Default Ethanol fuel and deteriorating composite fuel tanks
If you have a composite fuel tank and the fuel available in your area
has ethanol in it then you should google something like the
following...
ethanol fiberglass fuel tanks
There you will find out that the ethanol content appears to be a
significant player in relatively rapid deterioration of the resin and
therefore early failure of the fuel tank
Looks like the boaters have been seriously affected by the E10
situation and if your motorized sailplane also has a composite tank it
may be at risk of early failure.
AVGAS probably doesn't have Ethanol added so if you have a composite
fuel tank, it may be very wise to only use AVGAS even if autogas w/ 2
cycle mix is allowed.
Old November 18th 10, 05:36 AM posted to rec.aviation.soaring
following...
We stopped runing mogas in our STC'ed pawnees when CA Dumped MTBE and
went to 10% ethanol a few years back, Concern was more on the other
elements of the fuel system, I think the early Pawnee fuselage tank is
polyester.
aerodyne
Old November 18th 10, 05:42 AM posted to rec.aviation.soaring
Darryl Ramm
following...
went to 10% ethanol a few years back, *Concern was more on the other
polyester.
aerodyne
I think you want to be concerned with Polyester resin based tanks.
Not a drop of mogas is ever going in my ASH-26E, for possible tank
problems with Ethanol and other reasons including engine cooling.
Darryl
Old November 18th 10, 03:23 PM posted to rec.aviation.soaring
following...
polyester.
aerodyne
Darryl
Polyester resin based composites have been used for underground mogas
storage tanks (gas stations) for decades. Polyester and vinylester
are very chemical resistant.
aerodyne
Old November 18th 10, 03:29 PM posted to rec.aviation.soaring
Darryl Ramm
following...
polyester.
aerodyne
Darryl
storage tanks (gas stations) for decades. *Polyester and vinylester
aerodyne
Polyester based fiberglass tanks are exactly amongst those causing
concern with alcohol based fuels. You run it in your motorglider, I
won't in mine.
http://lmgtfy.com/?q=alcohol+fibergl...tank+polyester
Darryl
Old November 18th 10, 06:10 PM posted to rec.aviation.soaring
Mark Jardini
aren't most of last decade birds built with epoxy resin?
Old November 18th 10, 06:20 PM posted to rec.aviation.soaring
Darryl Ramm
Yes, but what the glider is made of does not dictate what the fuel
tanks is made of. And a fuel tank might well have a special fuel-proof
lining even if the tank is made of other resin. Check with the
manufacturer, and check if they believe the aircraft should use
alcohol blend fuels. And many motorgliders also have aux fuel stored
in the wings - in flexible bags not hard tanks.
Darryl
Old November 18th 10, 06:36 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
aerodyne
won't in mine.
Darryl
How about epoxy resin? I think that's what is used in my ASH 26 E fuel
tank. Not that I have any intention using something other than 100LL.
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl
- "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz
Old November 18th 10, 10:47 PM posted to rec.aviation.soaring
Gary Evans[_2_]
aerodyne
won't in mine.
Darryl
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarmhttp://tinyurl.com/yb3xywl
- "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz- Hide quoted text -
- Show quoted text -
Epoxy has a good resistance to alcohol but I agree on the choice of
100LL for other good reasons.
Old November 19th 10, 06:22 AM posted to rec.aviation.soaring
Jim[_18_]
You spend enough to buy a house on your motorglider and are trying to
save a few bucks on fuel?
It's time to mount the fuel tanks Lou Home Built 1 March 31st 07 07:07 PM
Leaking Fiberglass Fuel Tanks [email protected] Home Built 0 January 2nd 07 01:10 AM
Ethanol & capacitance fuel-level sensors Adam Aulick Home Built 4 May 20th 06 03:28 PM
Fuel Tanks C172 [email protected] Owning 1 May 2nd 06 05:45 AM
Epoxy for Fuel Tanks Doug Palmer Home Built 1 April 12th 06 02:53 AM
