#21
Getting a Badge Candidate set up with barograph is a task no one seems
eager to undertake. *Then there are the periodic calibrations required and the interpretation of the trace. *The width of the line seems important some times. *Does anyone know if the LXNAV Nano will require periodic calibrations for badge use? Carl yes all flight recorders require calibration. Barographs must be calibrated within the preceding year, Electronic Flight Recorders must be calibrated within the preceding 2 years. If a badge leg is claimed with either type of recorder out of calibration you have one month to get it calibrated and submit the data. there is still setup required for the flight recorder. for the barograph the OO has to fix the paper to the drum, mark the paper, put the drum in the barograph and probably scribe a baseline and maybe make a timing mark. then of course wind the barograph and turn it on. for the flight recorder they'll have to connect it to their computer, make sure the pilots name, glider, glider N number and whatever else is required for the electronic declaration. Since you'll be using this for renters this will have to be done basically before each flight. One benefit us private owners have is we can usually set up the device when we get it and if we always fly the same glider never worry about it. Having the wrong info in the electronic declaration risks invalidating the flight, unless a paper declaration is made after the electronic one. I am paranoid enough about the electronic flight recorder that I always make a paper declaration just to be safe. |
On Nov 18, 12:13*pm, Gregg Leslie wrote:
As far as reading a flight. Open Seeyou and open the Nano flight file, and your flight loads. Please tell me that SeeYou is not required to extract an IGC file from this recorder. Andy |
On Nov 19, 6:55*am, Andy wrote:
On Nov 18, 12:13*pm, Gregg Leslie wrote: As far as reading a flight. Open Seeyou and open the Nano flight file, and your flight loads. Please tell me that SeeYou is not required to extract an IGC file from this recorder. Andy Andy, Plug the NANO into a USB port on your computer it is identified as a drive and copy and paste the file. Richard www.craggyaero.com |
#24
On Nov 19, 8:55*am, Andy wrote:
On Nov 18, 12:13*pm, Gregg Leslie wrote: As far as reading a flight. Open Seeyou and open the Nano flight file, and your flight loads. Please tell me that SeeYou is not required to extract an IGC file from this recorder. Andy no, the Nano connects to your computer just like a USB drive. you open up the folder and drag/drop the igc file to wherever you want to save it. Manual is he http://www.lxnav.com/downloads/manua...ishver0100.pdf |
#25
On Nov 18, 9:37*pm, Tony wrote:
it was only complicated because you wanted to fly a closed course ![]() You are right, I did want to do a closed course. I had enough "head downwind and land somewhere" in my hang glider days. 50km is an easy drive, but Diamond distance is a long time to wait for the retrieve crew. Todd |
#26
![]() The LX specs for talking to an LX device such as Colibri, LX20 and probably the Nano (which I don't have, anyway), are not public. I'll try and ask LX if they can make them public. Winpilot and SeeYou can talk to LX, because they are or were all part of the same company, I was told. paolo "mike" ha scritto nel messaggio ... On Nov 18, 10:01 am, Carl6703 wrote: I would like to retire our old Barographs and replace them with a portable Flight Recorder that could be rented to candidates for SSA badges. Does anyone have any suggestions for a portable flight recorder which would meet the badge requirements? Thanks. Carl Baxter Turf Soaring I have a Nano and it is very easy to use and works well. Blue Tooth with the Nano works, as does using the serial port with my HX4700. There is one small hiccup if you are using XCSoar or LK8000. So far declaring a task using LK8000 or XCSoar has not been possible. The easy work around is using Navetir ConnectMe, which is a free program, to declare tasks via your IPAQ just prior to take off. Of course task inputs using a home or laptop computer are easy as well. Mike "0" |
#27
On Nov 19, 11:38*am, "PCool" wrote:
The LX specs for talking to an LX device such as Colibri, LX20 and probably the Nano (which I don't have, anyway), are not public. I'll try and ask LX if they can make them public. Winpilot and SeeYou can talk to LX, because they are or were all part of the same company, I was told. paolo "mike" ha scritto nel ... On Nov 18, 10:01 am, Carl6703 wrote: I would like to retire our old Barographs and replace them with a portable Flight Recorder that could be rented to candidates for SSA badges. Does anyone have any suggestions for a portable flight recorder which would meet the badge requirements? Thanks. Carl Baxter Turf Soaring I have a Nano and it is very easy to use and works well. Blue Tooth with the Nano works, as does using the serial port with my HX4700. There is one small hiccup if you are using XCSoar or LK8000. So far declaring a task using LK8000 or XCSoar has not been possible. The easy work around is using Navetir ConnectMe, which is a free program, *to declare tasks via your IPAQ just prior to take off. Of course task inputs using a home or laptop computer are easy as well. Mike "0" That would be nice, I'm not sure why LX (or the various companies spun off now) do not publicity document their protocols/NMEA extensions etc. Failing that a terminal emulator capturing the serial port stream should also tell you what you need to know. Naviter has a close relationship to the LX companies but AFAIK Winpilot does not and never had. Darryl |
#28
On Nov 19, 3:24*pm, Darryl Ramm wrote:
On Nov 19, 11:38*am, "PCool" wrote: The LX specs for talking to an LX device such as Colibri, LX20 and probably the Nano (which I don't have, anyway), are not public. I'll try and ask LX if they can make them public. Winpilot and SeeYou can talk to LX, because they are or were all part of the same company, I was told. paolo "mike" ha scritto nel ... On Nov 18, 10:01 am, Carl6703 wrote: I would like to retire our old Barographs and replace them with a portable Flight Recorder that could be rented to candidates for SSA badges. Does anyone have any suggestions for a portable flight recorder which would meet the badge requirements? Thanks. Carl Baxter Turf Soaring I have a Nano and it is very easy to use and works well. Blue Tooth with the Nano works, as does using the serial port with my HX4700. There is one small hiccup if you are using XCSoar or LK8000. So far declaring a task using LK8000 or XCSoar has not been possible. The easy work around is using Navetir ConnectMe, which is a free program, *to declare tasks via your IPAQ just prior to take off. Of course task inputs using a home or laptop computer are easy as well. Mike "0" That would be nice, I'm not sure why LX (or the various companies spun off now) do not publicity document their protocols/NMEA extensions etc. Failing that a terminal emulator capturing the serial port stream should also tell you what you need to know. Naviter has a close relationship to the LX companies but AFAIK Winpilot does not and never had. Darryl Try http://lxnavigation.de/avionics/manuals_de.php I was able to download a manual containing the definitions of the LXWPx sentences. The details of the upload and download protocols aren't available that I know of, however. -- Matt |
#29
On Nov 19, 5:38*am, Tony wrote:
Getting a Badge Candidate set up with barograph is a task no one seems eager to undertake. *Then there are the periodic calibrations required and the interpretation of the trace. *The width of the line seems important some times. *Does anyone know if the LXNAV Nano will require periodic calibrations for badge use? Carl yes all flight recorders require calibration. *Barographs must be calibrated within the preceding year, Electronic Flight Recorders must be calibrated within the preceding 2 years. *If a badge leg is claimed with either type of recorder out of calibration you have one month to get it calibrated and submit the data. there is still setup required for the flight recorder. for the barograph the OO has to fix the paper to the drum, mark the paper, put the drum in the barograph and probably scribe a baseline and maybe make a timing mark. *then of course wind the barograph and turn it on. for the flight recorder they'll have to connect it to their computer, make sure the pilots name, glider, glider N number and whatever else is required for the electronic declaration. *Since you'll be using this for renters this will have to be done basically before each flight. One benefit us private owners have is we can usually set up the device when we get it and if we always fly the same glider never worry about it. *Having the wrong info in the electronic declaration risks invalidating the flight, unless a paper declaration is made after the electronic one. *I am paranoid enough about the electronic flight recorder that I always make a paper declaration just to be safe. Tony, Who provides calibration service for the Nano? Does it take so much time that I might need 2 Nanos to cover when one is out for calibration? My feeling is that I can get OO's to do the electronic setup easier than I can get them to do the barograph drill. Carl |
#30
On Nov 19, 2:49*pm, Carl6703 wrote:
On Nov 19, 5:38*am, Tony wrote: Getting a Badge Candidate set up with barograph is a task no one seems eager to undertake. *Then there are the periodic calibrations required and the interpretation of the trace. *The width of the line seems important some times. *Does anyone know if the LXNAV Nano will require periodic calibrations for badge use? Carl yes all flight recorders require calibration. *Barographs must be calibrated within the preceding year, Electronic Flight Recorders must be calibrated within the preceding 2 years. *If a badge leg is claimed with either type of recorder out of calibration you have one month to get it calibrated and submit the data. there is still setup required for the flight recorder. for the barograph the OO has to fix the paper to the drum, mark the paper, put the drum in the barograph and probably scribe a baseline and maybe make a timing mark. *then of course wind the barograph and turn it on.. for the flight recorder they'll have to connect it to their computer, make sure the pilots name, glider, glider N number and whatever else is required for the electronic declaration. *Since you'll be using this for renters this will have to be done basically before each flight. One benefit us private owners have is we can usually set up the device when we get it and if we always fly the same glider never worry about it. *Having the wrong info in the electronic declaration risks invalidating the flight, unless a paper declaration is made after the electronic one. *I am paranoid enough about the electronic flight recorder that I always make a paper declaration just to be safe. Tony, Who provides calibration service for the Nano? *Does it take so much time that I might need 2 Nanos to cover when one is out for calibration? *My feeling is that I can get OO's to do the electronic setup easier than I can get them to do the barograph drill. Carl- Hide quoted text - - Show quoted text - Carl, I can calibrate the NANOs and any other flight recorder. I have be providing 1 Day Turn on Flight Recorder Calibrations since 2004. http://www.craggyaero.com/calibrate.htm Richard www.craggyaero.com |
WinCe Flight Recorder | John Godfrey (QT)[_2_] | Soaring | 0 | November 11th 09 12:18 PM |
New flight recorder - flyWithCE Flight Recorder | uros | Soaring | 12 | May 5th 09 08:31 PM |
In flight recorder | Lou | Piloting | 23 | March 24th 07 12:45 AM |
Badges ? ... We don't need no stinkin' badges | Doug Snyder | Soaring | 36 | September 21st 05 08:26 AM |
US: Flight Recorder Alert | Judy Ruprecht | Soaring | 8 | July 19th 04 09:04 PM |
