#31
On Nov 19, 4:49*pm, Carl6703 wrote:
On Nov 19, 5:38*am, Tony wrote: Getting a Badge Candidate set up with barograph is a task no one seems eager to undertake. *Then there are the periodic calibrations required and the interpretation of the trace. *The width of the line seems important some times. *Does anyone know if the LXNAV Nano will require periodic calibrations for badge use? Carl yes all flight recorders require calibration. *Barographs must be calibrated within the preceding year, Electronic Flight Recorders must be calibrated within the preceding 2 years. *If a badge leg is claimed with either type of recorder out of calibration you have one month to get it calibrated and submit the data. there is still setup required for the flight recorder. for the barograph the OO has to fix the paper to the drum, mark the paper, put the drum in the barograph and probably scribe a baseline and maybe make a timing mark. *then of course wind the barograph and turn it on.. for the flight recorder they'll have to connect it to their computer, make sure the pilots name, glider, glider N number and whatever else is required for the electronic declaration. *Since you'll be using this for renters this will have to be done basically before each flight. One benefit us private owners have is we can usually set up the device when we get it and if we always fly the same glider never worry about it. *Having the wrong info in the electronic declaration risks invalidating the flight, unless a paper declaration is made after the electronic one. *I am paranoid enough about the electronic flight recorder that I always make a paper declaration just to be safe. Tony, Who provides calibration service for the Nano? *Does it take so much time that I might need 2 Nanos to cover when one is out for calibration? *My feeling is that I can get OO's to do the electronic setup easier than I can get them to do the barograph drill. Carl they come calibrated so you'll be good for the first two years and i'm pretty sure anyone listed as doing "flight recorders" can do the calibrations. http://www.ssa.org/files/member/CalibrationLabs.pdf |
#32
On Nov 19, 1:18*pm, mattm wrote:
On Nov 19, 3:24*pm, Darryl Ramm wrote: On Nov 19, 11:38*am, "PCool" wrote: The LX specs for talking to an LX device such as Colibri, LX20 and probably the Nano (which I don't have, anyway), are not public. I'll try and ask LX if they can make them public. Winpilot and SeeYou can talk to LX, because they are or were all part of the same company, I was told. paolo "mike" ha scritto nel ... On Nov 18, 10:01 am, Carl6703 wrote: I would like to retire our old Barographs and replace them with a portable Flight Recorder that could be rented to candidates for SSA badges. Does anyone have any suggestions for a portable flight recorder which would meet the badge requirements? Thanks. Carl Baxter Turf Soaring I have a Nano and it is very easy to use and works well. Blue Tooth with the Nano works, as does using the serial port with my HX4700. There is one small hiccup if you are using XCSoar or LK8000. So far declaring a task using LK8000 or XCSoar has not been possible. The easy work around is using Navetir ConnectMe, which is a free program, *to declare tasks via your IPAQ just prior to take off. Of course task inputs using a home or laptop computer are easy as well. Mike "0" That would be nice, I'm not sure why LX (or the various companies spun off now) do not publicity document their protocols/NMEA extensions etc. Failing that a terminal emulator capturing the serial port stream should also tell you what you need to know. Naviter has a close relationship to the LX companies but AFAIK Winpilot does not and never had. Darryl Tryhttp://lxnavigation.de/avionics/manuals_de.php I was able to download a manual containing the definitions of the LXWPx sentences. *The details of the upload and download protocols aren't available that I know of, however. -- Matt Matt I had missed that, you are right the "LX-NMEA" manual on the page you provided documents the LXWP* NMEA extensions (but not the task declaration stuff). Thanks. Darryl |
#33
On Nov 18, 4:03*pm, "noel.wade" wrote:
Just a quick note: If you wind up not liking the LX NANO (which I haven't had a chance to play with yet), I've been VERY happy with my EW Micro Recorder units over the last 2 years. *They've performed nearly flawlessly at several contests and a big state-records flight this summer. *Super-simple operation, with an SD card slot and a single on/off button. *You can use the SD Card or a USB cable to plug into the unit and change settings or download flight logs. *Runs off of internal batteries or can be powered externally. *Easily removable from a glider, I mount mine with velcro. *Slightly larger than a deck of cards, and lightweight to boot. *Can drive a PDA (GPS NMEA output) and can accept flight declarations from most of the PDA/flight computer programs out there. Good luck! --Noel While I originally liked the concept of the EW and bought one when it came out, I've found mine to be a bit spotty in a couple of areas. One is the task declaration using the SD Card. There's some care needed in making sure that the right sequence is followed at power-up to ensure that the task is loaded from the SD Card (if present). Combine that with the internal battery which seems to kick in even if I have disconnected external power, and i've had a few misses that way. Same thing with shutting the unit off and ensuring I have the log file on the SD Card at the end of the flight. I seem to get it wrong about half the time. I should mention that I leave the unit mounted in the glider and do not use any external device (PDA/Laptop) to connect. It's there purely as a "dumb" backup to my primary logger. I fully admit that I may just be a "better fool" than was envisaged for an otherwise foolproof device. Wondering if others have had similar concerns. Erik Mann P3 |
#34
On Nov 20, 8:06*am, Papa3 wrote:
On Nov 18, 4:03*pm, "noel.wade" wrote: Just a quick note: If you wind up not liking the LX NANO (which I haven't had a chance to play with yet), I've been VERY happy with my EW Micro Recorder units over the last 2 years. *They've performed nearly flawlessly at several contests and a big state-records flight this summer. *Super-simple operation, with an SD card slot and a single on/off button. *You can use the SD Card or a USB cable to plug into the unit and change settings or download flight logs. *Runs off of internal batteries or can be powered externally. *Easily removable from a glider, I mount mine with velcro. *Slightly larger than a deck of cards, and lightweight to boot. *Can drive a PDA (GPS NMEA output) and can accept flight declarations from most of the PDA/flight computer programs out there. Good luck! --Noel While I originally liked the concept of the EW and bought one when it came out, I've found mine to be a bit spotty in a couple of areas. One is the task declaration using the SD Card. * There's some care needed in making sure that the right sequence is followed at power-up to ensure that the task is loaded from the SD Card (if present). Combine that with the internal battery which seems to kick in even if I have disconnected external power, and i've had a few misses that way. *Same thing with shutting the unit off and ensuring I have the log file on the SD Card at the end of the flight. * I seem to get it wrong about half the time. *I should mention that I leave the unit mounted in the glider and do not use any external device (PDA/Laptop) to connect. *It's there purely as a "dumb" backup to my primary logger. I fully admit that I may just be a "better fool" than was envisaged for an otherwise foolproof device. Wondering if others have had similar concerns. Erik Mann P3 With a backup recorder in the glider, you are probably better off with a paper declaration. -Evan Ludeman / T8 |
#35
On Nov 20, 8:45*am, T8 wrote:
On Nov 20, 8:06*am, Papa3 wrote: On Nov 18, 4:03*pm, "noel.wade" wrote: Just a quick note: If you wind up not liking the LX NANO (which I haven't had a chance to play with yet), I've been VERY happy with my EW Micro Recorder units over the last 2 years. *They've performed nearly flawlessly at several contests and a big state-records flight this summer. *Super-simple operation, with an SD card slot and a single on/off button. *You can use the SD Card or a USB cable to plug into the unit and change settings or download flight logs. *Runs off of internal batteries or can be powered externally. *Easily removable from a glider, I mount mine with velcro. *Slightly larger than a deck of cards, and lightweight to boot. *Can drive a PDA (GPS NMEA output) and can accept flight declarations from most of the PDA/flight computer programs out there. Good luck! --Noel While I originally liked the concept of the EW and bought one when it came out, I've found mine to be a bit spotty in a couple of areas. One is the task declaration using the SD Card. * There's some care needed in making sure that the right sequence is followed at power-up to ensure that the task is loaded from the SD Card (if present). Combine that with the internal battery which seems to kick in even if I have disconnected external power, and i've had a few misses that way. *Same thing with shutting the unit off and ensuring I have the log file on the SD Card at the end of the flight. * I seem to get it wrong about half the time. *I should mention that I leave the unit mounted in the glider and do not use any external device (PDA/Laptop) to connect. *It's there purely as a "dumb" backup to my primary logger. I fully admit that I may just be a "better fool" than was envisaged for an otherwise foolproof device. Wondering if others have had similar concerns. Erik Mann P3 With a backup recorder in the glider, you are probably better off with a paper declaration. -Evan Ludeman / T8 Hi Evan, You know me better than that :-) While you're right that a paper declaration is sometimes safer, there are a number of situations where where an electronic declaration is needed. The problem I have with the EW is largely that I can't always be sure that there is nothing in the declaration. For instance, I have a null (blank) declaration on the SD card that should overwrite what's on the EW. That should work... unless, I somehow get the boot sequence wrong. Or, I've decided to change the task at the last minute, and I want to make sure I'm "official" in that both FRs have the same task. Or, I'm trying for a category of record that requires an electronic declaration. I guess my point is just that a reliable declaration process in an FR is a pretty important thing IMO. |
#36
On Nov 20, 11:54*am, Papa3 wrote:
On Nov 20, 8:45*am, T8 wrote: On Nov 20, 8:06*am, Papa3 wrote: On Nov 18, 4:03*pm, "noel.wade" wrote: [snip] Hi Evan, You know me better than that *:-) While you're right that a paper declaration is sometimes safer, there are a number of situations where where an electronic declaration is needed. * The problem I have with the EW is largely that I can't always be sure that there is nothing in the declaration. * For instance, I have a null (blank) declaration on the SD card that should overwrite what's on the EW. * That should work... unless, I somehow get the boot sequence wrong. * Or, I've decided to change the task at the last minute, and I want to make sure I'm "official" in that both FRs have the same task. * Or, I'm trying for a category of record that requires an electronic declaration. I guess my point is just that a *reliable declaration process in an FR is a pretty important thing IMO. While its nice to have electronic declarations that work reliably almost everybody will be fine with paper and should be making paper declarations even if they do an electronic one. The only situation where that does not apply AFAIK is FAI world records. Right? Most of us should carry paper forms and do a paper declaration (in addition and after the electronic declaration is made) ... BTW many of these usability issues are unneeded pain and is unfortunately outside the IGC specs so vendors get to invent all sorts of creative usability problems. e.g some of the EW ones mentioned here, or the Volkslogger re-time stamping a declaration at power-on (enough of a trap IMNSHO to warn people off the Volkslogger altogether if you are doing badges/records) or the older Cambridge GPS (e.g. Model 20) (not the C302) overwriting declarations in IGC files stored on the recorder. Some of these are things that the vendors should have just fixed in the products. BTW on the EW I suspect they tried to make things automatic and the behavior configurable but ended up confusing some people with the complexity of settings and sometimes unexpected behavior. Personally I like just making a declaration from SeeYou Mobile to the flight recorder (C302 in my case). Darryl |
WinCe Flight Recorder | John Godfrey (QT)[_2_] | Soaring | 0 | November 11th 09 12:18 PM |
New flight recorder - flyWithCE Flight Recorder | uros | Soaring | 12 | May 5th 09 08:31 PM |
In flight recorder | Lou | Piloting | 23 | March 24th 07 12:45 AM |
Badges ? ... We don't need no stinkin' badges | Doug Snyder | Soaring | 36 | September 21st 05 08:26 AM |
US: Flight Recorder Alert | Judy Ruprecht | Soaring | 8 | July 19th 04 09:04 PM |
