Any known problems with early ASW27?
Old November 30th 10, 11:17 PM posted to rec.aviation.soaring
Gabriel Duford
Default Any known problems with early ASW27?
Hi,
With some glider models, there are known issues with the early models
(the first 10 or 20 built). Is there any such known issues with the
early ASW27, and if so, up to what serial number?
Thanks,
gabriel
Old December 1st 10, 01:24 PM posted to rec.aviation.soaring
On Nov 30, 6:17*pm, Gabriel Duford wrote:
Hi,
Thanks,
gabriel
Slow water dump was a problem for many folks. Many ships have this
improved by now.
Other than that, it's mostly how well kept.
Still a great glider.
UH
Old December 1st 10, 02:20 PM posted to rec.aviation.soaring
Andy[_1_]
improved by now.
Did the factory ever do anything to improve the dump speed on the 27
or was that improvement a result of owner modification to venting and
fitting (your) larger dump valves?
I know the 28 was modified sometime before serial 48 by adding an
additional vent line to the wing tips but the dump is still stupid
slow.
Andy
Old December 1st 10, 08:14 PM posted to rec.aviation.soaring
hretting
Better hurry, u snooze u lose.
Old December 1st 10, 08:51 PM posted to rec.aviation.soaring
JS
Most problems with early AS-W27, as far as my experience with 27035
and 27058 have been:
It's generally the idiot behind the stick fouling things up.
Old December 1st 10, 08:56 PM posted to rec.aviation.soaring
improved by now.
slow.
Andy
28's configured from factory to accept big valves without modification
shortly after mine(done as special to work out change) was built SN
28015.
Ships with factory water system got original small valves. US ships
ordered without valves could be set up with big valves as plug in
upgrade available from Eastern Sailplane. There is also a conversion
for the few that originally had samll valves. Same applies to 27B's.
During this time Gerhard and I exchanged numerous messages resulting
in 2 vents(I wanted 1 vent with tubing 1 size larger). Airflow in this
long vent is choked at flow rates required to replace water with air.
Next improvement is venting fill cap and adding smal check valve to
get air in better.
Last mod is to add a vent on the bottom of the wing at the outboard
end of the inner tank. This has a ball check valve. Not popular
because people got all itchy about cutting holes in theri shiney
gliders.
With all mods, I test dumped 50 gal in under 3 minutes with most out
in about 2 min. Stock valves and std vents on another ship dumped 50
gal in about 5 1/2 or 6 minutes as I recall.
FWIW
UH
Old December 1st 10, 09:28 PM posted to rec.aviation.soaring
Andy[_1_]
improved by now.
slow.
Andy
28015.
get air in better.
gliders.
FWIW
UH
Thanks for the info. For clarification though are you saying that
28048 (mine) will accept the larger valves with no modification.
After talking with Murray I thought the lower wing surface had to be
milled back to accept the larger valve retaining ring. However that
conversation was when only his prototype was in US and that would
predate 28015.
Andy
Old December 1st 10, 10:14 PM posted to rec.aviation.soaring
improved by now.
slow.
Andy
28015.
get air in better.
gliders.
FWIW
UH
Thanks for the info. *For clarification though are you saying that
milled back to accept the larger valve retaining ring. *However that
predate 28015.
Andy- Hide quoted text -
- Show quoted text -
I'm sure yours will take bigger valves. I can tell you how to confirm.
Contact me off line for that info.
No retaining ring on new valves. Requires opening the bottom hole to 1
3/8 diameter (removes the chamfered seat). Valve seats on inner face
of wing skin with foam seal and is retained by a single screw from the
bottom. Pushrods shorten 1 inch.
Install takes a couple hours if you haven't done before.
John stocks conversion kits with instructions.
He should have vent valve kits also. If not contact me.
UH
Old December 2nd 10, 07:46 AM posted to rec.aviation.soaring
Andy[_10_]
improved by now.
slow.
Andy
28015.
get air in better.
gliders.
FWIW
UH
Last time I measured water capacity on my -27B it came in at a tad
under 40 gallons. Does the 50 gallons mentioned include a fuselage
tank, enlarged bags on an -A model or some other consideration? I
didn't measure capacity super precisely, but I'm pretty sure it wasn't
even close to 50 gallons.
Also, my original factory dump valve arrangement takes closer to 9
minutes to dump the bulk of the tqnk's contents, but after looking at
a couple of modified valve installations I just haven't had the nerve
to start grinding away on the valve opening. It means I have to be
more careful about dumping water early if I get low.
$60,000 is an exceptionally good price. $85,000-$100,000 asking seems
more typical, depending on condition and instrumentation, so I expect
there is a very happy new -27 owner out
there.
9B
Old December 2nd 10, 01:45 PM posted to rec.aviation.soaring
improved by now.
slow.
Andy
28015.
get air in better.
gliders.
FWIW
UH
under 40 gallons. *Does the 50 gallons mentioned include a fuselage
tank, enlarged bags on an -A model or some other consideration? *I
to start grinding away on the valve opening. *It means I have to be
there.
9B- Hide quoted text -
Data was for '28 which has more capacity answering "the other Andy".
'27B/'28 big valve mod has been done about 40 times based on how many
systems have been produced so it is pretty
well proven. The amount removed in enlarging the hole is about 5/32
all around and does not begin to come close to edges
of structure in that area.
UH
ASW27 best offer near $60000.00 Udo Soaring 14 December 1st 10 08:47 PM
WTB: ASW27, Ventus2b or V2bx [email protected] Soaring 0 January 11th 08 12:29 AM
For Sale - ASW27 Andy Smielkiewicz Soaring 0 November 24th 06 04:45 AM
Looking for an ASW27/28 fuselage goneill Soaring 0 May 23rd 04 08:41 PM
ASW27 vs LS8-18 CH Soaring 0 July 22nd 03 10:57 PM
