Well done gliding PR video found on AIRCRAFT OWNER ONLINE
Old December 2nd 10, 03:11 AM posted to rec.aviation.soaring
Bob
Default Well done gliding PR video found on AIRCRAFT OWNER ONLINE
This is a pretty good gliding PR piece aimed General Aviation folks
found on AIRCRAFT OWNER ONLINE WEEKLY NEWSLETTER December 1, 2010
issue. Check it out at
http://www.aircraftowner.com/videos/...show_1567.html
Bob T.
19
Old December 2nd 10, 03:31 AM posted to rec.aviation.soaring
Mike the Strike
issue. *Check it out athttp://www.aircraftowner.com/videos/view/cross-country-soaring-on-the...
Bob T.
19
Very well done indeed. I particularly liked the unique tow-out gear -
any idea who made that?
Mike
Old December 2nd 10, 03:42 AM posted to rec.aviation.soaring
Paul Remde
Hi,
Awesome! Well done!
The person in the video is Don Ingraham of Cross Country Soaring, Inc. He's
a great guy. He represents our sport extremely well and is fun to be
around.
Paul Remde
"Bob" wrote in message
Bob T.
19
Old December 2nd 10, 03:44 AM posted to rec.aviation.soaring
Paul Remde
Hi Mike,
The tow out rig for the Grob was made (I believe) by Don Ingraham or Cross
Country Soaring, Inc. I don't recall the exact design, but it makes it easy
to connect the cart to the 2 Grob 103s they fly and pull them around without
a long rope between them.
Paul Remde
"Mike the Strike" wrote in message
issue. Check it out
Bob T.
19
Mike
Old December 2nd 10, 07:45 PM posted to rec.aviation.soaring
bildan
Bob T.
19
Very well done indeed. *I particularly liked the unique tow-out gear -
Mike
Don designed and built it. IIRC, it's 2" PVC pipe, a toilet plunger
to protect the glider nose and rope down the middle with a Tost ring
set. The stiff pipe prevents the glider from over running and
colliding with the tow out vehicle. It eliminates the need for a tail
dolly and tow bar. Very clever.
It works perfectly with the Grobs and probably any glider with the
aero tow hook in the point of the nose.
Old December 2nd 10, 08:48 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Mike
I'm guessing it's important the weight on the tailwheel be low, or at
least, don't tow it on pavement. The Grob tail weight is likely low,
because the main wheel is farther back than "tail dragger" gliders.
You could still tow a heavy tail glider around as shown, if you used a
tail dolly. A clever system.
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
- "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what
you need to know tinyurl.com/yfs7tnz
Old December 2nd 10, 11:17 PM posted to rec.aviation.soaring
bildan
Mike
Don designed and built it. *IIRC, it's 2" PVC pipe, a toilet plunger
set. *The stiff pipe prevents the glider from over running and
colliding with the tow out vehicle. *It eliminates the need for a tail
dolly and tow bar. *Very clever.
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarmhttp://tinyurl.com/yb3xywl
Again, IIRC, Don's G103 Twin II's are very light on the tailwheel when
unoccupied. I don't think they have ever had their booms repaired. I
was astonished how little effort was needed to lift the tailwheel.
My final flight as owner in N1943L - Video nate_fl Instrument Flight Rules 1 May 5th 10 01:11 PM
My final flight as owner in N1943L - Video [email protected] Piloting 4 May 4th 10 07:50 PM
My final flight as owner in N1943L - Video [email protected] Owning 0 April 30th 10 01:30 AM
New gliding online directory Dan G Soaring 2 December 24th 07 04:52 AM
Online shop for gliding instruments Mika Koski Soaring 3 October 12th 07 08:52 PM
