What's the point? It's still not going to handle all that well,perhaps
worse with the extra speed. How much do you know about how the F-104 "handled"? Got any personal experience? I do...and I think your statement is typical of the ill-educated BS associated with this aircraft. "Jim Yanik" wrote in message .. . "Bjørnar Bolsøy" wrote in : http://www.f-16.net/reference/versions/f16_79.html I've read that the F-104's speed is really limited by the compressor inlet temperature on the J79, and that the airframe itself supports much higher speeds. Since the J79 fits (modified) in a F-16, what then if we were to fit a GE-F110 type engine with closer to twice the thrust? Regards... What's the point? It's still not going to handle all that well,perhaps worse with the extra speed. And probably not worth the money spent on the project. BTW,would the F-104's inlets then become the major restriction for airflow into the engine? I believe the jets that use the newer engines have much larger inlets. -- Jim Yanik jyanik-at-kua.net |
In the G model, we could and did run it out to 800KIAS. Not for very long,
however!! "WaltBJ" wrote in message m... There are three redlines for the F104A with either the -3b or the -19 engine. 710 KIAS, 121C or M 2.0. I believe most Zipper pilots honored these limits in the breach, as the Limeys say. They are all artificial limits as even the -3b engined proverbial 'squadron dog' would exceed all 3 limits. The hard concrete limit is the aluminum airframe. M 2.4 at STP will anneal the aluminum alloy and now the design strength is gone never to return. (The F106 on display at the USAFA is a case in int - 2.46 Mach and she was grounded forever.) FWIW the 2.0 limit is because of reduction in lateral stability beow USAF criteria; Cnbeta limit is .03; think of this as a stability restitution coefficient. Of course if you don't do anything really dumb like stomping on teh rudder - hey,let 'er rip. The KIAS limit is because of internal pressure limits at the rear of the compressor. There is a limit built into the fuel control and it's quite noticeable when it cuts in - but you're over 710 when it does. the airplane is accelerating like mad because those little scoops are really taking in the ram air and all of a sudden the 'governor' cuts in and she stops accelerating. I remember seeing at that point about 750 and 1.2 on the clock at about 100 ASL just before I went right over the top of a shrimp trawler on a test hop early one Florida morning - and that was with an old tired -3b engine. The 121C limit is from a temp sensor in the generator cooling air duct. It turns on the Slow light. The 100 CIT is from the T2 probe at the front of the compressor. I know a couple fearless single Zipper pilots who have been out all the way up at altitude; neither would own up to what their Mach was. One of them returned with scorched paint on his warhead-loaded AIM9s. The other was turned ;ate on a supersonic target on a night exercise - the conroller called 'skip it - we're too far behind.' Howie replied 'keep talking' and put teh throttle in teh far left corner. He heard the controller over an open mike call otu to his buddies - 'Hey! Come look at this!' Howie caught and passed an f4 cruisng supersonic in (probably) minimum AB. Howie, back then, wasn't about to let a little thing like a book limit bother him. He also let teh F4 know he was there. We wondered what the F4 crew thought as something blitzed past them close aboard at least 500 knots faster than they were cruising. One thing I noticed was the fuel flow increase as the IAS increased. A static 8500PPH at the end of the runway (those little intakes!) during the pre-takeoff runup rose to about 12500 at 600KIAS, still on the deck. Since the fuel-air ratio is fixed that indicates the thrust developed increased proportionately. Once took a Dash19 Zipper right off the line, usual war load of 20mm ammo plus 2 AIM9Bs, from brake release to 45000 in 90 seconds flat. Takeoff acceleration was from brake release to .97 - 43 seconds. Rotated to hold .97 and at 40000 stood her on her tail. Exhilirating ride! Mommy, I want a Zipper for Christmas! Walt BJ |
WaltBJ wrote:
There are three redlines for the F104A with either the -3b or the -19 engine. 710 KIAS, 121C or M 2.0. I believe most Zipper pilots honored these limits in the breach, as the Limeys say. Walt, are you sure you weren't thinking of the Deuce (or some other a/c), as far as the KIAS redline goes? I checked the F-104A-1, and for a clean (or AIM-9s and/or pylons at the tips) a/c all it says is 650KEAS at sea level, increasing linearly to 750KEAS at 5,000 and up (there doesn't appear to be a fixed redline on the ASI at all, just a yellow line @ 240KIAS for max. landing flap speed). The instrument section of the Dash 1 dealing with the ASI/Machmeter says "The second aneroid drives the maximum allowable airspeed pointer. This pointer is preset to the aircraft's maximum equivalent airspeed and increases with altitude," agreeing with the operating limits info. Guy |
On Tue, 10 Feb 2004 19:15:19 -0500, "Paul F Austin"
wrote: "Scott Ferrin" wrote in message .. . On Tue, 10 Feb 2004 06:36:25 -0600, "John Carrier" wrote: Relatively easy to fit a smaller diameter engine into the space in which a larger one fit. The retrofit of the 110 engine into the F-14's engine bays (TF-30's somewhat physically larger than a J-79 BTW) was a real squeeze. Compressor inlet temp can be handled by water injection (Skyburner F-4 had it, Greenameyer's F-104 was getting it). Canopy overheating is another problem. R / John If you have access to AW&ST you might want to read about Rascal that DARPA is kicking around. It's pretty interesting and it's along similar lines. Can you be more specific? I searched AvWeek's site for DARPA and Rascal and came up empty. It's the cover story for the September 22, 2003 issue of Aviation Week & Space Technology. Also of interest in that issue is "New Stealth" on page 32. |
