Graphene gliders
Old December 28th 10, 11:21 PM posted to rec.aviation.soaring
bildan
Default Graphene gliders
This is about Bill Collum's story in Soaring, "New Sailplane
Material". I respect Bill's knowledge and enjoy reading his stories
in Soaring. In it he suggests a 50 Lb 15 meter glider will be
possible and I don't doubt it.
Certainly assembling it would be much easier, but to get reasonable
penetration, wouldn't it need water ballast? Now, many fly without
water but with a 50 Lb airframe, that wouldn't be an option. Every
flight would be 'wet' offsetting the ease of assembly with the water
filling hassle.
You might see an increase in the number of the 12 meter gliders but I
don't see many 12 meter gliders entered in 15 meter contests. No
matter how light, I don't think the performance is really there.
Ultimately, if you reduce the density of a glider to that of air, you
have a glider shaped balloon. What's the L/D of a balloon?
Old December 28th 10, 11:35 PM posted to rec.aviation.soaring
Mark Jardini
But think what could be done to the aspect ratio.....
Mark
Old December 29th 10, 12:22 AM posted to rec.aviation.soaring
Chris Nicholas[_2_]
I would add ballast in the form of more lithium polymer batteries, to
drive the electric sustainer motor.
Chris N
Old December 29th 10, 01:59 AM posted to rec.aviation.soaring
Mark
Can you say "low Reynolds number?"
UH
Old December 29th 10, 02:57 AM posted to rec.aviation.soaring
bildan
On Dec 28, 7:29*pm, Bob Whelan wrote:
On 12/28/2010 6:59 PM, wrote:
Mark
UH
Curable by speed! *:-)
Clearly 'practical graphene' will require extensive, systemic thought (and
probably not a little new 'aereodynamic' research), but my nickel is on it
happening. After all, who can seriously imagine glider designers whining about
having a material so good it *hurts* their ability to improve performance
because it's too light?!?
Regards,
Bob W.
My bet would be designers will use the immense strength to eliminate
Va, Vb and Vne speeds. A glider would reach terminal velocity first.
A higher turbulence penetration speed would facilitate higher inter-
thermal speeds. It would be especially beneficial for high altitude,
long distance XC wave flights. Imagine a 300 knot low pass.
Old December 29th 10, 04:04 AM posted to rec.aviation.soaring
RL
At the SSA Conference in PHL we're doing a session on Future
Composites and I'll be discussing the latest graphene and smart
materials technology. We are indeed approaching a tipping point where
nano-reinforcements and active materials will change the structural
paradigm, which in turn will drive aerodynamic advancements.
Bob
Old December 29th 10, 11:31 AM posted to rec.aviation.soaring
Anne
Bob
I'd be more concerned about vertical acceleration in turbulence and
cracking my head on the canopy if the glider were really this light.
1200 pounds gross is where I would like to be - it might be a
challenge to find space for 900 lbs of water ballast.
Mike
Old December 29th 10, 04:21 PM posted to rec.aviation.soaring
Grider Pirate
Bob
Mike
BTDT! Bashed the canopy OFF my Speed Astir with my cranium a couple
years ago!
Old December 29th 10, 10:14 PM posted to rec.aviation.soaring
Herb
Material". *I respect Bill's knowledge and enjoy reading his stories
in Soaring. *In it he suggests a 50 Lb 15 meter glider will be
penetration, wouldn't it need water ballast? *Now, many fly without
water but with a 50 Lb airframe, that wouldn't be an option. *Every
filling hassle.
don't see many 12 meter gliders entered in 15 meter contests. *No
have a glider shaped balloon. *What's the L/D of a balloon?
Hype, hype and more hype in Bill Collums story, pure vapor-ware.
Going from a single layer of graphene molecules to a structural part
is not around the corner - unless its the corner of some distant
galaxy. Remember buckyballs? We were going to have string materials
of unbelievable strenght, space elevators everywhere to get payloads
for pennies into orbit, surely a hazard to soaring activities.
In my uneducated view graphene is an oddity for materials researchers
to mull over and write papers, nothing to see here folks, move
along...
Herb, J7
When jetliners become gliders. [email protected] Soaring 1 February 15th 09 04:50 PM
Gliders? Ben Jeffrey Soaring 1 September 3rd 08 09:25 PM
UK Gliders Jack Soaring 11 June 15th 06 03:50 AM
Battery for gliders Udo Rumpf Soaring 23 January 19th 05 04:13 PM
Still Available to Transport Gliders Jeff Landfield Soaring 0 June 7th 04 07:23 AM
