Noticed that all LET production has ceased including the L23 Blanik
and the L33 solo. Why? Most reports have stated the cause of the L13 failure was fatigue, yet all L13's are grounded. Most fatigue failures are the result of very long life, yet they are not grounding L13's with over X number of hours, they are grounding all L13's. There also seems to be something about the percentage of dual over solo flight time. Any new info on all of this? |
On Jan 9, 8:38*pm, gldrgidr wrote:
Noticed that all LET production has ceased including the L23 Blanik and the L33 solo. *Why? Most reports have stated the cause of the L13 failure was fatigue, yet all L13's are grounded. *Most fatigue failures are the result of very long life, yet they are not grounding L13's with over X number of hours, they are grounding all L13's. *There also seems to be something about the percentage of dual over solo flight time. Any new info on all of this? And if the spar is the same on the L23 shouldn't they be grounded as well... |
On Jan 9, 11:11*pm, "
wrote: And if the spar is the same on the L23 shouldn't they be grounded as well... Not if this is a fatigue problem. Fatigue would only show up after many thousands of hours of service. Remember that the L13 has been around for many years without any problems until now. The much newer L23 's might not suffer any failures for 20 more years. The FAA should be determining what a reasonable safe expected service life for the L13 is, and then ground only the L13's that have accumulated more than that number of hours service. There should also be some kind of approved fix to bring these gliders back into service. Apparently sailplanes are a low priority with the FAA. Has the SSA applied any pressure to get this resolved? A small local club owns only a L13 and are left with no club glider and I am sure there are other clubs in the same mess. |
On Jan 10, 5:35*am, gldrgidr wrote:
On Jan 9, 11:11*pm, " wrote: And if the spar is the same on the L23 shouldn't they be grounded as well... Not if this is a fatigue problem. *Fatigue would only show up after many thousands of hours of service. Remember that the L13 has been around for many years without any problems until now. The much newer L23 's might not suffer any failures for 20 more years. The FAA should be determining what a reasonable safe expected service life for the L13 is, and then ground only the L13's that have accumulated more than that number of hours service. There should also be some kind of approved fix to bring these gliders back into service. Apparently sailplanes are a low priority with the FAA. Has the SSA applied any pressure to get this resolved? There should be a tooth fairy and Santa Claus as well. What actually needs to happen has been talked about here in detail - from both the FAA and SSA perspectives and I believe pro-active owners are trying to work on this. Just spouting off what the FAA should be doing is going will get nothing done. "Fatigue would only show up after many thousands of hours of service." Well if only real world engineering was that simple. There was a fatal crash in a not too old L13 that Austrian air saftey investigators determined appeared to involve fatigue. Then EASA and the FAA followed up with a slate of ADs to try to understand/manage the possible fatigue issue, and I believe those agencies actually looked at this in more than a cursory way. I kind of expect those folks know more about fatigue than you. If you are a subject expert and think they are wrong then do all the owners a favor and take up the issue with EASA and/or the FAA. A small local club owns only a L13 and are left with no club glider and I am sure there are other clubs in the same mess. The TC holder needs to drive the failure/fatigue analysis and engineering fixes. Affected owners should be starting there. The FAA and EASA was not tasked with engineering fixes for aircraft. All this, including the SSA angle has been well discussed here in the past. You can search the r.a.s. archives on Google groups (where the original post was from). Darryl |
On Jan 10, 10:53*am, Darryl Ramm wrote:
On Jan 10, 5:35*am, gldrgidr wrote: On Jan 9, 11:11*pm, " wrote: And if the spar is the same on the L23 shouldn't they be grounded as well... Not if this is a fatigue problem. *Fatigue would only show up after many thousands of hours of service. Remember that the L13 has been around for many years without any problems until now. The much newer L23 's might not suffer any failures for 20 more years. The FAA should be determining what a reasonable safe expected service life for the L13 is, and then ground only the L13's that have accumulated more than that number of hours service. There should also be some kind of approved fix to bring these gliders back into service. Apparently sailplanes are a low priority with the FAA. Has the SSA applied any pressure to get this resolved? There should be a tooth fairy and Santa Claus as well. What actually needs to happen has been talked about here in detail - from both the FAA and SSA perspectives and I believe pro-active owners are trying to work on this. Just spouting off what the FAA should be doing is going will get nothing done. "Fatigue would only show up after many thousands of hours of service." Well if only real world engineering was that simple. There was a fatal crash in a not too old L13 that Austrian air saftey investigators determined appeared to involve fatigue. Then EASA and the FAA followed up with a slate of ADs to try to understand/manage the possible fatigue issue, and I believe those agencies actually looked at this in more than a cursory way. I kind of expect those folks know more about fatigue than you. If you are a subject expert and think they are wrong then do all the owners a favor and take up the issue with EASA and/or the FAA. A small local club owns only a L13 and are left with no club glider and I am sure there are other clubs in the same mess. The TC holder needs to drive the failure/fatigue analysis and engineering fixes. Affected owners should be starting there. The FAA and EASA was not tasked with engineering fixes for aircraft. All this, including the SSA angle has been well discussed here in the past. You can search the r.a.s. archives on Google groups (where the original post was from). Darryl- Hide quoted text - - Show quoted text - Among those posts, LET has published a document setting out how they intend to resolve the issue, and a time frame of early spring to get it done. After that, EASA and the FAA will have to agree to it. The SSA has also published a detailed report from the FAA on the problem. That FAA report is very discouraging. Clearly, the piggyback rivets used in that area of the wing structure are a big issue for the FAA, and LET's document doesn't address that issue at all. LET'S planned eddy current cract detection fix is also going to have to address the issues already raised by the FAA about the effectiveness of such tests. I would not be surprised if there were somewhat more than 100 clubs in the same situation as the one you are close to. However, I'm afraid that given that Blanik L-13's were designed in the 50's, when repair labor costs were low, and they tend to be complex to fix in some areas at the best of times, one shouldn't be surprised if the fix that is eventually approved is complex and expensive to do. And that, as you are obviously aware, is not going to be a good thing for Soaring. |
On Jan 10, 1:37*pm, Sandy Stevenson wrote:
On Jan 10, 10:53*am, Darryl Ramm wrote: On Jan 10, 5:35*am, gldrgidr wrote: On Jan 9, 11:11*pm, " wrote: And if the spar is the same on the L23 shouldn't they be grounded as well... Not if this is a fatigue problem. *Fatigue would only show up after many thousands of hours of service. Remember that the L13 has been around for many years without any problems until now. The much newer L23 's might not suffer any failures for 20 more years. The FAA should be determining what a reasonable safe expected service life for the L13 is, and then ground only the L13's that have accumulated more than that number of hours service. There should also be some kind of approved fix to bring these gliders back into service. Apparently sailplanes are a low priority with the FAA. Has the SSA applied any pressure to get this resolved? There should be a tooth fairy and Santa Claus as well. What actually needs to happen has been talked about here in detail - from both the FAA and SSA perspectives and I believe pro-active owners are trying to work on this. Just spouting off what the FAA should be doing is going will get nothing done. "Fatigue would only show up after many thousands of hours of service." Well if only real world engineering was that simple. There was a fatal crash in a not too old L13 that Austrian air saftey investigators determined appeared to involve fatigue. Then EASA and the FAA followed up with a slate of ADs to try to understand/manage the possible fatigue issue, and I believe those agencies actually looked at this in more than a cursory way. I kind of expect those folks know more about fatigue than you. If you are a subject expert and think they are wrong then do all the owners a favor and take up the issue with EASA and/or the FAA. A small local club owns only a L13 and are left with no club glider and I am sure there are other clubs in the same mess. The TC holder needs to drive the failure/fatigue analysis and engineering fixes. Affected owners should be starting there. The FAA and EASA was not tasked with engineering fixes for aircraft. All this, including the SSA angle has been well discussed here in the past. You can search the r.a.s. archives on Google groups (where the original post was from). Darryl- Hide quoted text - - Show quoted text - Among those posts, LET has published a document setting out how they intend to resolve the issue, and a time frame of early spring to get it done. After that, EASA and the FAA will have to agree to it. The SSA has also published a detailed report from the FAA on the problem. That FAA report is very discouraging. Clearly, the piggyback rivets used in that area of the wing structure are a big issue for the FAA, and LET's document doesn't address that issue at all. *LET'S planned eddy current cract detection fix is also going to have to address the issues already raised by the FAA about the effectiveness of such tests. I would not be surprised if there were somewhat more than 100 clubs in the same situation as the one you are close to. However, I'm afraid that given that Blanik L-13's were designed in the 50's, when repair labor costs were low, and they tend to be complex to fix in some areas at the best of times, one shouldn't be surprised if the fix that is eventually approved is complex and expensive to do. And that, as you are obviously aware, is not going to be a good thing for Soaring. I heard second hand that eddy current testing will be over $10,000/ airframe. X-raying may be done for about $700/airframe, however, someone will have to validate that as an AMOC. There are some recent computer enhancements in xray methods, but not sure if they've been fielded. Certainly DHS has pushed the xray envelope;^) To that end, some owners have volunteered up to 11 wings that could be used to validate an AMOC. Not all of the wings have logbooks. The accident glider had 2200 hours. A wing departed an L-13 in turbulence in Colorado in 1975. Happened again in Germany in 1976. Not details on aircraft time in either case. There are L-13's in the US with as few as 800 hours. It would seem reasonable that low timers should be allowed to fly, perhaps under some restrictions. Frank Whiteley |
On Jan 10, 10:53*am, Darryl Ramm wrote: On Jan 10, 5:35*am, gldrgidr wrote: On Jan 9, 11:11*pm, " wrote: And if the spar is the same on the L23 shouldn't they be grounded as well... Not if this is a fatigue problem. *Fatigue would only show up after many thousands of hours of service. Remember that the L13 has been around for many years without any problems until now. The much newer L23 's might not suffer any failures for 20 more years. The FAA should be determining what a reasonable safe expected service life for the L13 is, and then ground only the L13's that have accumulated more than that number of hours service. There should also be some kind of approved fix to bring these gliders back into service. Apparently sailplanes are a low priority with the FAA. Has the SSA applied any pressure to get this resolved? There should be a tooth fairy and Santa Claus as well. What actually needs to happen has been talked about here in detail - from both the FAA and SSA perspectives and I believe pro-active owners are trying to work on this. Just spouting off what the FAA should be doing is going will get nothing done. "Fatigue would only show up after many thousands of hours of service." Well if only real world engineering was that simple. There was a fatal crash in a not too old L13 that Austrian air saftey investigators determined appeared to involve fatigue. Then EASA and the FAA followed up with a slate of ADs to try to understand/manage the possible fatigue issue, and I believe those agencies actually looked at this in more than a cursory way. I kind of expect those folks know more about fatigue than you. If you are a subject expert and think they are wrong then do all the owners a favor and take up the issue with EASA and/or the FAA. A small local club owns only a L13 and are left with no club glider and I am sure there are other clubs in the same mess. The TC holder needs to drive the failure/fatigue analysis and engineering fixes. Affected owners should be starting there. The FAA and EASA was not tasked with engineering fixes for aircraft. All this, including the SSA angle has been well discussed here in the past. You can search the r.a.s. archives on Google groups (where the original post was from). Darryl- Hide quoted text - - Show quoted text - Among those posts, LET has published a document setting out how they intend to resolve the issue, and a time frame of early spring to get it done. After that, EASA and the FAA will have to agree to it. The SSA has also published a detailed report from the FAA on the problem. That FAA report is very discouraging. Clearly, the piggyback rivets used in that area of the wing structure are a big issue for the FAA, and LET's document doesn't address that issue at all. *LET'S planned eddy current cract detection fix is also going to have to address the issues already raised by the FAA about the effectiveness of such tests. I would not be surprised if there were somewhat more than 100 clubs in the same situation as the one you are close to. However, I'm afraid that given that Blanik L-13's were designed in the 50's, when repair labor costs were low, and they tend to be complex to fix in some areas at the best of times, one shouldn't be surprised if the fix that is eventually approved is complex and expensive to do. And that, as you are obviously aware, is not going to be a good thing for Soaring. 100 US clubs affected is probably about right. I fear your analysis is also right - L-13's will prove too expensive a fix. I sincerely hope your are proved wrong for the sake of those 100 clubs. |
On Jan 9, 10:11*pm, "
wrote: On Jan 9, 8:38*pm, gldrgidr wrote: And if the spar is the same on the L23 shouldn't they be grounded as well... Does anyone have specific information on the differences in the L-23 spar? |
On Jan 10, 4:05*pm, Frank Whiteley wrote:
On Jan 10, 1:37*pm, Sandy Stevenson wrote: On Jan 10, 10:53*am, Darryl Ramm wrote: On Jan 10, 5:35*am, gldrgidr wrote: On Jan 9, 11:11*pm, " wrote: And if the spar is the same on the L23 shouldn't they be grounded as well... Not if this is a fatigue problem. *Fatigue would only show up after many thousands of hours of service. Remember that the L13 has been around for many years without any problems until now. The much newer L23 's might not suffer any failures for 20 more years. The FAA should be determining what a reasonable safe expected service life for the L13 is, and then ground only the L13's that have accumulated more than that number of hours service. There should also be some kind of approved fix to bring these gliders back into service. Apparently sailplanes are a low priority with the FAA. Has the SSA applied any pressure to get this resolved? There should be a tooth fairy and Santa Claus as well. What actually needs to happen has been talked about here in detail - from both the FAA and SSA perspectives and I believe pro-active owners are trying to work on this. Just spouting off what the FAA should be doing is going will get nothing done. "Fatigue would only show up after many thousands of hours of service." Well if only real world engineering was that simple. There was a fatal crash in a not too old L13 that Austrian air saftey investigators determined appeared to involve fatigue. Then EASA and the FAA followed up with a slate of ADs to try to understand/manage the possible fatigue issue, and I believe those agencies actually looked at this in more than a cursory way. I kind of expect those folks know more about fatigue than you. If you are a subject expert and think they are wrong then do all the owners a favor and take up the issue with EASA and/or the FAA. A small local club owns only a L13 and are left with no club glider and I am sure there are other clubs in the same mess. The TC holder needs to drive the failure/fatigue analysis and engineering fixes. Affected owners should be starting there. The FAA and EASA was not tasked with engineering fixes for aircraft. All this, including the SSA angle has been well discussed here in the past. You can search the r.a.s. archives on Google groups (where the original post was from). Darryl- Hide quoted text - - Show quoted text - Among those posts, LET has published a document setting out how they intend to resolve the issue, and a time frame of early spring to get it done. After that, EASA and the FAA will have to agree to it. The SSA has also published a detailed report from the FAA on the problem. That FAA report is very discouraging. Clearly, the piggyback rivets used in that area of the wing structure are a big issue for the FAA, and LET's document doesn't address that issue at all. *LET'S planned eddy current cract detection fix is also going to have to address the issues already raised by the FAA about the effectiveness of such tests. I would not be surprised if there were somewhat more than 100 clubs in the same situation as the one you are close to. However, I'm afraid that given that Blanik L-13's were designed in the 50's, when repair labor costs were low, and they tend to be complex to fix in some areas at the best of times, one shouldn't be surprised if the fix that is eventually approved is complex and expensive to do. And that, as you are obviously aware, is not going to be a good thing for Soaring. I heard second hand that eddy current testing will be over $10,000/ airframe. *X-raying may be done for about $700/airframe, however, someone will have to validate that as an AMOC. *There are some recent computer enhancements in xray methods, but not sure if they've been fielded. *Certainly DHS has pushed the xray envelope;^) *To that end, some owners have volunteered up to 11 wings that could be used to validate an AMOC. *Not all of the wings have logbooks. The accident glider had 2200 hours. *A wing departed an L-13 in turbulence in Colorado in 1975. *Happened again in Germany in 1976. Not details on aircraft time in either case. There are L-13's in the US with as few as 800 hours. *It would seem reasonable that low timers should be allowed to fly, perhaps under some restrictions. Frank Whiteley- Hide quoted text - - Show quoted text - I know you mean well, Frank, but I don't think the FAA or EASA will go along with that idea. It isn't just number of hours; it's also time. There isn't an L-13 newer than 30 years old. I suspect they're going to want significant evidence that individual machines are demonstrably sound. In that vein, the figure I've seen posted above of $10k for eddy current inspection I presume is for both wings including opening, repair if necessry, and closing. the eddy current inspection itself is already called for in one Blanik AD, and my recollection is that by itself it's only about $1500; possibly less. However, LET is suggesting that they will be looking at a modified form of eddy current in order to address the issue of how much area around a rivet is actually properly examined by a probe inserted in the rivet hole. It remains to be seen whether the inspection technique proposed will be more expensive to perform than the usual eddy current inspections. If a way is found to assure the safety of the L-13 fleet at modest cost I will be quite surprised, but also greatly relieved. |
On Jan 11, 8:56*pm, Sandy Stevenson wrote:
On Jan 10, 4:05*pm, Frank Whiteley wrote: On Jan 10, 1:37*pm, Sandy Stevenson wrote: On Jan 10, 10:53*am, Darryl Ramm wrote: On Jan 10, 5:35*am, gldrgidr wrote: On Jan 9, 11:11*pm, " wrote: And if the spar is the same on the L23 shouldn't they be grounded as well... Not if this is a fatigue problem. *Fatigue would only show up after many thousands of hours of service. Remember that the L13 has been around for many years without any problems until now. The much newer L23 's might not suffer any failures for 20 more years. The FAA should be determining what a reasonable safe expected service life for the L13 is, and then ground only the L13's that have accumulated more than that number of hours service. There should also be some kind of approved fix to bring these gliders back into service. Apparently sailplanes are a low priority with the FAA. Has the SSA applied any pressure to get this resolved? There should be a tooth fairy and Santa Claus as well. What actually needs to happen has been talked about here in detail - from both the FAA and SSA perspectives and I believe pro-active owners are trying to work on this. Just spouting off what the FAA should be doing is going will get nothing done. "Fatigue would only show up after many thousands of hours of service." Well if only real world engineering was that simple. There was a fatal crash in a not too old L13 that Austrian air saftey investigators determined appeared to involve fatigue. Then EASA and the FAA followed up with a slate of ADs to try to understand/manage the possible fatigue issue, and I believe those agencies actually looked at this in more than a cursory way. I kind of expect those folks know more about fatigue than you. If you are a subject expert and think they are wrong then do all the owners a favor and take up the issue with EASA and/or the FAA. A small local club owns only a L13 and are left with no club glider and I am sure there are other clubs in the same mess. The TC holder needs to drive the failure/fatigue analysis and engineering fixes. Affected owners should be starting there. The FAA and EASA was not tasked with engineering fixes for aircraft. All this, including the SSA angle has been well discussed here in the past. You can search the r.a.s. archives on Google groups (where the original post was from). Darryl- Hide quoted text - - Show quoted text - Among those posts, LET has published a document setting out how they intend to resolve the issue, and a time frame of early spring to get it done. After that, EASA and the FAA will have to agree to it. The SSA has also published a detailed report from the FAA on the problem. That FAA report is very discouraging. Clearly, the piggyback rivets used in that area of the wing structure are a big issue for the FAA, and LET's document doesn't address that issue at all. *LET'S planned eddy current cract detection fix is also going to have to address the issues already raised by the FAA about the effectiveness of such tests. I would not be surprised if there were somewhat more than 100 clubs in the same situation as the one you are close to. However, I'm afraid that given that Blanik L-13's were designed in the 50's, when repair labor costs were low, and they tend to be complex to fix in some areas at the best of times, one shouldn't be surprised if the fix that is eventually approved is complex and expensive to do. And that, as you are obviously aware, is not going to be a good thing for Soaring. I heard second hand that eddy current testing will be over $10,000/ airframe. *X-raying may be done for about $700/airframe, however, someone will have to validate that as an AMOC. *There are some recent computer enhancements in xray methods, but not sure if they've been fielded. *Certainly DHS has pushed the xray envelope;^) *To that end, some owners have volunteered up to 11 wings that could be used to validate an AMOC. *Not all of the wings have logbooks. The accident glider had 2200 hours. *A wing departed an L-13 in turbulence in Colorado in 1975. *Happened again in Germany in 1976. Not details on aircraft time in either case. There are L-13's in the US with as few as 800 hours. *It would seem reasonable that low timers should be allowed to fly, perhaps under some restrictions. Frank Whiteley- Hide quoted text - - Show quoted text - I know you mean well, Frank, but I don't think the FAA or EASA will go along with that idea. It isn't just number of hours; it's also time. *There isn't an L-13 newer than 30 years old. I suspect they're going to want significant evidence that individual machines are demonstrably sound. In that vein, the figure I've seen posted above of $10k for eddy current inspection I presume is for both wings including opening, repair if necessry, and closing. the eddy current inspection itself is already called for in one Blanik AD, and my recollection is that by itself it's only about $1500; possibly less. However, LET is suggesting that they will be looking at a modified form of eddy current in order to address the issue of how much area around a rivet is actually properly examined by a probe inserted in the rivet hole. It remains to be seen whether the inspection technique proposed will be more expensive to perform than the usual eddy current inspections. If a way is found to assure the safety of the L-13 fleet at modest cost I will be quite surprised, but also greatly relieved. I think you are referring to the GFA document, which is over 20 years old. This was a recent cost estimate. The long term problem is that inspections will be recurrent at some maximum interval, like every 500 hours. If it's $1500/glider, might be doable. If it's the higher estimate, maybe the Llewellyn mod would be better. As of January 6th, the factory hopes to have some Eddy current testing results by February. See https://sites.google.com/site/blanikspar/home#BRUNO Frank Whiteley |
| Blanik L-13 AD | Jim[_18_] | Soaring | 20 | August 30th 10 09:25 PM |
| Blanik L-23 Super Blanik Manual -F.C.F.S. | Joel Flamenbaum | Soaring | 2 | April 14th 10 04:29 PM |
| Blanik L23 AD | tomcatvf51 | Soaring | 0 | February 12th 09 01:52 PM |
| Blanik L-13 | brien | Soaring | 0 | December 5th 04 03:00 PM |
| Mig-29 questions & general aviation questions 2003 | Steven | Military Aviation | 1 | October 20th 03 07:06 AM |
