"Harley W. Daugherty" wrote in message k.net...
"Chad Irby" wrote in message om... In article 402a7579$1@bg2., "Matt Wiser" wrote: If you had been given the task of choosing the plaform for a next-generation gunship, would the C-130J be the platform base, or would an as yet unbuilt A400M be chosen? I'd take an AC-130 based on the J, but use the stretched J, with two instead of one 25mms, one 40mm, and the 105. Add single rail launchers underwing for Hellfire. We've already had the AC-5 suggested... sweet Jesus..................... What kinda loadout you put on that monstrosity? I'd prefer a AC-17 variant.... Harley W. Daugherty -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. C-17 has 3x the max takeoff weight of a AC-130, C-5 5x. Even with structural strengthening, that is a lot of leftover weight to play with. However, not a chance in hell are C-5s getting used as gunships. If anyone is an AFA member, read last month's magazine. The Air Force is doing everything it can to keep the cargo C-5s hauling as much as possible, and with little or no prospect of new construction of them, they aren't going to divert airframes from Air Mobility Command to Spec Ops. The C-17 is still in production, so that is another story. A C-17's MTW is around 500000 lbs versus about 150000 lbs for an AC-130. Even with the weight to strenghten the airframe, that is a lot of volume and lift to use for guns, ammo, sensors, jammers, missiles etc... |
"Chad Irby" wrote in message . com... In article , "Harley W. Daugherty" wrote: "Chad Irby" wrote in message om... We've already had the AC-5 suggested... sweet Jesus..................... What kinda loadout you put on that monstrosity? Everything. Just... everything. Yea, if not some 8" cannon with Copperhead I understand there's still some 16" guns in depot. Probably not have more than one of either and the 16 would have to fire straight ahead. Think of it like the B-25G but with the 16" replacing the 75mm. Possibly an airborne reloadable rotary launcher for MLRS rounds; if we have spare development cash at the end a special version with 3/4s of the propellant traded for more HE. A couple of Phalanx systems for self defense. Or, again, if the development budget is big enough an adaptation of THEL for the job. Could give THEL the role of defending troops in contact from mortar rounds too. Hmm, come to think of it, THEL would make a nice "danger close" antipersonnel weapon too. Ah heck, let's just stuff the thing full of THEL, COIL and/or the solid state systems that are about ready and go pure directed energy. We'll call it the "Death Star", er, make that the "Death Galaxy". |
Well that's what I was told as to why the USAF is only buying the regular
one and the Brits aren't buying them for their Spec Ops squadrons. Like you, I thought the stretch J was a great upgrade for the Combat Talon, but when I proposed it as an option (in the late '90s ) that was the answer I got from some pretty high up in AFSOC. Les "Kevin Brooks" wrote in message ... "Les Matheson" wrote in message news:iOyWb.3630$Yj.3407@lakeread02... Stretched J model is a problem, as you can't do assault landings with it, and I'm sure some minimum field length issues will be in the specs. Are you sure about that? According to LMCO, the USAF was conducting tests with the CC-130J back in late 2002 to certify it for assault landing use. www.lmaeronautics.com/lmaerostar/ pdfs/year02/sep_02.pdf Brooks -- Les F-4C(WW),D,E,G(WW)/AC-130A/MC-130E EWO (ret) "Matt Wiser" wrote in message news:402a7579$1@bg2.... If you had been given the task of choosing the plaform for a next-generation gunship, would the C-130J be the platform base, or would an as yet unbuilt A400M be chosen? I'd take an AC-130 based on the J, but use the stretched J, with two instead of one 25mms, one 40mm, and the 105. Add single rail launchers underwing for Hellfire. Posted via www.My-Newsgroups.com - web to news gateway for usenet access! |
"Les Matheson" wrote in message news:hsKWb.3680$Yj.1623@lakeread02... Well that's what I was told as to why the USAF is only buying the regular one and the Brits aren't buying them for their Spec Ops squadrons. Like you, I thought the stretch J was a great upgrade for the Combat Talon, but when I proposed it as an option (in the late '90s ) that was the answer I got from some pretty high up in AFSOC. Things have changed. The USAF is indeed buying the stretched CC-130J--IIRC the first ones went to the Rhode Island ANG. I doubt they would be buying them if they could not perform assault landings. Brooks Les "Kevin Brooks" wrote in message ... "Les Matheson" wrote in message news:iOyWb.3630$Yj.3407@lakeread02... Stretched J model is a problem, as you can't do assault landings with it, and I'm sure some minimum field length issues will be in the specs. Are you sure about that? According to LMCO, the USAF was conducting tests with the CC-130J back in late 2002 to certify it for assault landing use. www.lmaeronautics.com/lmaerostar/ pdfs/year02/sep_02.pdf Brooks -- Les F-4C(WW),D,E,G(WW)/AC-130A/MC-130E EWO (ret) "Matt Wiser" wrote in message news:402a7579$1@bg2.... If you had been given the task of choosing the plaform for a next-generation gunship, would the C-130J be the platform base, or would an as yet unbuilt A400M be chosen? I'd take an AC-130 based on the J, but use the stretched J, with two instead of one 25mms, one 40mm, and the 105. Add single rail launchers underwing for Hellfire. Posted via www.My-Newsgroups.com - web to news gateway for usenet access! |
I doubt they do assault landings like Spec Ops 130s do assault landings.
I've broken teeth. -- Les F-4C(WW),D,E,G(WW)/AC-130A/MC-130E EWO (ret) "Kevin Brooks" wrote in message ... "Les Matheson" wrote in message news:hsKWb.3680$Yj.1623@lakeread02... Well that's what I was told as to why the USAF is only buying the regular one and the Brits aren't buying them for their Spec Ops squadrons. Like you, I thought the stretch J was a great upgrade for the Combat Talon, but when I proposed it as an option (in the late '90s ) that was the answer I got from some pretty high up in AFSOC. Things have changed. The USAF is indeed buying the stretched CC-130J--IIRC the first ones went to the Rhode Island ANG. I doubt they would be buying them if they could not perform assault landings. Brooks Les "Kevin Brooks" wrote in message ... "Les Matheson" wrote in message news:iOyWb.3630$Yj.3407@lakeread02... Stretched J model is a problem, as you can't do assault landings with it, and I'm sure some minimum field length issues will be in the specs. Are you sure about that? According to LMCO, the USAF was conducting tests with the CC-130J back in late 2002 to certify it for assault landing use. www.lmaeronautics.com/lmaerostar/ pdfs/year02/sep_02.pdf Brooks -- Les F-4C(WW),D,E,G(WW)/AC-130A/MC-130E EWO (ret) "Matt Wiser" wrote in message news:402a7579$1@bg2.... If you had been given the task of choosing the plaform for a next-generation gunship, would the C-130J be the platform base, or would an as yet unbuilt A400M be chosen? I'd take an AC-130 based on the J, but use the stretched J, with two instead of one 25mms, one 40mm, and the 105. Add single rail launchers underwing for Hellfire. Posted via www.My-Newsgroups.com - web to news gateway for usenet access! |
Les Matheson wrote:
I doubt they do assault landings like Spec Ops 130s do assault landings. I've broken teeth. I'm somewhat confused. Why would the AC-130 replacement *need* to do assault landings. An MC-130 replacementr, sure, but the AC should be orbiting somewhere, not landing, if I understand their roles properly. -- Tom Schoene Replace "invalid" with "net" to e-mail "If brave men and women never died, there would be nothing special about bravery." -- Andy Rooney (attributed) |
Because they are going to use the same airframe, I'm pretty sure of that.
-- Les F-4C(WW),D,E,G(WW)/AC-130A/MC-130E EWO (ret) "Thomas Schoene" wrote in message ink.net... Les Matheson wrote: I doubt they do assault landings like Spec Ops 130s do assault landings. I've broken teeth. I'm somewhat confused. Why would the AC-130 replacement *need* to do assault landings. An MC-130 replacementr, sure, but the AC should be orbiting somewhere, not landing, if I understand their roles properly. -- Tom Schoene Replace "invalid" with "net" to e-mail "If brave men and women never died, there would be nothing special about bravery." -- Andy Rooney (attributed) |
"Les Matheson" wrote in message news:nxXWb.4716$Yj.2563@lakeread02... Because they are going to use the same airframe, I'm pretty sure of that. -- Les F-4C(WW),D,E,G(WW)/AC-130A/MC-130E EWO (ret) "Thomas Schoene" wrote in message ink.net... Les Matheson wrote: I doubt they do assault landings like Spec Ops 130s do assault landings. I've broken teeth. I'm somewhat confused. Why would the AC-130 replacement *need* to do assault landings. An MC-130 replacementr, sure, but the AC should be orbiting somewhere, not landing, if I understand their roles properly. -- Tom Schoene Replace "invalid" with "net" to e-mail "If brave men and women never died, there would be nothing special about bravery." -- Andy Rooney (attributed) Baltimore was the first US unit to get the 130J but they were shorties. So are Keesler's I believe. Rhode Islands and ours are stretches, and as far as we've been told all the new J's will be stretches. There was talk of sending the shorties back to be stretched. We were doing assault landings with a stretch out in the desert by Yuma back in the fall of 2002. As far as I know it all came out good. Steve R. |
I guess that is good news, but is contradictory to what I was told. Maybe
they did something to the frame. Les "Steve R." wrote in message news ![]() "Les Matheson" wrote in message news:nxXWb.4716$Yj.2563@lakeread02... Because they are going to use the same airframe, I'm pretty sure of that. -- Les F-4C(WW),D,E,G(WW)/AC-130A/MC-130E EWO (ret) "Thomas Schoene" wrote in message ink.net... Les Matheson wrote: I doubt they do assault landings like Spec Ops 130s do assault landings. I've broken teeth. I'm somewhat confused. Why would the AC-130 replacement *need* to do assault landings. An MC-130 replacementr, sure, but the AC should be orbiting somewhere, not landing, if I understand their roles properly. -- Tom Schoene Replace "invalid" with "net" to e-mail "If brave men and women never died, there would be nothing special about bravery." -- Andy Rooney (attributed) Baltimore was the first US unit to get the 130J but they were shorties. So are Keesler's I believe. Rhode Islands and ours are stretches, and as far as we've been told all the new J's will be stretches. There was talk of sending the shorties back to be stretched. We were doing assault landings with a stretch out in the desert by Yuma back in the fall of 2002. As far as I know it all came out good. Steve R. |
"George" wrote in message m... "Harley W. Daugherty" wrote in message k.net... "Chad Irby" wrote in message om... In article 402a7579$1@bg2., "Matt Wiser" wrote: If you had been given the task of choosing the plaform for a next-generation gunship, would the C-130J be the platform base, or would an as yet unbuilt A400M be chosen? I'd take an AC-130 based on the J, but use the stretched J, with two instead of one 25mms, one 40mm, and the 105. Add single rail launchers underwing for Hellfire. We've already had the AC-5 suggested... sweet Jesus..................... What kinda loadout you put on that monstrosity? I'd prefer a AC-17 variant.... Harley W. Daugherty -- cirby at cfl.rr.com Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. C-17 has 3x the max takeoff weight of a AC-130, C-5 5x. Even with structural strengthening, that is a lot of leftover weight to play with. However, not a chance in hell are C-5s getting used as gunships. If anyone is an AFA member, read last month's magazine. The Air Force is doing everything it can to keep the cargo C-5s hauling as much as possible, and with little or no prospect of new construction of them, they aren't going to divert airframes from Air Mobility Command to Spec Ops. The C-17 is still in production, so that is another story. A C-17's MTW is around 500000 lbs versus about 150000 lbs for an AC-130. Even with the weight to strenghten the airframe, that is a lot of volume and lift to use for guns, ammo, sensors, jammers, missiles etc... So a AC-17 is a serious possibility!? THEL. hmmm, any one got a mass/Weight break down on that? It would make a intrewsing add on. Harley |
| AC-130 Replacement Contemplated | sid | Military Aviation | 29 | February 10th 04 11:15 PM |
| Magneto/comm interference on TKM MX-R Narco 120 replacement | Eugene Wendland | Home Built | 5 | January 13th 04 03:17 PM |
| Canada to order replacement for the Sea King | Ed Majden | Military Aviation | 3 | December 18th 03 08:02 PM |
| Replacement for C130? | John Penta | Military Aviation | 24 | September 29th 03 08:11 PM |
| Hellfire Replacement | Eric Moore | Military Aviation | 6 | July 2nd 03 03:22 AM |
