Klaus Ohlmann has broken more world records in Patagonia, some of the
few he didn't hold (or rather some of his own records which were recently broken). Triangles in Patagonia are extraordinarily difficult because they require leaving the wave routes along the Andes to get a turnpoint in the Pampas and then return against headwinds back to the wave routes. This has not been a good year for wave flying in Patagonia due to the "La Niña" phenomenon. Nevertheless there have been several 2K+ flights. Here is Klaus' report and a link to the OLC files: PILOT REPORT 12.01.2011 World record 1750,6 km declared triangle, 1755,5 km free triangle and Speed task for a 1750 km triangle with 119,29 km/h. It was really a great day for me. I have worked so hard for years, of course with a lot of pleasure, to find different solutions for this triangle stuff, which, as we know, is not really adapted for wave- flying. I'm quite sure, that this is the best solution for the problem. There are certainly better days than yesterday to do this flight. The first 200 km were weak and blue until El Maiten. But even then it was not easy to find the best lifts. I stopped climbing most of the time in 4000m due to weaker lifts above. I was one hour too late at the first TP. But the second leg was better than in the planning with one great lift in the middle of nowhere. It was the only one up to FL 195 on this leg, the rest were only weak alignments above the cumulus. After TP 2 I was forced to pass below the clouds in thermals, due to lack of wave lifts, which were strong enough. It was a long trip between "hope and fear" against the wind. I tried always to go more to El Maiten to come back to the first wave line, a little bit closer to home. But finally I went back to the south due to the enormous Rotor lennies formed there. No regrets, up to 9 m/s!! The rest was a last race against the end of the daylight. As always, it was this mixture of adapted planning during one week, hope, determination and good luck, which makes our sport so exciting. Klaus Ohlmann http://www.onlinecontest.org/olc-2.0...l?dsId=1604149 |
Congratulations on your great flight! Thanks for sharing this with
us. It is nice to have some pilots information beside just looking at your flight on OLC. Randy |
On Jan 14, 8:41*am, Juanman wrote:
Klaus Ohlmann has broken more world records in Patagonia, some of the few he didn't hold (or rather some *of his own records which were recently broken). * Triangles in Patagonia are extraordinarily difficult because they require leaving the wave routes along the Andes to get a turnpoint in the Pampas and then return against headwinds back to the wave routes. This has not been a good year for wave flying in Patagonia due to the "La Niña" phenomenon. *Nevertheless there have been several 2K+ flights. *Here is Klaus' report and a link to the OLC files: * * * * * * * * * * * *PILOT REPORT 12.01.2011 World record 1750,6 km declared triangle, 1755,5 km free triangle and Speed task for a 1750 km triangle *with 119,29 km/h. It was really a great day for me. I have worked so hard for years, of course with a lot of pleasure, to find different solutions for this triangle stuff, which, as we know, is not really adapted for wave- flying. I'm quite sure, that this is the best solution for the problem. There are certainly better days than yesterday to do this flight. The first 200 km were weak and blue until El Maiten. But even then it was not easy to find the best lifts. I stopped climbing most of the time in 4000m due to weaker lifts above. I was one hour too late at the first TP. *But the second leg was better than in the planning with one great lift in the middle of nowhere. It was the only one up to FL 195 on this leg, the rest were only weak alignments above the cumulus. After TP 2 I was forced to pass below the clouds in thermals, due to lack of wave lifts, which were strong enough. It was a long trip between "hope and fear" against the wind. I tried always to go more to El Maiten to come back to the first wave line, a little bit closer to home. But finally I went back to the south due to the enormous Rotor lennies formed there. No regrets, up to 9 m/s!! *The rest was a last race against the end of the daylight. As always, it was this mixture of adapted planning during one week, hope, determination and good luck, which makes our sport so exciting. Klaus Ohlmann http://www.onlinecontest.org/olc-2.0....html?dsId=160.... wow, awesome flight! |
Extraordinary! Congratulations!!
Andrej -- glider pilots use http://www.Naviter.com On 14 jan., 15:41, Juanman wrote: Klaus Ohlmann has broken more world records in Patagonia, some of the few he didn't hold (or rather some *of his own records which were recently broken). * Triangles in Patagonia are extraordinarily difficult because they require leaving the wave routes along the Andes to get a turnpoint in the Pampas and then return against headwinds back to the wave routes. This has not been a good year for wave flying in Patagonia due to the "La Niña" phenomenon. *Nevertheless there have been several 2K+ flights. *Here is Klaus' report and a link to the OLC files: * * * * * * * * * * * *PILOT REPORT 12.01.2011 World record 1750,6 km declared triangle, 1755,5 km free triangle and Speed task for a 1750 km triangle *with 119,29 km/h. It was really a great day for me. I have worked so hard for years, of course with a lot of pleasure, to find different solutions for this triangle stuff, which, as we know, is not really adapted for wave- flying. I'm quite sure, that this is the best solution for the problem. There are certainly better days than yesterday to do this flight. The first 200 km were weak and blue until El Maiten. But even then it was not easy to find the best lifts. I stopped climbing most of the time in 4000m due to weaker lifts above. I was one hour too late at the first TP. *But the second leg was better than in the planning with one great lift in the middle of nowhere. It was the only one up to FL 195 on this leg, the rest were only weak alignments above the cumulus. After TP 2 I was forced to pass below the clouds in thermals, due to lack of wave lifts, which were strong enough. It was a long trip between "hope and fear" against the wind. I tried always to go more to El Maiten to come back to the first wave line, a little bit closer to home. But finally I went back to the south due to the enormous Rotor lennies formed there. No regrets, up to 9 m/s!! *The rest was a last race against the end of the daylight. As always, it was this mixture of adapted planning during one week, hope, determination and good luck, which makes our sport so exciting. Klaus Ohlmann http://www.onlinecontest.org/olc-2.0....html?dsId=160.... |
FAI triangle records speed question | Bruno | Soaring | 1 | June 6th 09 05:05 PM |
Zoom & World Records | Al G[_1_] | Home Built | 0 | March 18th 08 08:57 PM |
World Records | Nick Gilbert | Soaring | 2 | February 26th 04 06:43 PM |
100k triangle world record claim | Stewart Kissel | Soaring | 0 | November 11th 03 05:21 PM |
First California World Class Records | Steve Pawling | Soaring | 3 | August 4th 03 11:47 PM |
