Hi,
I have decided to buy a Dell Streak 5" for XCSoar, replacing my old iPaq hx4700. It runs with Android, not Windows CE. We will release a "stable" version of XCSoar for Android in March or April 2011, and this switch to Android in my own glider will give me some more motivation to make our Android version more mature. XCSoar is available for free on the Android Market. The Streak arrived today, and I've installed XCSoar on it. As expected, it is faster than my old HTC Magic. The CPU is a modern 1 GHz Snapdragon ARM chip, with good OpenGL support. http://max.kellermann.name/gallery/f..._1024x768.html The Streak is bigger than PDAs, but not a lot. 5 inch is just the right size for the cockpit. Mobile phones are too small, and tablets are too large. The display is a transflective TFT, which looks pretty bright. The weather is overcast today in Germany, no direct sunlight to test with. At normal daylight, it looks much brighter than a hx4700 and a Dell Axim x51v. It is comparable to the Altair display, but one needs to consider that the Altair has an antireflective display, while the Streak seems like a mirror - applying an anti-glare layer will reduce its brightness slightly. http://max.kellermann.name/gallery/f..._1024x768.html The Streak has a high-resolution display (800x480, same as the LX Mini Map and iPaq 31x). The Altair has 320x240, and the other PDAs on the photo have 640x480. An Oudie is limited to 480x272. I would not go below 640x480, and 800x480 feels comfortable. The display is capable of multi-touch. XCSoar doesn't have multi-touch yet, but we will eventually implement that. More pictures: http://max.kellermann.name/gallery/fliegen/streak/ Max |
On Feb 1, 8:59*am, Max Kellermann wrote:
Hi, * * * * * * * * * * * * * * * * * I have decided to buy a Dell Streak 5" for XCSoar, replacing my old iPaq hx4700. *It runs with Android, not Windows CE. *We will release a "stable" version of XCSoar for Android in March or April 2011, and this switch to Android in my own glider will give me some more motivation to make our Android version more mature. *XCSoar is available for free on the Android Market. The Streak arrived today, and I've installed XCSoar on it. *As expected, it is faster than my old HTC Magic. *The CPU is a modern 1 GHz Snapdragon ARM chip, with good OpenGL support. *http://max.kellermann.name/gallery/f..._1024x768.html The Streak is bigger than PDAs, but not a lot. *5 inch is just the right size for the cockpit. *Mobile phones are too small, and tablets are too large. The display is a transflective TFT, which looks pretty bright. *The weather is overcast today in Germany, no direct sunlight to test with. At normal daylight, it looks much brighter than a hx4700 and a Dell Axim x51v. *It is comparable to the Altair display, but one needs to consider that the Altair has an antireflective display, while the Streak seems like a mirror - applying an anti-glare layer will reduce its brightness slightly. *http://max.kellermann.name/gallery/f..._1024x768.html The Streak has a high-resolution display (800x480, same as the LX Mini Map and iPaq 31x). *The Altair has 320x240, and the other PDAs on the photo have 640x480. *An Oudie is limited to 480x272. *I would not go below 640x480, and 800x480 feels comfortable. The display is capable of multi-touch. *XCSoar doesn't have multi-touch yet, but we will eventually implement that. More pictures:http://max.kellermann.name/gallery/fliegen/streak/ Max Look forward to your report when the sun returns, Max. |
Barbs wrote:
Lots of people have complained about the keyboard issue inputting names, it is a problem, but with a bit of trial and error you can succeed (it is there, but just invisible, querty). This bug was reported a few weeks ago, and I managed to fix it today: http://www.xcsoar.org/trac/ticket/786 (Please report all bugs to that page; bugs don't get fixed unless you make us aware of them.) A new maintenance release (6.0.3) is going to be released within the next 24 hours, and it will include this fix. Max |
I tried to signup using openID and the system has now totally rejected
me. ![]() Will try again Thank you On Feb 1, 9:13*pm, Max Kellermann wrote: Barbs wrote: Lots of people have complained about the keyboard issue inputting names, it is a problem, but with a bit of trial and error you can succeed (it is there, but just invisible, querty). This bug was reported a few weeks ago, and I managed to fix it today: *http://www.xcsoar.org/trac/ticket/786 (Please report all bugs to that page; bugs don't get fixed unless you make us aware of them.) A new maintenance release (6.0.3) is going to be released within the next 24 hours, and it will include this fix. Max |
Mike wrote:
Look forward to your report when the sun returns, Max. The spring is coming now! Streak vs Altair in direct sunlight: http://max.kellermann.name/gallery/f..._1024x768.html http://max.kellermann.name/gallery/f..._1024x768.html More pictures: http://max.kellermann.name/gallery/fliegen/streak/ Both displays are doing very well, but it is very hard to make good pictures. It depends very much on the angle. You can read both displays very well in direct sunlight, but you might have to turn them slightly. The Streak turns into a mirror quickly in some sun angles, but you can still focus your eyes on the screen (within limits). At the same angle, the Altair is not doing significantly better: instead of seeing a small mirror image, you can see the sun spotlight all over the screen, making it unreadable as a whole. Max |
On Feb 9, 5:03*am, Max Kellermann wrote:
Mike wrote: Look forward to your report when the sun returns, Max. The spring is coming now! Streak vs Altair in direct sunlight: *http://max.kellermann.name/gallery/f..._1024x768.html *http://max.kellermann.name/gallery/f..._1024x768.html More pictures:http://max.kellermann.name/gallery/fliegen/streak/ Both displays are doing very well, but it is very hard to make good pictures. *It depends very much on the angle. *You can read both displays very well in direct sunlight, but you might have to turn them slightly. The Streak turns into a mirror quickly in some sun angles, but you can still focus your eyes on the screen (within limits). *At the same angle, the Altair is not doing significantly better: instead of seeing a small mirror image, you can see the sun spotlight all over the screen, making it unreadable as a whole. Max Looks pretty good. Is it really that much brighter than the 4700, or is the back light off on the Ipaq? thanks, Mike |
Mike wrote:
Looks pretty good. Is it really that much brighter than the 4700, or is the back light off on the Ipaq? Backlight was forced to 100% on all of the devices. There is a huge difference between hx4700 and Streak/Altair. Even more in "reality"; the dull photos don't show the difference well enough. (Still need to experiment with anti-glare foil on the Streak) Max |
AnyWhere Map w/Dell Axim | Peter Westerkamp-TBRR | Owning | 20 | February 6th 07 02:24 PM |
Who needs terrorists when we have Dell? | cjcampbell | Piloting | 38 | August 22nd 06 05:35 PM |
Dell Dimension 8300 | Tlewis95 | Simulators | 3 | March 4th 04 07:50 PM |
Streak Shadow | david H | Home Built | 0 | December 27th 03 10:43 PM |
Streak Shadow | david H | Home Built | 0 | December 26th 03 10:22 PM |
