New small transponder
Old March 4th 11, 01:28 AM posted to rec.aviation.soaring
Dave White
Default New small transponder
This is the article from the EAA newsletter:
http://www.ksallink.com/?cmd=display...13&format=html
This is the manufacturer:
http://www.aaicorp.com
Wonder if they might consider adapting this thing to gliders?
Old March 4th 11, 01:57 AM posted to rec.aviation.soaring
Whiskey Delta
Manufacturer link is actually: http://sagetechcorp.com/
Old March 4th 11, 02:20 AM posted to rec.aviation.soaring
Martin[_5_]
Nope...the market is too small. I asked them at a trade show. It's
meant for UAVs. That market is small, too, in terms of volume, but
they can charge a lot...UAV makers are less price sensitive than
glider owners.
Old March 4th 11, 02:42 AM posted to rec.aviation.soaring
JS
Other than a few thousand dollars, what's the difference between their
"conventional manned installation" and "adapted to gliders"?
Old March 4th 11, 03:19 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Pro: the "power box" is about half the thickness of a Trig power box.
Cons: The power consumption is greater than a Trig according to their
data sheet, it's not TSO'd.
It would have to be several hundred dollars cheaper the Trig than to
appeal to me enough to dump my Becker, based on those pros/cons.
email me)
Old March 4th 11, 12:01 PM posted to rec.aviation.soaring
Nigel Cottrell[_2_]
At 02:42 04 March 2011, JS wrote:
This looks a lot like the Trig 21 which I have had fitted in a powered
plane for about 18 months and am very happy with.
http://www.trig-avionics.com/library/TT2xBrochure.pdf
This link should take you to their website.
Old March 4th 11, 12:49 PM posted to rec.aviation.soaring
John Smith
Am 04.03.11 13:01, schrieb Nigel Cottrell:
The TT21 is a class 2 transponder and therefore *not* suited for
gliders. If you choose to go with Trig, then do yourself a favour and
buy the TT22.
Old March 4th 11, 01:51 PM posted to rec.aviation.soaring
kirk.stant
buy the TT22.
Please explain your reasoning for this statement. This seems to be a
minority view, at least in the US.
Cheers,
Kirk
66
Old March 4th 11, 02:46 PM posted to rec.aviation.soaring
Grider Pirate
buy the TT22.
Cheers,
Kirk
66
Class 2 is only 'legal' to 15,000 feet. The extra wattage of a class 1
is 'legally' required to fly above 15,000. Frankly it doesn't make any
sense to me. In my limited experience, the higher you are, the
greater the range of your RF device.
Old March 4th 11, 07:37 PM posted to rec.aviation.soaring
Darryl Ramm
buy the TT22.
The TT21 is very suitable for gliders. Its being installed in many
gliders in the USA and I expect elsewhere. The issue between class 1
and 2 transponders comes down to a fairly meaningless difference in
output power when you compare 15,000' vs. the maximum altitude we
typically fly at. If the difference in price between say a TT21 and
TT22 puts anybody off who should otherwise be installing a transponder
please install the TT21
Darryl
Transponder vs. Portable Transponder Detectors John Murphy Soaring 16 December 20th 08 07:25 AM
helo 1182 small - 1182 small.JPG (1/1) urbanwriter Aviation Photos 0 April 15th 07 09:06 PM
where to buy a small crank Charles McLaurin Soaring 1 May 12th 06 03:05 PM
Small Typo [email protected] Soaring 3 December 2nd 05 03:29 AM
Why are there no small turboprops? Thomas J. Paladino Jr. Piloting 59 June 8th 04 02:57 PM
