			#21
At 23:38 04 March 2011, Darryl Ramm wrote:
	Which manufacturer intends the ships's ASI to ever be connected to (or switchable) to a tail mounted pitot and/or static? The ASI should only be connected to the nose pitot and fuselage main static. A vario/ flight computer (like my C302) might be switchable between both (as it is in my motorglider). Darryl Schempp Hirth. My Discus only has fin pitot. Presumably this is so that the ASI still works when the nose hook is used for aerotow. (Not sure why knowing the speed on tow is important?) Kevin  |
On Mar 5, 3:01*am, BruceGreeff  wrote:
	AHEM - my T59D has a pitot on the tail fin - sharing space with the TE probe... That was way back in 1971 and is actually not that uncommon an arrangement.  |
On Mar 5, 4:33*am, Kevin Neave  wrote:
	At 23:38 04 March 2011, Darryl Ramm wrote: Which manufacturer intends the ships's ASI to ever be connected to (or switchable) to a tail mounted pitot and/or static? The ASI should only be connected to the nose pitot and fuselage main static. A vario/ flight computer (like my C302) might be switchable between both (as it is in my motorglider). Darryl Schempp Hirth. My Discus only has fin pitot. Presumably this is so that the ASI still works when the nose hook is used for aerotow. (Not sure why knowing the speed on tow is important?) Kevin I was talking about motorgliders. AFAIK Schempp-Hirth motorgliders have nose mounted pitots for the ASI and do not switch the ASI pitot source to a tail pitot. I've seen the ASI on some gliders like my old club's DG-1000S bouncing around a fair bit as we aerotowed at times with a wiffle ball on the tow rope (to protect the rope from abrasion damage). That tow operator liked to use a round wiffle ball followed by a half cut wiffle ball that could get a pretty good cup over the nose of the glider and the actual impact on the ASI would depend on how exactly that half cut ball sat on the nose. But since you are following a towplane this is less of a potential problem than would be using an ASI accidentally switched to a tail mounted pitot when self launching a motorglider (not that motorglider manufactures actally would intend anybody to do that, sigh.). Darryl  |
On Mar 4, 3:47*pm, Don Johnstone  wrote:
	Man who teach me to fly he say, "Never ever blow in pitot, altimeters are not designed to deal with being blown" Are you sure that's what he said? How would blowing into a pitot have any impact on the altimeter? Applying pressure to pitot tubes is a standard method of testing airspeed systems. You can buy quite expensive test equipment to do just that. The same test equipment will also vary the static port pressures although that's typically a suction. For comparison testing of airspeed indicators, such as a mechanical ASI and the Cambridge 302, one can either gently blow on the pitot and gently suck on the static while observing the instrument readings. If the mechanical ASI does not go off scale no harm can be done. Andy  |
| Thread Tools | |
| Display Modes | |
| Airspeed Indicator Strangeness | Frank[_1_] | Soaring | 6 | June 9th 08 02:24 PM |
| Airspeed Indicator problems | [email protected] | Soaring | 6 | June 19th 07 03:33 AM |
| verifying airspeed indicator | Heino & Deanne Weisberg | Home Built | 11 | October 22nd 05 08:36 PM |
| Need glider airspeed indicator | [email protected] | Soaring | 1 | June 21st 05 10:57 PM |
| Inaccurate airspeed indicator | Wyatt Emmerich | Instrument Flight Rules | 20 | April 20th 04 01:08 AM |
