Spot 2 problem
Old April 6th 11, 07:24 PM posted to rec.aviation.soaring
vontresc
Default Spot 2 problem
Hi, I was wondering if anyone else has had problems with their spot
unit not being able to get a GPS signal? Mine was working for about a
month, and now it no longer gets a GPS signal even though it can still
send a help message without location. The GPS light just blinks red
even if I'm outside in the open.
When I called support they were very quick to suggest I make a
warrantee claim to get a new unit, so that made me wonder if this is a
common problem.
Thanks
Pete
Old April 6th 11, 08:36 PM posted to rec.aviation.soaring
glidergeek
common problem.
Thanks
Pete
Look at this thread.
http://www.backcountrypilot.org/foru...=spot&start=20
Old April 7th 11, 01:08 AM posted to rec.aviation.soaring
Darryl Ramm
On Apr 6, 12:36*pm, glidergeek wrote:
On Apr 6, 11:24*am, vontresc wrote: Hi, I was wondering if anyone else has had problems with their spot
common problem.
Thanks
Pete
http://www.backcountrypilot.org/foru...3&t=7089&hilit....
OK I'll play this game. Why should he look at this thread?
0. The discussion on backcountry pilots is about a different product
made by a SPOT partner not the SPOT 2. While they share common
hardware I do not see anything in that thread relevant to the OP's
questions here.
1. The original post was about problems getting a GPS fix on the SPOT.
which you can tell by the LED status. The OP was very clearly not
complaining about the Globalstar data-uplink part of the device.
2. The backcountry pilot thread contains some unqualified/unexplained
comments about Globalstar satellite performance. The poor performance
of Globalstar satellite phones did (rightfully) trash their reputation
but this was due to early degradation in orbit of their S-band system
in the satellite that are used for the voice service. The SPOT simplex
data link operates on the L-Band using different hardware on the
satellites that is/was not affected by their S-band hardware problems.
3. While the posts on backcountry pilots may be genuine there have
been cases of one particular SPOT competitor spreading FUD about SPOT
products on pubic newsgroups and blogs (and I've helped track down
where they were coming from). So be just a little careful when people
criticizing SPOT (or any other) products without backing that up with
any facts or detail. I can pick lots of holes in SPOT and similar
other technology products, but the reality is this stuff works very
well in practice. And I suspect the main issue with SPOT, especially
for our uses, is users understanding a bit about how the technology
works, and especially for the need to obtain a pretty clear sky view
for the Globalstar satellite uplink.
To the OP. The GPS chipset in the SPOT 2 unit is pretty good
(technically better than SPOT 1, which was not bad) and should be able
to acquire and keep a fix in lots of situations. Is there something
weird about how you have the unit mounted? Best place is on the canopy
rail or glareshield. From your description I would return the unit to
SPOT for repair/replacement.
Darryl
Old April 7th 11, 02:39 AM posted to rec.aviation.soaring
Paul Remde
Hi Pete,
My SPOT 2 worked great even when strapped to my parachute harness (down low)
and pointing forward (not up).
I'm sure you've thought of this, but make sure the logo (front face) is
pointing up.
It does sound like a defective unit. I believe that SPOT will support you
well.
Best Regards,
Paul Remde
"vontresc" wrote in message
common problem.
Thanks
Pete
Old April 7th 11, 04:15 AM posted to rec.aviation.soaring
On Apr 6, 6:39*pm, "Paul Remde" wrote:
Hi Pete,
pointing up.
It does sound like a defective unit. *I believe that SPOT will support you
well.
Best Regards,
Paul Remde
common problem.
Thanks
Pete
I had mine replaced under warranty after having the same problem.
Service was expeditious and courteous. No complaints with the brand
new replacement unit.
Old April 7th 11, 04:41 AM posted to rec.aviation.soaring
vontresc
Hi Pete,
pointing up.
well.
Best Regards,
Paul Remde
common problem.
Thanks
Pete
Well that explains why the service rep was so quick to suggest a
warranty claim :-)
Pete
Old April 7th 11, 04:55 AM posted to rec.aviation.soaring
glidergeek
common problem.
Thanks
Pete
questions here.
comments about Globalstar satellite performance. *The poor performance
Darryl
Daryl
I was not playing a game only trying to be helpful eat ****.
Russ
Old April 7th 11, 05:10 AM posted to rec.aviation.soaring
Darryl Ramm
common problem.
Thanks
Pete
questions here.
Darryl
Daryl
Russ
You provided a link in reply to a pretty specific question being
asked. I and probalby others spent time reading the stuff you linked
to an trying to understand why. I tried to provide both accurate
information to the OP and clarify that nothing was relevant in the
stuff you linked to. "being helpful" is not linking to random stuff on
the web that has no relevance to the question being asked. Since you
want to throw around insults here. You either did not read what you
linked to or were not able to understand how unrelated it was to the
question being asked. Either way you look clueless. Trying to be
helpful maybe, but clueless.
Darryl
Old April 7th 11, 06:57 AM posted to rec.aviation.soaring
glidergeek
common problem.
Thanks
Pete
questions here.
1. The original post was about problems getting a GPS fix on the SPOT..
satellites that is/was not affected by their S-band hardware problems..
Darryl
Daryl
Russ
Darryl
Darryl
Your reply was arrogant, insulting and rude so, eat ****. As I stated
before I was trying to help. So you wasted your time reading a thread
you didn't invent your loss not mine. And so you continue to waste
more time reading this. "While they share common hardware I do not
see anything in that thread relevant to the OP's questions here".
Whether relevant or not my contribution was meant to enlighten not
attack anybody's intelligence such as yours (soaring community needs
more with attitudes such as yours). But seeing that's not the problem
with the OP's Spot he can eliminate that from his list of possible
problems with his Spot. You now must solve the problem with his Spot
or now you will be deemed to be clueless also.
Spot deal, today only, buy service get a free Spot Tim Taylor Soaring 3 December 1st 08 10:30 PM
SPOT on Tuno Soaring 0 May 15th 08 09:36 PM
See SPOT run... [email protected] Soaring 11 April 30th 08 08:57 PM
SPOT GPS jeplane Soaring 17 February 5th 08 05:23 AM
SPOT D.Rizzato General Aviation 0 February 5th 08 01:04 AM
