asw19 airbrake kit
Old April 7th 11, 05:31 PM posted to rec.aviation.soaring
steve[_2_]
Default asw19 airbrake kit
Hi all, sorry for my english.
I'm a new owner of an asw19b.
I ordered the TN11 kit to add the second blade to the airbrakes.
If i try to mount the blade of the kit with the supplied screws,
blades have an enormous play on the vertical axis because there ale a
pair mm between the blade and the threaded mount that attaches around
the arm of the airbrake.
Is possible to have some detailed photo of the kit installation.
Thanks
Stefano
Old April 7th 11, 07:19 PM posted to rec.aviation.soaring
mattm[_2_]
Thanks
Stefano
We went through this last year. It took a bit of head scratching to
get it all
to fit properly. Note that the two wings are mirror images of each
other
so it's possible to put things on wrong. Also, it's a good idea to
install
the fillet in the spoiler box before you try attaching the blade -- if
you don't
it's VERY easy for the blade to get caught under the lip and quite
difficult
to free it! Also, you may have to fabricate a connector for the blade
to
be bolted to the arms. This was shown on the plans but it wasn't in
my
part kit -- I'm not sure if they were there originally or not, but we
had
to make them from aluminum stock and flush rivet them to the blades.
When I get to the airport I'll try to get some photos of the completed
airbrakes, but I'm not sure when I'll get there.
-- Matt
Old April 7th 11, 08:32 PM posted to rec.aviation.soaring
GK[_2_]
Thanks
Stefano
Stefano,
I went trough similar problems last year. The bolts are too long
(cutting needed) and the supplied mounting brackets are extending too
far behind the original spoiler preventing them from closing. I
machined both: bolts and brackets. The mounting bolts HAVE TO BE RE-
THREATED all the way, leaving a couple millimeters for the spoiler
thickness. Schleicher supplied 4 bolts have all different threads
dimensions, when they all should have at least the same thread height.
Also, there should be some horizontal play in one of the holes
drilled in the spoiler, otherwise the bolt has no room to slide to the
side as the spoiler assembly is closing.
I'll try to take some pictures this weekend if I'll make it out to the
field. One thing for su the quality of these Schleicher retrofits
leaves a lot to be desired...This isn’t the first one I bought and
they all look like someone fabricated them in their garage after-
hours.
GK
Refinish and Repair ASW19 and Russia Jim Rizzo Soaring 3 November 30th 07 03:24 PM
Asw19 Winglets for sale Gregg Leslie Soaring 0 November 21st 06 02:31 PM
ASW19 performance mods Jim Crowhurst Soaring 2 June 3rd 05 12:18 PM
airbrake position while tied outside CK Soaring 18 January 19th 04 02:34 PM
airbrake question miso Military Aviation 17 December 4th 03 04:27 AM
