Software for glider pilots running on Ipad
Old April 12th 11, 11:50 PM posted to rec.aviation.soaring
Cliff Hilty[_4_]
Default Software for glider pilots running on Ipad
t 03:31 09 April 2011, Darryl Ramm wrote:
On Apr 8, 8:14=A0pm, Mike Schumann
On 4/8/2011 7:34 PM, Darryl Ramm wrote:
On Apr 8, 4:10 pm, jsbrake =A0wrote:
Its possible to root hack the Nook now and run Android 2.2 (and
mayb=
e
3.0) on it and should be able to install the current XCSoar
Android
software and see if it works. I believe there is supposed to be
an
official upgrade to Android 2.2 coming for the Nook which should
mak=
e
this easier. Anybody tried XCSoar on the Nook?
Perhaps a foolish question, but since the Nook Color doesn't have
a
GPS, how are you thinking of getting the GPS signal? =A0I found
that
there's an app called tetherGPS, but that uses an Android
smartphone
to transmit over wi-fi to the Nook. =A0Is there a way to feed the
GPS
directly into the nook from another GPS source? =A0Could it,
somehow,
be
connected to a PowerFLARM?
The Color Nook has Bluetooth hardware and enabling that and the
required SPP (serial over Bluetooth) is just a matter of software.
If
that support is not in the common Android 2.2 root hack then it
_may_
be in the official Android 2.2 update that is supposedly coming to
Color Nook. Once you have BT SSP support in the operating system the
rest should be easy. And ideally applications that know how to use
this (like XCSoar) should in principle just work. Once you have
Bluetooth you can go out to those low cost Bluetooth GPS receivers
or
via a Bluetooth adapter (like the K6-BT) to a PowerFLARM etc. Of
course my hand waving and seeing it all work are two different
things.
BTW another nook root hack resource for the color Nook is
http://nookdevs.com/Portal:NookColor
I just ordered a iPad 2 but the inner geek in me is thinking of
getting a Moto Xoom as well since I want to play more with Android.
Darryl
The Nook Color also has a USB interface, which might be another way to
connect the required GPS receiver.
Mike Schumann
The Color Nook as shipped is USB client only but it apparently has
chipset support for Bluetooth On-The-Go (i.e. client/host switching).
I don't think this is working yet with any of the root hacked Android
versions. But if the BT OTG support is really there then yes this is a
possibility. If its client only then it won't work. Still the first
step now would be for somebody to just try out XCSoar on Android 2.2
on this platform, you don't need a physical GPS to do a test.
Darryl
No inner geek here, but I did download XCsoar and custom map for my Droid
X which is running 2.2 Android and it seems to run fine. I haven't done
any flying with it yet (I have a SN10 in the glider) because I don't have
any way of mounting or powering it. The droid really eats batteries
CH
Old April 13th 11, 01:00 AM posted to rec.aviation.soaring
Tuno
Cliff:
I have a ram air turbine you can use to power your Droid. I'll put it
on your glider this weekend!
tuN7o
Old April 13th 11, 05:51 PM posted to rec.aviation.soaring
Cliff Hilty[_2_]
At 23:00 12 April 2011, Tuno wrote:
Cliff:
tuN7o
Not wanting to hijack the thread, but I want a small air turbine that will
fit into the scoop vent in the window that would supply charging power to
my batteries. As much 100+ knot flying and outside temps in the 100+ that
we have out here I could have a surplus and never need to charge my
batteries
How about it Bumper, Do I see a high tech Quiet Vent 6 out there?
CH
Old April 13th 11, 08:19 PM posted to rec.aviation.soaring
bildan
On Apr 13, 9:51*am, Cliff Hilty
Cliff:
tuN7o
batteries
CH
Better idea: Piezoelectric materials to generate power from wing
flexing or a Faraday device like this: http://peswiki.com/index.php/Directory:M2E_Power
Old April 13th 11, 08:22 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Cliff:
tuN7o
batteries
That's a silly idea, because it adds drag and would ruin the L/D;
instead, connect the generator to the rudder pedals. The way I fan my
rudder, that would run a radio, vario, GPS, ClearNav, transponder, MRX,
and more. :^]
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
Old April 13th 11, 08:42 PM posted to rec.aviation.soaring
Mike Schumann
Cliff:
tuN7o
will
batteries
and more. :^]
If you fanned the rudder hard enough, it could replace the need for an
auxiliary engine!
Mike Schumann
Old April 13th 11, 09:44 PM posted to rec.aviation.soaring
Cliff Hilty[_2_]
Cliff:
it
tuN7o
will
power
to
that
batteries
MRX,
and more. :^]
auxiliary engine!
Mike Schumann
Have you guys been watching me fly My nickname is salmon!
CH
Software for glider pilots running on Ipad nimbus Soaring 28 December 10th 13 07:26 PM
New software program for glider pilots Matt Herron Jr. Soaring 9 April 25th 10 11:14 PM
Q: Apple MAC Book (pro) with Intel core 2 duo running Windows XP plus soaring software Ruud Soaring 1 October 31st 06 02:02 AM
Glider Pilot Running for US President mm Soaring 95 March 5th 04 04:32 PM
Hey OZ, NZ, SA, Argentina Was: Glider Pilot Running for US President Vorsanger1 Soaring 1 February 20th 04 04:11 AM
