Arion Lightning, best Light Sport Plane on the market for cross country
Old April 24th 11, 02:09 PM posted to rec.aviation.piloting
Mark IV
Default Arion Lightning, best Light Sport Plane on the market for cross country
Arion Aircraft spent over 3 years making the kit Lightning as
efficient and fast as we could, so slowing down to 120knts was a
complete reversal of thinking that did have its benefits. By changing
the airfoil slightly and adding 3 feet of wing span the LS-1 stalls
below 44knts clean, giving this aircraft and impressive 50knt approach
speed for its class. Solo climb is in excess of 1500fpm while you can
expect 1200fpm at 1320lbs. Cruise speeds and fuel burns fall in the
120knts range at under 5gph respectively. These are real performance
numbers a pilot can rely on, not on a perfect day at sea level or
flying around solo but all loaded up!
A payload of up to 500lbs is available, and if equipped with 30
gallons can take you over 660nm with VFR reserves. When equipped with
standard tanks you can still reach out and touch some place 500nm away
with VFR reserves.
http://www.flylightning.net/
Mark IV
Old May 24th 11, 09:47 AM
SophiaEnman SophiaEnman is offline
Banned
First recorded activity by AviationBanter: Apr 2011
Send a message via ICQ to SophiaEnman
Prodam attribution pasteboard database - 130 000 lines in it, - mix countries - CA,US,DE,DENMARK,IT,UK,EST,LH,CZ, and other EU,+ TW,Thailand and other. Valid -5-30%.
Can show you wholly Side Viewer, can wor auspices of Garant (escrow). Minimum decree 5000 lines - fee - 0,07$ per line. if structure more than 10k lines then 0,05$ per line.
All derive 130000 cc - 10000$ . Contacts email: skype:ccseller icq:603948540
Prodam credit card database - 130 000 lines in it, - mix countries - CA,US,DE,DENMARK,IT,UK,EST,LH,CZ, and other EU,+ TW,Thailand and other. Valid -5-30%.
Can show you through Team Viewer, can wor through Garant (escrow). Minimum order 5000 lines - price - 0,07$ per line. if order more than 10k lines then 0,05$ per line.
All base 130000 cc - 10000$ . Contacts email -
Light Sport Aircraft as Tow Plane [email protected] Soaring 8 February 20th 08 11:31 AM
Arion Lightning? [email protected] Home Built 0 May 8th 06 07:08 PM
New discussion forum for Sport Pilots and Light Sport Aircraft [email protected] Piloting 6 February 25th 06 06:51 PM
New discussion forum for Sport Pilots and Light Sport Aircraft [email protected] Owning 0 February 9th 06 07:16 PM
Light-Sport Aircraft / Sport Pilot group gilan Piloting 0 November 13th 05 04:53 PM
