My Soaring Blog
Old May 6th 11, 04:19 AM posted to rec.aviation.soaring
Reed von Gal
Default My Soaring Blog
Hey everyone,
I just started my soaring blog on the SSA website. I am learning to
fly cross country out of Boulder, CO with the SSB, and will use this
space to talk about my adventures, flights, and what I've been
learning. I will be flying at Region 9 with our contest mentor
program, and a lot of the content will have to do with this as well.
Take care,
Reed
Old May 6th 11, 03:09 PM posted to rec.aviation.soaring
Grider Pirate
On May 5, 8:19*pm, Reed von Gal wrote:
Hey everyone,
Take care,
Reed
Out of curiousity, I went to the SSA website and used the member
locator to find your 'home page'. The blog reports "No current
Ariticles"
Old May 8th 11, 03:10 AM posted to rec.aviation.soaring
Reed von Gal
Hey everyone,
Take care,
Reed
locator to find your 'home page'. *The blog reports "No current
Ariticles"
Should be there. Just had a look and found it no problem.
Old May 8th 11, 05:53 AM posted to rec.aviation.soaring
Frank Whiteley
Hey everyone,
Take care,
Reed
Ariticles"
Reed, et al,
If you have posted something to your blog, you probably have left the
draft box checked at the bottom of the composition window. It's
checked by default. This gives the blogger a chance to proof it before
posting online. Go back and edit your post and uncheck the draft box
before saving. Then it will be shared.
Frank Whiteley
Old May 8th 11, 03:02 PM posted to rec.aviation.soaring
William Elliott
On May 5, 10:19*pm, Reed von Gal wrote:
Hey everyone,
Take care,
Reed
Please consider adding some of your stories to the Soaring Cafe at
www.SoaringCafe.com.
Old May 10th 11, 06:39 AM posted to rec.aviation.soaring
Reed von Gal
Hey everyone,
Take care,
Reed
Please consider adding some of your stories to the Soaring Cafe atwww.SoaringCafe.com.
Gentlemen,
Problem is now fixed. Kind of a tricky spot to put that draft button.
Once things get going I will definitely post on the Cafe. Great site!
Reed
Old May 10th 11, 03:21 PM posted to rec.aviation.soaring
Grider Pirate
Hey everyone,
Take care,
Reed
Gentlemen,
Reed
Hello Reed,
I left a 'comment' on your Blog, mostly just to ops check that
function. I still had to use the member locator to find your blog.
I'm not sure how the blogs make their way to the 'Member Blogs' page,
but it is apparently not instant or automatic.
Old May 10th 11, 03:27 PM posted to rec.aviation.soaring
Tony[_5_]
Hey everyone,
program, and a lot of the content will have to do with this as well..
Take care,
Reed
Please consider adding some of your stories to the Soaring Cafe atwww..SoaringCafe.com.
Gentlemen,
Reed
Hello Reed,
* I left a 'comment' on your Blog, mostly just to ops check that
function. *I still had to use the member locator to find your blog.
worked for me to go to News and Information and then Member Blogs on
the ssa.org home page
Old May 10th 11, 04:04 PM posted to rec.aviation.soaring
Grider Pirate
Hey everyone,
Take care,
Reed
Gentlemen,
Reed
Hello Reed,
the ssa.org home page- Hide quoted text -
- Show quoted text -
Interestingly, I did that first, and didn't find Reed's blog. Then I
navigated to his page via the member locator, left a comment on his
blog, then exited. A few minutes later I revisited the SSA.org site,
went to News and Information, then member blogs, and there it was!
Magic.
Old May 10th 11, 07:49 PM posted to rec.aviation.soaring
Frank Whiteley
Hey everyone,
Take care,
Reed
Gentlemen,
Dave's Blog on Promoting Soaring by Exhibiting and Flying at OshkoshAirVenture 2009 Dave Nadler Soaring 0 October 10th 09 09:58 PM
new blog ahm Aviation Marketplace 0 August 2nd 08 06:30 PM
new blog ahm Simulators 0 August 2nd 08 06:29 PM
new blog ahm General Aviation 1 July 31st 08 11:48 AM
ADV: Roger's Soaring Blog Roger Worden Soaring 3 April 8th 08 03:51 AM
