#11
![]() "The CO" wrote in message ... "Tarver Engineering" wrote in message ... "Emmanuel.Gustin" wrote in message ... Stephen Harding wrote: Wasn't the rover about to attack 'an interesting geological feature' when it failed? So it would be legitimate self-defence, or at worst a legitimate pre-emptive strike... A much more likely source of failure is the lack of EEs at NASA, as outlined in the Shuttle crash investigation board report. Until the areo mafia is rooted out of NASA, there can be no forward movement. Aero's havn't controlled a successful aerospace company since the 1970s, as it has been all EE since then. Actually, it now appears highly likely that it's a problem with the FLASH memory management software module. Perhaps. The FLASH hardware is apparently ok. In short, it appears to be either a bug or something corrupted it, such as a high energy particle impact. I know that JPL would lie, so I can't put much stock into what they say. There is an identical module on Mars now and in a week you right be able to make such a case. Right now, any such "cause" is unknowable. I will give JPL credit for creating something that works at all, which is something that has been problematic at NASA for some time. |
In article , "The CO"
wrote: "Tarver Engineering" wrote in message ... "Emmanuel.Gustin" wrote in message ... Stephen Harding wrote: Wasn't the rover about to attack 'an interesting geological feature' when it failed? So it would be legitimate self-defence, or at worst a legitimate pre-emptive strike... A much more likely source of failure is the lack of EEs at NASA, as outlined in the Shuttle crash investigation board report. Until the areo mafia is rooted out of NASA, there can be no forward movement. Aero's havn't controlled a successful aerospace company since the 1970s, as it has been all EE since then. Not all EEs. Hughes Aircraft had an ME at the helm for a good while. Actually, it now appears highly likely that it's a problem with the FLASH memory management software module. The FLASH hardware is apparently ok. In short, it appears to be either a bug or something corrupted it, such as a high energy particle impact. Some EE apparently didn't put in EDAC. -- Harry Andreas Engineering raconteur |
![]() "Tarver Engineering" wrote in message ... "The CO" wrote in message ... "Tarver Engineering" wrote in message ... "The CO" wrote in message ... Actually, it now appears highly likely that it's a problem with the FLASH memory management software module. Perhaps. snip Today the claim is a "file management" problem, which seems likely. Yes, the software that manages it is the suspect, as they stated previously. The flash memory controller is being reported as being software Yes. That's probably not the ideal way to do that, possibly they were considering the likelihood of an unrecoverable hardware failure due to rad or thermal impact as more likely than using software for the task. It's probably that the software can be debugged or a new version uploaded from here, even now, however changing out a dodgy card would not be possible. and this would not be the first time some softhead grabbed up all the memory themselve, so that their program alone would run better. I get the impression it's an actual bug that has arisen due to something that was not tested for rather than a memory or cycle hog. It would net be the first time such a thing has happened and a goo reason why memory management units are usually hardware. Well, it's certainly one reason. Politics, funding and the need to protect certain people, are the standard reasons why Governemnt Agencies lie. No doubt, but I was under the impression you had some specific reason to be suspicious. They do seem to be being quite candid at the moment. Were you perhaps being a little over critical based on your perception? Software and hardware both seem to be faulty. Software seems to be the very high probability candidate. I've heard nothing more about the teams investigating a possible hardware anomaly (on the motor board) and this seems less and less likely to be the case as time goes on. It is an age old mistake of developers to use the interupt that halts the processor and there was a scientist on TV making the claim that the processor was being interupted, right before the 138 reboots. Quite so, but the interrupt is being software driven. The type of error you describe would be rather unlikely given the amount of development. I suspect it's rather more obscure than that, I get the feeling this is more likely to be something that only occurs during heavy memory workloads. snip Right now JPL is hacking the system and deleting old files and no longer necessary software and perhaps the robot will come back. I think it's a little more involved than that. snip All we can really know is that the machine is suffering from memory starvation right now. Some how there is a leak, much like what happens to a PC under Windows. Doesn't seem to be a simple memory leak. If I may use a *very* crude analogy, it looks to bear some resemblance to the issue that arises with DOS when the root directory has it's maximum of 255 entries. I respectfully suggest therefore that your statement is indicative of strong personal bias not based on realistic knowledge of the onboard computer system. How much do you actually know about the effects of ionised particles/he protons on computer memory, specifically, FLASH, or memory diagnostic routines in VxWorks RTOS environments running on a 20Mhz RAD6000 hardened version of the PowerPC chip? Quite a bit. Ok. I'll be interested to see the end result of the rover recovery efforts. I was mistaken is claiming the two landers are identical, as the second robot has some chips that are a generation newer than the broken bot. Not aware of that. Thank you. Interesting. snip JPL's track record may not be perfect, but I suspect that they are well in front of whoever is in second place. (Russia?) As was pointed out to the Queen at the completion of the first America's cup: "there is no second place" LOL. I can agree with that. The US has to go back to the Moon for strategic reasons, Strategic? What can you do from the moon that you can't do from LEO (in the military sense)? otherwise the Chinese will gain a military advantage within a few years. Hmm, seems unlikely that it would be either significant or any real advantage. They are very much playing catch-up ball here. Mars is a dead planet That is yet to be scientifically demonstrated. Make it 'likely to be a dead planet' and I might agree. and probably is not going to be of much interest. Sorry, can't agree. I'd like to see JPL send a robot to one of the Moons of Jupiter ISTR there is a mission of that kind planned. instead of sending a man to Mars. How about 'as well as'. The CO |
![]() "The CO" wrote in message ... I was mistaken is claiming the two landers are identical, as the second robot has some chips that are a generation newer than the broken bot. Not aware of that. Thank you. Interesting. Today JPL validated what I wrote yesturday and they now expect to be able to have the broken robot completely functional, in a few days. If JPL does that, I say they are pretty smart. |
"Harry Andreas" wrote in message ... In article , "The CO" wrote: "Tarver Engineering" wrote in message ... "Emmanuel.Gustin" wrote in message ... Stephen Harding wrote: Wasn't the rover about to attack 'an interesting geological feature' when it failed? So it would be legitimate self-defence, or at worst a legitimate pre-emptive strike... A much more likely source of failure is the lack of EEs at NASA, as outlined in the Shuttle crash investigation board report. Until the areo mafia is rooted out of NASA, there can be no forward movement. Aero's havn't controlled a successful aerospace company since the 1970s, as it has been all EE since then. Not all EEs. Hughes Aircraft had an ME at the helm for a good while. My mistake, you are quite correct. In fact, most MEs can work complex numbers; while an Aero with a BSAE will be lost. I had an aero come up to me at Dryden and speak with fascination at the huge difficulty he had applying complex numbers. From the way he described it, I don't believe he had ever seen a number written with a "j". before his masters level work. Actually, it now appears highly likely that it's a problem with the FLASH memory management software module. The FLASH hardware is apparently ok. In short, it appears to be either a bug or something corrupted it, such as a high energy particle impact. Some EE apparently didn't put in EDAC. From the story today it apears JPL used a software MMU. That would make the most likely cause of the problem some softhead that couldn't get their program to run without hogging memory. It is a story repeated again and again in industry. It is nice to see you posting, Harry. I have been programming vxWorks for 12 years. There is a basic mmu that comes with and another that is more traditional that keeps tasks from clobbering each other. But from the press release, it sounds like to me exactly the same problem I complained to Wind River 10 years ago: That all the directory entries are cached in regular dram memory (on bootup, it rereads all the directory entries into memory). I believe it was something like 64 bytes per entry. So when a customer of mine logged 20000 data files, his system ran out of regular memory because I didn't factor in this possibility. I think I heard they had to delete 10s of thousands of files - probably freeing a few precious megs of memory. |
OT (sorta): Bush Will Announce New Space Missions | Dav1936531 | Military Aviation | 0 | January 9th 04 10:34 AM |
Israeli Air Force to lose Middle East Air Superiority Capability to the Saudis in the near future | Jack White | Military Aviation | 71 | September 21st 03 02:58 PM |
Baker Co, US Infantry shot from helicopter | Dan Ross | Military Aviation | 0 | September 19th 03 07:28 PM |
