IS-29
Old May 17th 11, 05:53 PM posted to rec.aviation.soaring
Jim[_18_]
Default IS-29
I have a friend looking at rebuilding an IS-29 lark.
Are parts available? Does it have a life limit like the 28?
Thanks,
Old May 17th 11, 06:39 PM posted to rec.aviation.soaring
ray conlon
Default IS-29
Thanks,
The factory IAR Brosov had a web page...there is a guy in Canada who
has a very low time one that suffered wind damage in a storm that's
almost new...Parts? I had his email somewhere I will look for it.
Old May 17th 11, 06:47 PM posted to rec.aviation.soaring
kirk.stant
Default IS-29
Thanks,
Not sure if parts are available (though Blanik parts may fit in some
cases) but it definitely has a life limit, and a factory approved
inspection method for life extension.
Kirk
Old May 17th 11, 07:05 PM posted to rec.aviation.soaring
Tony[_5_]
Default IS-29
Thanks,
Kirk
really? i found a pdf of the flight and maintenance manual online as
well as the faa type certificate and didn't see anything about a life
limit. there are no AD's against the IS-29 that I can find in the FAA
database.
Old May 17th 11, 08:49 PM posted to rec.aviation.soaring
ray conlon
Default IS-29
Thanks,
email: addresses
Howard Allmon used to be the Lark importer:
Old May 17th 11, 10:15 PM posted to rec.aviation.soaring
T[_2_]
Default IS-29
Thanks,
Kirk
limit. *there are no AD's against the IS-29 that I can find in the FAA
database.
I looked at the TCDS for both the -28 and -29 and neither mentioned
life limits. I found a POH for the single seat Lark and it did not
mention life limits.
Old May 17th 11, 10:22 PM posted to rec.aviation.soaring
Tony[_5_]
Default IS-29
Thanks,
Kirk
database.
i've never been able to find definitive documentation (besides RAS
posts) online proving that life limits exist in the USA. Although my
CFIG owned a IS28B2 Lark when I was training and did a life extension
on it so I assume it is in fact somehow required.
Old May 17th 11, 11:46 PM posted to rec.aviation.soaring
T[_2_]
Default IS-29
Thanks,
Kirk
database.
There was a 2 seat Lark in the club when I first joined. I remember a
30yr calendar life limit that was extended with factory approved
inspection and replacement of some life limit (time) parts like
control pushrods.
Old May 18th 11, 02:28 AM posted to rec.aviation.soaring
Jim[_18_]
Default IS-29
database.
Thanks for the comments, do you have a link to the online manuals?
I owned an IS-28 years ago when the life limit issue became a big deal
but don’t remember anything being said about the 29.
Has anybody that’s flown one want to comment on flying qualities?
Thanks,
Old May 18th 11, 03:13 AM posted to rec.aviation.soaring
Tony[_5_]
Default IS-29
database.
Thanks,
http://www.tbss.us/txfiles/POH%20Bra...9D2%20Lark.pdf
