#21
On May 17, 5:37*pm, sisu1a wrote:
Meanwhile, our Duo trailer has had two of these bolts fail in the last week; one of my partners just showed up and left a broken bolt on my desk. Has anyone used NAS shear bolts as replacements? They're designed for close fit, and have ~160-180,000psi in tensile and ~95,000psi in shear (+CAD II plating...) *'normal' bolts are as low as around 50,000psi in tensile and not even rated in shear. http://www.aircraftspruce.com/pdf/20...l/Cat11065.pdf -paul Interesting. I have a 2002 Cobra trailer. Will have to check the bolts. Probably should replace them. Not having the trailer nearby to go and look at the relevant areas discussed above and not being that familiar with it, it is somewhat hard to visualize and follow the discussion. Anyone care to post a step by step "Replacing Cobra Hinge Plate Bolts for Dummies" with specifics as to what type of clamp(s) and where to put it(them), bolt specs, etc? Pictures would be a great help. It would be greatly appreciated. Thanks for the information posted thus far! WD |
On 5/17/2011 11:38 AM, Andy wrote:
I checked my bolts for security last year after YO's report. Don't remember how much I tightened them, it at all, but the damage was probably already done. I think the only safe action is to replace the bolts. Given Howard's confirmation of fatigue failure I wonder how much wash boarded dirt roads are a factor. Is this just a Western US hazard? I didn't even know what a wash board road was until I moved here. Washboarded roads - maybe. Here's another data point: 1995 Cobra trailer for ASH 26 E, 160,000 miles of highway driving, and the bolts are not broken. Some details: *note that the ASH 26 E trailer body is 30 feet long, as the 18 meter wing is only two pieces (tongue is another 4 feet) *towed almost entirely by motorhomes *I haven't actually pulled out the bolts to see if they are cracked *Probably less than 1000 miles of dirt roads, including mostly roads under repair or construction, and hardly any washboarded roads. I will replace the bolts as soon as people settle on the best kind of bolt. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
I have 3 Wing Riggers that I need to get shipped out today, but as
soon as I get a chance I intend to investigate changing the bolts to the next larger size, 3/8" grade 8. Of course that will mean drilling the holes larger and it will also mean that the head will not be neatly counterbored into the handle. If that plan works out, I will post back here. GW |
#24
On May 18, 9:44*am, Steve Koerner wrote:
I have 3 Wing Riggers that I need to get shipped out today, but as soon as I get a chance I intend to investigate changing the bolts to the next larger size, 3/8" grade 8. *Of course that will mean drilling the holes larger and it will also mean that the head will not be neatly counterbored into the handle. *If that plan works out, I will post back here. GW I'd be interested to hear how that works out. There is a least one spacer block inside the frame extrusion and it looks like it would have to be extracted, drilled, and replaced. There may be two each side. Given the limit access to the extrusion opening it could be a bit awkward to work the inner blocks. If I was going to larger bolts I think I'd relocate the handles and keep them on 5/16 socket cap bolts. They wouldn't need the spacer blocks as long as a moderate torque was used. Andy (GY) |
#25
On May 18, 11:44*am, Steve Koerner wrote:
I have 3 Wing Riggers that I need to get shipped out today, but as soon as I get a chance I intend to investigate changing the bolts to the next larger size, 3/8" grade 8. *Of course that will mean drilling the holes larger and it will also mean that the head will not be neatly counterbored into the handle. *If that plan works out, I will post back here. GW Why not use the proper metric size? Peter |
#26
On May 18, 11:43*am, vontresc wrote:
On May 18, 11:44*am, Steve Koerner wrote: I have 3 Wing Riggers that I need to get shipped out today, but as soon as I get a chance I intend to investigate changing the bolts to the next larger size, 3/8" grade 8. *Of course that will mean drilling the holes larger and it will also mean that the head will not be neatly counterbored into the handle. *If that plan works out, I will post back here. GW Why not use the proper metric size? Peter Because they break. GW |
#27
Hi Guys - Spindelberger is looking into this.
It would greatly assist if you could: 1) Take close-up photographs of broken bolt ends and email them to me. 2) Send me the broken bolts (which I will forward on to Spindelberger): Dave Nadler 97 Central Street Acton, MA 01720 3) Somebody go help JJ get a picture of the rivets he replaced and email them to me... Thanks ! Best Regards, Dave PS: I'm on the road so a bit hard to reach. Going to PA for a few days, where no doubt it will rain as they've gone and called another contest... |
#28
If this problem is primarily affecting Cobra trailers with fiberglass
tops, rather than aluminum, I wonder if the difference in thermal coefficient of expansion between the two materials might be playing a roll? On early Stemme S10-VT motorgliders, the spoiler control rods were aluminum in an otherwise mostly carbon fiber wing. The spoiler over- center locks were at the fuselage end. As the temperature dropped with altitude, the spoilers would first start to come open and then sometimes even open all the way with no pilot input. Problem was solved by changing the control rods to carbon fiber. bumper zz Minden |
#29
On May 21, 6:25*pm, bumper wrote:
If this problem is primarily affecting Cobra trailers with fiberglass tops, rather than aluminum, I wonder if the difference in thermal coefficient of expansion between the two materials might be playing a roll? On early Stemme S10-VT motorgliders, the spoiler control rods were aluminum in an otherwise mostly carbon fiber wing. The spoiler over- center locks were at the fuselage end. As the temperature dropped with altitude, the spoilers would first start to come open and then sometimes even open all the way with no pilot input. Problem was solved by changing the control rods to carbon fiber. bumper zz Minden Bumper might be on to something. Polyester reinforced with glass fiber has a linear coefficient of thermal expansion of 25 (10^-6 m/m K) while structural steel is just 13. Aluminum is 22.2 which is close enough to steel there may not be a problem. Ref: http://www.engineeringtoolbox.com/li...ents-d_95.html The fiberglass top is, of course, exposed to the direct sunlight while the steel trailer frame stays mostly in the shade. Bill D |
#30
I have an older (early 1992) Cobra with a fiberglass top. I haven't
spent the past 19 years on the road but the trailer doesn't live in a hangar, either. I just checked visually and all four bolts are intact and tight, the hinge plate is tight up against the aluminum cross member, and there is no sign of movement or looseness or distortion anywhere. I'll remove the bolts one by one to inspect but I'm wondering, as at least one other person did, if the cause was simply a bad batch of bolts, or perhaps improper tightening at the time of manufacture. For sure, once there's looseness anywhere in the bolted system, the likelihood of failure rises significantly. Chip Bearden ASW 24 "JB" USA |
Cobra Trailer Spare Tire mount failure | Barny | Soaring | 29 | July 23rd 15 12:52 AM |
Cobra bottle jack failure | db_sonic | Soaring | 15 | October 30th 09 03:34 PM |
cobra trailer brake lever gas strut failure? | Frank[_1_] | Soaring | 11 | March 31st 09 08:59 PM |
Hanger Queen meets Cobra - Cobra Girl 07.jpg (1/1) | Alan Erskine[_3_] | Aviation Photos | 9 | September 20th 08 04:35 PM |
Hanger Queen meets Cobra - Cobra Girl 05.jpg (1/1) | Glenn[_2_] | Aviation Photos | 0 | September 19th 08 03:41 PM |
