Cobra top hinge plate bolt failure
Old May 23rd 11, 06:39 PM posted to rec.aviation.soaring
Ian Reekie
Default Cobra top hinge plate bolt failure
Interesting, I took a couple of pictures of the hinge and they seem to show
no structural connection from the side rails to my cross member ?
I am flying tomorrow so I will examine this further, but I wonder if they
varied the construction. Many of my aluminium support brackets are glued
to the shell with what looks like a black polyurethane glue, similar to
that used in the car industry to glue panels. I assumed this was the case
for this cross member.
I agree that It would be ideal to change one bolt at a time, but I was
thinking of implement Steve Koerners mod which I believe would require you
to remove both bolts to get the 1/4" spacer under the handle ?
It is riveted to the top side rails. However one US owner has found
all rivets sheared. All mine seem ok.
In any event you should only change one bolt at a time!
Andy
  #42
Ian Reekie
Andy
  #43
Old May 23rd 11, 07:24 PM posted to rec.aviation.soaring
Andy[_1_]
varied the construction. *Many of my aluminium support brackets are glued
that used in the car industry to glue panels. *I assumed this was the case
Andy- Hide quoted text -
- Show quoted text -
Mine also has the black glue. Email me and I'll send you a photo that
shows the rivet locations.
It should be easy to change one bolt at a time even when introducing
the new plate. Just leave the first new bolt slightly loose so the
plate can be rotated into alignment after the second bolt is removed.
Even if you decide to remove the handle to work on it you can still
put bolts in place to maintain the alignment.
Having dealt with this issue once I would go to great length to ensure
that both bolts were never removed at the same time.
If you want all the bolts out then raising the top, disconnecting the
gas struts, and then doing all the hinge work with the top closed may
be the way to go. You'll need several strong friends or an overhead
hoist though.
Andy
  #44
Old May 24th 11, 03:41 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
On 5/22/2011 7:54 PM, MKoerner wrote:
Like Eric’s, my trailer has “bridged” its way around the west, at
least until I got bigger tires and wheels (Eric, get bigger tires and
wheels).
That would make the rear of the trailer too high for convenient rigging
with the trailer attached, something I commonly do when traveling with
the motorhome (the trailer's primary motive force). Removing it to rig
is a nuisance, especially since I need to reconnect it after rigging, so
my wife can retrieve or follow me, as needed.
A Cobra trailer dealer told me they are designed to be supported
entirely by the tail and the tongue without damage, so I don't think the
bridging causes the trailer any problems. I do have to replace the
aluminum tail skids every 100,000 miles.
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
- "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what
you need to know tinyurl.com/yfs7tnz
Cobra Trailer Spare Tire mount failure Barny Soaring 29 July 23rd 15 12:52 AM
Cobra bottle jack failure db_sonic Soaring 15 October 30th 09 03:34 PM
cobra trailer brake lever gas strut failure? Frank[_1_] Soaring 11 March 31st 09 08:59 PM
Hanger Queen meets Cobra - Cobra Girl 07.jpg (1/1) Alan Erskine[_3_] Aviation Photos 9 September 20th 08 04:35 PM
Hanger Queen meets Cobra - Cobra Girl 05.jpg (1/1) Glenn[_2_] Aviation Photos 0 September 19th 08 03:41 PM
