I just noticed this posted on the SSA homepage ... strangely quietly I
might add ... New Transponder Code (1202) for Gliders SSA has received information of a new transponder code for gliders. Gliders not in contact with an ATC facility should squawk 1202 in lieu of 1200. This proposed change will be effective February 9, 2012. Posted: 5/20/2011 |
On May 23, 2:06*pm, CLewis95 wrote:
I just noticed this posted on the SSA homepage ... strangely quietly I might add ... New Transponder Code (1202) for Gliders SSA has received information of a new transponder code for gliders. Gliders not in contact with an ATC facility should squawk 1202 in lieu of 1200. This proposed change will be effective February 9, 2012. Posted: 5/20/2011 So what happened to 1201? Inflation? Mike |
On May 23, 5:06*pm, CLewis95 wrote:
I just noticed this posted on the SSA homepage ... strangely quietly I might add ... New Transponder Code (1202) for Gliders SSA has received information of a new transponder code for gliders. Gliders not in contact with an ATC facility should squawk 1202 in lieu of 1200. This proposed change will be effective February 9, 2012. Posted: 5/20/2011 The FAA Joint Order that describes transponder code allocations has 1201 for gliders not in touch with ATC. What happened to that!!! We've been working all winter to get our local TRACON to recognize 1201and now it changes?? WTFO!! T |
1201, 1202, 0440...
It would be interesting to see a map of the country that displayed where these codes have been accepted. Jim |
On May 23, 5:56*pm, JS wrote:
1201, 1202, 0440... * It would be interesting to see a map of the country that displayed where these codes have been accepted. Jim We use 0400 in Tucson. Mike |
On May 23, 7:06*pm, Mike the Strike wrote:
On May 23, 5:56*pm, JS wrote: 1201, 1202, 0440... * It would be interesting to see a map of the country that displayed where these codes have been accepted. Jim We use 0400 in Tucson. Mike 1201 in the Denver area. We have an LOA with the local ARTCC |
JO 7110.66D is the current iteration of FAA orders on transponder codes which was sent out to all air traffic facilities - that is when the folks at the puzzle palace can remember to send them out (which is what did not happen when the above mentioned order was originally generated.) Those towers and centers which did not already have a letter of agreement with local glider operators in place were more often than not confused when asked by local glider pilots about the change in beacon codes specifically for gliders because they had not yet received their copy of JO 7110.66D or they had not read it and gotten the information out to the controllers at the radar positions. IF, and that's a big IF, the folks at Independence Ave. do their job correctly, ATC facilities will continue to adhere to the current order (JO 7110.66D) until such time as it is up dated with JO 7110.66E. So, let's not muddy the waters by getting out information to the unwashed masses (read glider pilots) about changes in squawk codes until such time as the Feds say the order has been changed. I hope that doesn't make too much sense. Bill Hill |
On May 23, 11:56*pm, zulu wrote:
JO 7110.66D is the current iteration of FAA orders on transponder codes which was sent out to all air traffic facilities - *that is when the folks at the puzzle palace can remember to send them out (which is what did not happen when the above mentioned order was originally generated.) Those towers and centers which did not already have a letter of agreement with local glider operators in place were more often than not confused when asked by local glider pilots about the change in beacon codes specifically for gliders because they had not yet received their copy of JO 7110.66D or they had not read it and gotten the information out to the controllers at the radar positions. IF, and that's a big IF, the folks at Independence Ave. do their job correctly, ATC facilities will continue to adhere to the current order (JO 7110.66D) until such time as it is up dated with JO 7110.66E. So, let's not muddy the waters by getting out information to the unwashed masses (read glider pilots) about changes in squawk codes until such time as the Feds say the order has been changed. I hope that doesn't make too much sense. Bill Hill My point exactly, JO 7110.66D has been published since Nov 2009 and they have not gotten the word out. So based on SSA reporting an effective date of Feb 2012, that would be the publication date of Ver E? And it's right after the SSA Convention in Reno NV? My thanks to our SSA leadership for pushing this through. Knowing it was going to change from 1201 to 1202 would have been nice to know for those working with the local TRACONs to get something for this soaring season, which SSA suggested we do. Trust me, when you are working with the FAA, the waters are already muddy, it's not the unwashed masses of glider pilots. (former ATC'r) T |
One issue that hasn't been discussed much is what happens when a
glider flies cross-country between different TRACON jurisdictions. We have three possibilities in Arizona - 0400 (Tucson) 1200 (Phoenix) and 1201 (New Mexico and some other surrounding locations). I have flown in all three with my home 0400 code and no-one appears to have noticed. I suspect if you chose any random 4-digit number, no-one would notice either. It's definitely time for some uniformity, at least if anyone is watching! Mike |
On May 24, 9:44*am, Mike the Strike wrote:
One issue that hasn't been discussed much is what happens when a glider flies cross-country between different TRACON jurisdictions. *We have three possibilities in Arizona - 0400 (Tucson) 1200 (Phoenix) and 1201 (New Mexico and some other surrounding locations). *I have flown in all three with my home 0400 code and no-one appears to have noticed. I suspect if you chose any random 4-digit number, no-one would notice either. It's definitely time for some uniformity, at least if anyone is watching! Mike Do they not notice because you are not talking to them to find out? Hence the reason for a national code. 04xx series codes are for TRACONs to use locally with no impact to the national system. Picking a random 4 digit code, you might pick the same code assigned to IFR traffic in the local area and his tracking data block could get attached to your radar plot and that would not be good for the other aircraft or ATC. Joshua Approach, Edwards AFB and China Lake NAS, had problems with the 0440 codes flying south from Reno into their airspace and to Joshua, 0440 meant something else. T |
| Thread Tools | |
| Display Modes | |
| Aussie pilots looking for gliders to hire or swap for the Pre-Worlds2011 & WGC 2012 | gliderpilots | Soaring | 0 | March 19th 11 03:20 AM |
| Transponder squawk code 1201 approved for ZDV | Frank Whiteley | Soaring | 0 | June 7th 10 09:00 PM |
| A national glider transponder code? Not so fast!! | Phil Umphres | Soaring | 1 | April 7th 10 02:21 PM |
| Transponder code switching | Ken Pruchnick | Instrument Flight Rules | 30 | October 12th 03 09:31 PM |
| Transponder code switching | Sven | Piloting | 7 | October 7th 03 06:02 PM |
