Anyone used FlywithCE?
Old June 6th 11, 12:37 AM posted to rec.aviation.soaring
smithcorp
Default Anyone used FlywithCE?
On Jun 6, 2:54*am, Rob Shepherd wrote:
Evening all,
Has anyone used one of the FlywithCE devices, comments on ease of use,
accuracy, battery duration would be much appreciated.
Cheers
Rob
I use one. Simply turn it on, check it's got a green light (the "on"
light is small and can be difficult to see in sunlight) and then pop
it in my top pocket. Download is easy by USB cable and easy to export
to SeeYou, or onto Google maps plot. Can't comment on battery life
beyond saying i have had problems using rechargeables, finding the
batteries flat just when I want to use them (but that's not the fault
of the device - i always take them out at the end of the day) - I
think I need better rechargeables. I now use good quality triple-A
batteries and haven't had further troubles.
In terms of accuracy, I was testing an Android app on my Galaxy Tab
(Gaggle) and the plots from Gaggle and FlyCE were consistent. Neat
little device - other GPS devices may offer lots more, but at my stage
of flying I just wanted a logger.
smith
Old June 6th 11, 01:26 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Default Anyone used FlywithCE? (slight digression)
On Sun, 05 Jun 2011 15:37:40 -0700, smithcorp wrote:
Can't comment on battery life beyond
saying i have had problems using rechargeables, finding the batteries
flat just when I want to use them (but that's not the fault of the
device - i always take them out at the end of the day) - I think I need
In my experience almost all the rechargeables currently on the market are
garbage. I'm referring to the NiMH AA cells that claim anything up to
2800 mAh. I have a battery charger/recycler that records capacity and
have to sat that, after buying several sets of these batteries (my Pentax
DSLR uses AA cells) from various outlets and several makes:
- there is no correlation between price and performance. In fact the most
expensive set was the worst on terms of capacity
- Not one of the consumer grade sets I bought would hold more than
900 mAh despite claiming anything between 2400 and 2800 mAh.
The worst case I found was a set that claimed 2800 mAh and actually
held 400 mAh
The best I've found are the Sanyo Eneloops, followed by Maplins Hybrids,
which AFAIK are only available in the UK. Both makes should be charged as
though they are NiMH - I use a peak charger - and both do what it says on
the tin.
I should also add that I've had bad experiences with cheap Chinese-made
consumer grade chargers and won't touch them with a barge pole. I now use
one of the cheaper multi-chemistry chargers sold for charging RC model
equipment: you pay rather more for these, but IME they're worth it.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org
held 400 mAh
the tin.
org
held 400 mAh
the tin.
org
Old June 6th 11, 01:27 PM posted to rec.aviation.soaring
held 400 mAh
the tin.
org
held 400 mAh
the tin.
org
held 400 mAh
the tin.
org
held 400 mAh
the tin.
org
Old June 6th 11, 01:28 PM posted to rec.aviation.soaring
held 400 mAh
the tin.
org
held 400 mAh
the tin.
org
Anyone used FlywithCE? rec.aviation.soaring[_2_] Soaring 0 June 5th 11 07:28 PM
flyWithCE tip #2: flyWithCE Flight Recorder and OLC urosp Soaring 0 February 16th 11 06:28 PM
flyWithCE tip #1: How can you view flights in flyWithCE Logbook? urosp Soaring 0 February 11th 11 07:39 AM
FlywithCE PC[_2_] Soaring 1 January 10th 08 04:34 AM
FlyWithCE V2.1 SUA Ken Kochanski (KK) Soaring 1 June 14th 06 09:34 PM
