I made it back
Old June 6th 11, 06:55 PM posted to rec.aviation.soaring
Tony[_5_]
Default I made it back
Somewhat revolutionary (for me), I actually returned to my point of
takeoff yesterday after a good cross country flight. I took the new-
ish to me NG-1 (a modified BG-12/16) out for a 300 km FAI triangle.
Had a good time, finished the task, and didn't need a retrieve. I can
see why you guys like more L's and fewer D's. Check out the final
glide. Flight report he http://soaringcafe.com/2011/06/diamond-goal/
Old June 6th 11, 09:20 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
takeoff yesterday after a good cross country flight. *I took the new-
Had a good time, finished the task, and didn't need a retrieve. *I can
see why you guys like more L's and fewer D's. *Check out the final
glide. Flight report hehttp://soaringcafe.com/2011/06/diamond-goal/
Good on you, Tony! I believe NG-1 was built by Jerry Nedouer, we tried
for our Diamond distance flights on the same day back in 1976? From
Minden to somewhere in the Owens Valley to Hawthorne. Jerry mad it and
completed his Diamond badge. I landed short in my Duster, .......... L/
D is a relative thing.
Cheers,
JJ
Old June 6th 11, 09:27 PM posted to rec.aviation.soaring
BruceGreeff
Indeed
Efficiency is addictive.
Moved from Bergfalke 2-55 (1:26) to Std Cirrus (1:37) to Kestrel 19 (1:44)
The low L/D number is not the main constraint - the speed means there
are a whole new world of tasks that become possible.
Welcome to the dark side.
Getting home is sometimes less adventurous and probably less fun, but is
a whole lot more compatible with family and commitments...
So far I am scoring more than 3 to 1 on the number of times I have
fetched outlanders, vs times I have needed to be fetched. Probably
means I'm not trying hard enough.
Bruce
Bruce Greeff
T59D #1771
Old June 6th 11, 09:48 PM posted to rec.aviation.soaring
Tony[_5_]
Cheers,
JJ
JJ - yes, Jerome Niedrauer. His son Eric is still flying the Pik 20
they bought to replace the NG-1. He'll be in Wichita this fall to see
the old bird. I'll look in the logs for his diamond distance flight.
I'm pretty sure he did all his diamonds in the glider.
Old June 6th 11, 10:16 PM posted to rec.aviation.soaring
Tony[_5_]
On Jun 6, 3:27*pm, BruceGreeff wrote:
Indeed
fetched outlanders, vs times I have needed to be fetched. *Probably
Bruce
Bruce Greeff
T59D #1771
this was my first soaring flight of the year that didn't result in a
landout. of course it was only my 4th soaring flight of the year. I
still flew about as slow on this flight as I did on my almost 300 km
out/return in the Cherokee last year. Most of that was on the upwind
leg, i was super conservative as I've learned over the years that its
hard to make progress on a task if you are sitting in a field.
Old June 7th 11, 04:21 AM posted to rec.aviation.soaring
Tony[_5_]
Stop cheating ! Get out there and do it with the Cherokee.
See ya, Dave (who had a tough time getting home Friday)
heh Dave. Before yesterday I was determined that I was going to do
all the diamonds in my Cherokee. But man, I was so beat when I got
back I felt like I earned it. Plus I flew so darn slow that it was
very Cherokee-like speedwise So now I will just have to work on
doing a 300 km task in the Cherokee to prove it can be done (it can, i
almost did it last year).
JJ - logs show Diamond Distance June 21, 1975 from DCA (Douglas County
Airport?) to Dolomite to Hawthorne, that the one? Also see your name
in there for a few repairs in 1978, do you recall the reason they were
required?
Old June 7th 11, 02:16 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
County
Airport?) to Dolomite to Hawthorne, that the one? *Also see your name
required?
You got to be kidding, I can't remember what I had for breakfast
yesterday! How can I remember a repair in 1978? Strange because Jerry
built the NG-1, so I don't know why he wouldn't repair it himself? I
moved the turnpoint to a road intersection on the north side of Owens
Lake so I could get 500K at the north end of the
valley...................it worked with a landing at Janies Ranch (the
local cat house) after working hot rocks on the Inyo's and White
mountains all the way north. A fiend who landed at Manzanar tried to
get me to join him, but I was determined. Used that trick to get back
into Bishop in a regionals, years later.
Wood is good,
JJ
Old June 7th 11, 03:19 PM posted to rec.aviation.soaring
Tony[_5_]
On Jun 7, 8:16*am, JJ Sinclair wrote:
*JJ - logs show Diamond Distance June 21, 1975 from DCA (Douglas
County
required?
Wood is good,
JJ
ha but you can remember that flight from 75!
I think the repair was done after Jerry sold the bird. Its a
different signature on the flights in the log starting around 77. it
was some skin work on the fuselage and some minor repairs to the wing
skin 8" outboard on each wing (I think)
Old June 8th 11, 12:34 AM posted to rec.aviation.soaring
Gary[_5_]
Indeed
Bruce
Bruce Greeff
T59D #1771
landout. of course it was only my 4th soaring flight of the year. *I
out/return in the Cherokee last year. *Most of that was on the upwind
hard to make progress on a task if you are sitting in a field.- Hide quoted text -
- Show quoted text -
Tony, for some reason I thought you did your 300k last year....am I
thinking of a near miss? Bruce is right; it's the speed.
Gary Adams GA2
Old June 8th 11, 03:08 AM posted to rec.aviation.soaring
Tony[_5_]
Gary,
Last year I did an out and almost return Diamond Goal attempt in the
Cherokee. The write up for that one is on my Cherokee II blog as well
as Soaring Cafe. Total distance on that one was a touch over 300 km
but i ended up landing 4 miles short of the starting airport at 7:30
PM. That one was a 6.5 hr flight, about the same as Sunday.
http://www.onlinecontest.org/olc-2.0...tId=1688698192
I also did a 300 km straight out flight last year for Gold Distance
http://www.onlinecontest.org/olc-2.0...tId=1618688367
Interestingly the speed I made in the Cherokee on the out and return
was about the same as I made in the NG-1 on Sunday. I bet if I was in
a Nimbus I could still average 30 mph!
2, People know that Swiss made watches are best, while the Asia madeare worst but cheapest, but Some of Asia made Oyster Perpetual Air King - AllStainless Steel are also close to a real thing that is in fact almostimpossible to tell the difference. [email protected] Piloting 0 April 26th 08 07:49 PM
Blue Angels back in Pensacola - practice session - Diamond heading back to the hangar Pensacola Beachcomber Aviation Photos 0 March 23rd 08 04:28 PM
Home, From Paris! Made It Back On 24th NW_Pilot Piloting 9 December 27th 07 06:59 PM
Getting Back to FS - CH analog drivers made all the difference TJ Simulators 5 February 26th 05 07:20 AM
they took me back in time and the nsa or japan wired my head and now they know the idea came from me so if your back in time and wounder what happen they change tim liverance history for good. I work at rts wright industries and it a time travel trap tim liverance Military Aviation 0 August 18th 03 12:18 AM
