Any general recommendations for type of glue to use when attaching (or
reattaching, in this case) a wingtip wheel? Would like it to hold during normal ops, but not require a power tools to remove at some future date. Thanks in advance. -- RWW |
On Jul 6, 9:07*am, R Weien wrote:
Any general recommendations for type of glue to use when attaching (or reattaching, in this case) a wingtip wheel? *Would like it to hold during normal ops, but not require a power tools to remove at some future date. Thanks in advance. -- RWW 3M UHB foam tape? Depends on the material and surface area. You remove UHB tape by using thin fishing line as a "saw". Darryl |
Here is what I did.
I got a set of JJ's wing tip wheels from Williams. These are some kind of cast acrylic. JJ recommended to epoxy the wheels onto the wing surface. I did not like that idea. I preferred the removability with the fishline method as Darryl described. So I got the described 3M VHB tape from McMaster-Carr, but found that it did not stick too well to the acrylic. Also, I needed to sand the base of the wingtip wheel to conform to the wing surface, which was difficult. I did an experiment with different glues and found that the foaming polyurethane (Gorrilla) glue adheres very well to the acrylic. So, I used this expanding polyurethane both to create a conforming surface to the wing and as a surface that the VHB tape adheres to very well. Just put some plastic kitchen wrap on the wing surface, apply the polyurethane glue to the wingtip wheel, set it in place and let it cure. Make sure you have a good marking system for alignment of your wingtip wheels. Then put the VHB tape on the new polyurethane base on the wheel, covering the complete base. Leave the other side of the protective film on. Pull a little corner off of the protection tape on the other side and fold it back to the side such that you can grab it, once you put it in place. Put the wheel down on the wing surface with the little uncovered corner of the VHB tape. Now make sure that you are all ready for the final alignment. Pull the little corner of the protective film to remove the rest of protective film from in between the wing and wheel, while keeping proper alignment. Make sure that the protective film does not break as there is no recovery at this point other than complete removal and restart. (if I did it again, I would put a piece of sticking tape on top of the protective film to pull it all off) Press down and let sit for 24 hours to let the VHB tape adhere. This has been sitting on my ship for 3 seasons now and each time I check, it is still rock solid. And it has been going through some very rough surface, like runway cracks and course gravel. (Some people claim the VHB tape will rather rip the wing skin off than release) I have not yet had the need to remove the wheel with the fishline method. 3U |
On Jul 6, 2:19*pm, weersch wrote:
Here is what I did. I got a set of JJ's wing tip wheels from Williams. These are some kind of cast acrylic. JJ recommended to epoxy the wheels onto the wing surface. I did not like that idea. I preferred the removability with the fishline method as Darryl described. So I got the described 3M VHB tape from McMaster-Carr, but found that it did not stick too well to the acrylic. Also, I needed to sand the base of the wingtip wheel to conform to the wing surface, which was difficult. I did an experiment with different glues and found that the foaming polyurethane (Gorrilla) glue adheres very well to the acrylic. So, I used this expanding polyurethane both to create a conforming surface to the wing and as a surface that the VHB tape adheres to very well. Just put some plastic kitchen wrap on the wing surface, apply the polyurethane glue to the wingtip wheel, set it in place and let it cure. Make sure you have a good marking system for alignment of your wingtip wheels. Then put the VHB tape on the new polyurethane base on the wheel, covering the complete base. Leave the other side of the protective film on. Pull a little corner off of the protection tape on the other side and fold it back to the side such that you can grab it, once you put it in place. Put the wheel down on the wing surface with the little uncovered corner of the VHB tape. Now make sure that you are all ready for the final alignment. Pull the little corner of the protective film to remove the rest of protective film from in between the wing and wheel, while keeping proper alignment. Make sure that the protective film does not break as there is no recovery at this point other than complete removal and restart. (if I did it again, I would put a piece of sticking tape on top of the protective film to pull it all off) Press down and let sit for 24 hours to let the VHB tape adhere. This has been sitting on my ship for 3 seasons now and each time I check, it is still rock solid. And it has been going through some very rough surface, like runway cracks and course gravel. (Some people claim the VHB tape will rather rip the wing skin off than release) I have not yet had the need to remove the wheel with the fishline method. 3U Goop. Lasts for years. If you have to, you can remove it-with some difficulty. Used it on my RS15 several years ago and the present owner is still using them. |
On Jul 6, 10:07*am, R Weien wrote:
Any general recommendations for type of glue to use when attaching (or reattaching, in this case) a wingtip wheel? *Would like it to hold during normal ops, but not require a power tools to remove at some future date. Thanks in advance. -- RWW I used Goop, has held for nearly four years so far, is thick enough to fill minor gaps due to wing profile-have not tried to remove it though, could be a bear. |
On Jul 6, 1:19*pm, weersch wrote:
Here is what I did. I got a set of JJ's wing tip wheels from Williams. These are some kind of cast acrylic. JJ recommended to epoxy the wheels onto the wing surface. I did not like that idea. I preferred the removability with the fishline method as Darryl described. So I got the described 3M VHB tape from McMaster-Carr, but found that it did not stick too well to the acrylic. Also, I needed to sand the base of the wingtip wheel to conform to the wing surface, which was difficult. I did an experiment with different glues and found that the foaming polyurethane (Gorrilla) glue adheres very well to the acrylic. So, I used this expanding polyurethane both to create a conforming surface to the wing and as a surface that the VHB tape adheres to very well. Just put some plastic kitchen wrap on the wing surface, apply the polyurethane glue to the wingtip wheel, set it in place and let it cure. Make sure you have a good marking system for alignment of your wingtip wheels. Then put the VHB tape on the new polyurethane base on the wheel, covering the complete base. Leave the other side of the protective film on. Pull a little corner off of the protection tape on the other side and fold it back to the side such that you can grab it, once you put it in place. Put the wheel down on the wing surface with the little uncovered corner of the VHB tape. Now make sure that you are all ready for the final alignment. Pull the little corner of the protective film to remove the rest of protective film from in between the wing and wheel, while keeping proper alignment. Make sure that the protective film does not break as there is no recovery at this point other than complete removal and restart. (if I did it again, I would put a piece of sticking tape on top of the protective film to pull it all off) Press down and let sit for 24 hours to let the VHB tape adhere. This has been sitting on my ship for 3 seasons now and each time I check, it is still rock solid. And it has been going through some very rough surface, like runway cracks and course gravel. (Some people claim the VHB tape will rather rip the wing skin off than release) I have not yet had the need to remove the wheel with the fishline method. 3U Excellent write up Hans. And I had a typo it's definitely VHB (Very High Bond) not UHB tape. BTW its also available from Uline (in largish rolls). There are also different versions of the VHB tape designed for different surfaces but they are really hard to find some of the exotic ones and even with the "right" type Hans' technique may still be better. Read the directions, there are minimum temp requirements when you mate the surfaces (if you are doing this over winter). Darryl |
Darryl Ramm wrote:
On Jul 6, 1:19 pm, weersch wrote: Here is what I did. I got a set of JJ's wing tip wheels from Williams. These are some kind of cast acrylic. JJ recommended to epoxy the wheels onto the wing surface. I did not like that idea. I preferred the removability with the fishline method as Darryl described. So I got the described 3M VHB tape from McMaster-Carr, but found that it did not stick too well to the acrylic. Also, I needed to sand the base of the wingtip wheel to conform to the wing surface, which was difficult. I did an experiment with different glues and found that the foaming polyurethane (Gorrilla) glue adheres very well to the acrylic. So, I used this expanding polyurethane both to create a conforming surface to the wing and as a surface that the VHB tape adheres to very well. Just put some plastic kitchen wrap on the wing surface, apply the polyurethane glue to the wingtip wheel, set it in place and let it cure. Make sure you have a good marking system for alignment of your wingtip wheels. Then put the VHB tape on the new polyurethane base on the wheel, covering the complete base. Leave the other side of the protective film on. Pull a little corner off of the protection tape on the other side and fold it back to the side such that you can grab it, once you put it in place. Put the wheel down on the wing surface with the little uncovered corner of the VHB tape. Now make sure that you are all ready for the final alignment. Pull the little corner of the protective film to remove the rest of protective film from in between the wing and wheel, while keeping proper alignment. Make sure that the protective film does not break as there is no recovery at this point other than complete removal and restart. (if I did it again, I would put a piece of sticking tape on top of the protective film to pull it all off) Press down and let sit for 24 hours to let the VHB tape adhere. This has been sitting on my ship for 3 seasons now and each time I check, it is still rock solid. And it has been going through some very rough surface, like runway cracks and course gravel. (Some people claim the VHB tape will rather rip the wing skin off than release) I have not yet had the need to remove the wheel with the fishline method. 3U Excellent write up Hans. And I had a typo it's definitely VHB (Very High Bond) not UHB tape. BTW its also available from Uline (in largish rolls). There are also different versions of the VHB tape designed for different surfaces but they are really hard to find some of the exotic ones and even with the "right" type Hans' technique may still be better. Read the directions, there are minimum temp requirements when you mate the surfaces (if you are doing this over winter). Darryl Thanks to all for your excellent replies! -- RWW |
On Jul 11, 8:28*am, RWW wrote:
Darryl Ramm wrote: On Jul 6, 1:19 pm, weersch wrote: Here is what I did. I got a set of JJ's wing tip wheels from Williams. These are some kind of cast acrylic. JJ recommended to epoxy the wheels onto the wing surface. I did not like that idea. I preferred the removability with the fishline method as Darryl described. So I got the described 3M VHB tape from McMaster-Carr, but found that it did not stick too well to the acrylic. Also, I needed to sand the base of the wingtip wheel to conform to the wing surface, which was difficult. I did an experiment with different glues and found that the foaming polyurethane (Gorrilla) glue adheres very well to the acrylic. So, I used this expanding polyurethane both to create a conforming surface to the wing and as a surface that the VHB tape adheres to very well. Just put some plastic kitchen wrap on the wing surface, apply the polyurethane glue to the wingtip wheel, set it in place and let it cure. Make sure you have a good marking system for alignment of your wingtip wheels. Then put the VHB tape on the new polyurethane base on the wheel, covering the complete base. Leave the other side of the protective film on. Pull a little corner off of the protection tape on the other side and fold it back to the side such that you can grab it, once you put it in place. Put the wheel down on the wing surface with the little uncovered corner of the VHB tape. Now make sure that you are all ready for the final alignment. Pull the little corner of the protective film to remove the rest of protective film from in between the wing and wheel, while keeping proper alignment. Make sure that the protective film does not break as there is no recovery at this point other than complete removal and restart. (if I did it again, I would put a piece of sticking tape on top of the protective film to pull it all off) Press down and let sit for 24 hours to let the VHB tape adhere. This has been sitting on my ship for 3 seasons now and each time I check, it is still rock solid. And it has been going through some very rough surface, like runway cracks and course gravel. (Some people claim the VHB tape will rather rip the wing skin off than release) I have not yet had the need to remove the wheel with the fishline method. 3U Excellent write up Hans. And I had a typo it's definitely VHB (Very High Bond) not UHB tape. BTW its also available from Uline (in largish rolls). There are also different versions of the VHB tape designed for different surfaces but they are really hard to find some of the exotic ones and even with the "right" type Hans' technique may still be better. Read the directions, there are minimum temp requirements when you mate the surfaces (if you are doing this over winter). Darryl Thanks to all for your excellent replies! -- RWW I would use Goop for this application. When you want to remove it, drip some toluene on it and it will peel right off. Once I found that that you can easliy remove goop with toluene, I have been using it for many applicaitions It is very strong yet flexible. For example, I do a lot of dynamic soaring with larger RC sailplanes - a servo that is epoxied to a wing skin will almost always pop-off at the worst possible time due to wing skin flex and the fact that epoxy does not bond well to plastics. Goop is perfect IMO - it only takes a small amount, it dries fairly quickly, it flexes, and I can easily remove the servo for service with a few drops of toluene. It does not look all that elegant but it works. /Adam |
| A wingtip | Glenn[_2_] | Aviation Photos | 5 | September 3rd 10 04:33 PM |
| Yet another PA-28 wingtip query... | Mike Spera | Owning | 2 | August 4th 09 04:07 AM |
| Wingtip Camera | NG[_2_] | Soaring | 14 | April 10th 09 12:38 AM |
| Wingtip Camera | kestrel19 | Soaring | 0 | April 9th 09 05:02 PM |
| Visible wingtip vortex! | Bill | Piloting | 23 | October 25th 05 11:37 PM |
