#21
Take a look at this link from Strong parachutes. Scroll down and find
their answer to the question. Settles it for me. http://www.strongparachutes.com/page...stOfTheAnswers MK |
In article Eric Greenwell writes:
On 7/6/2011 8:04 AM, wrote: Pilot rigs haven't evolved much in the last 50 years without forced obsolescence a tiny market would be even smaller. I wonder how the defenders of the 20 year policy would feel if someone bought the type certificate for their glider then grounded all of them over 20 years old for safety? I don't think they need to do to avoid liability, at least in the US. Isn't the limitation on manufacturer's liability only 18 years? It may be now, but note what was happening to general aviation manufacturing before that was changed. Back in the early '80s, most of the GA manufacturers were shutting down production. Cessna shut down single engine production in 1986. As noted on AVweb, the General Aviation Revitalization Act of 1994 (GARA) immunized makers of GA aircraft against lawsuits for defects in products older than 18 years. However, the 9th circuit court of appeals has ruled that the flight manual is part of the aircraft, so any revisions to the manual may restart the clock each time. Clearly, the manufacturer would have trouble defending not revising the manual if changes needed to be made. This may break the 18 year limit of liability. Perhaps the manufacturer will decide that, rather than wait for 18 years to go by with no revisions, that at the 20 years they will cut their liability by issuing a manual revision that says the aircraft is not airworthy after that point. I thnk that Greg raises a potentially frightening possibility. Alan |
What you say would also be true with a brand new parachute. Sad, but
true... "Chris Rollings" wrote in message ... If I was a parachute maker - which, thank the Lord, I'm not sir - I would probably want to put a life on my products (a) to try to protect myself from product liability litigation, particularly in the USA and (b) to try to generate repeat sales. This would have to be balanced against what life - if any - my competitors put on their products. If somebody jumps from an aircraft in the USA, wearing a parachute, and hits the ground without the parachute having been sucessfuly deployed, I think it is a near certainty that there would be a claim made against the parachute manufacturer and/or the last packer. I also think it highly likely that the claim would result in a large sum being awarded, almost regardless of the actual cause of the failure to deploy. At 13:52 06 July 2011, Gary wrote: On Jul 6, 9:15=A0am, GC wrote: On 6/07/2011 03:17, Paul Remde wrote: Hi, They have recently put a note in their manual stating that the life limit is 20 years. They do that for liability reasons. I can't say I blame them - after seeing how some pilot take care (not) of their parachutes. Rubbish! This is simply an attempt to sell more parachutes based on the usual process of thickly spreading FUD. =A0When was the last case of a parachut= e which had been packed on schedule and certified by a qualified rigger failing when needed? =A0Or even failing when pulled on the ground and tes= ted? Where is the industry research which shows that 20 years is the maximum safe life? =A0Is this research on the pack?, the canopy?, the harness? th= e metal components? =A0Or are they reducing the quality of the components they use everywhere so that a proper inspection schedule of all components no longer guarantees safety? =A0Or is this a solid vote of no confidence in the parachute rigging profession? What do they mean by liability reasons? =A0Do they now warrant their chutes for 20 years unqualified by inspection? =A0Or do they say no matte= r how well they're treated, they won't last more than 20 years? =A0Even in very low UV environments such as Scandinavia? =A0If the reason really is liability, why isn't the life limited only by inspection when used in jurisdictions other than the USA? They're certainly not a great product if they now last less than half the life regularly attained by many earlier chutes. Rubbish! GC Paul Remde "Dan Marotta" wrote in message ... It's about riggers wanting to sell you a new parachute rather than packing a perfectly serviceable item. I posted a similar question almost a year ago and was met with a barage of questions about what my life is worth, etc. Totally useless replies. In the US there is no life limit on your parachute if it will pass all required tests and inspections. The trick is to find a rigger who will accept the work. I was fortunate in this regard and my 37 year old Pioneer Thin Pack is still in service. It will remain in service as long as it is serviceable. "Gary" wrote in message .= ... I apoligize of this has been discussed in the past. Looking for a use= d chute I keep running into talk of 20 year life span for parachutes. I= s it solely up to the rigger to pack or refuse a chute that age? Still looking for a used chute that will not break the bank after recently buying an ASW-20. Thanks, Gary Adams GA2- Hide quoted text - - Show quoted text - Wow, All good info. Thanks all for the replys. The rigger I plan on using (TA) is a fellow clubmember of mine at CCSC and someone I trust. I like the idea that the life span is 180...... GA2 |
#24
On Jul 6, 7:43*pm, howdy wrote:
Take a look at this link from Strong parachutes. *Scroll down and find their answer to the question. *Settles it for me. http://www.strongparachutes.com/page...icles.php#Rest... MK Looks like a good answer to me since I fly with a Strong chute. Thanks for the reference. Andy |
#25
Any evidence for that remark? I have not heard of any parachute
manufacturer being sued in that situation. Anyone can sue, of course, but "highly likely that the claim would result in a large sum being awarded" seems without any basis. On 7/7/2011 7:01 AM, Dan Marotta wrote: What you say would also be true with a brand new parachute. Sad, but true... "Chris Rollings" wrote in message ... If I was a parachute maker - which, thank the Lord, I'm not sir - I would probably want to put a life on my products (a) to try to protect myself from product liability litigation, particularly in the USA and (b) to try to generate repeat sales. This would have to be balanced against what life - if any - my competitors put on their products. If somebody jumps from an aircraft in the USA, wearing a parachute, and hits the ground without the parachute having been sucessfuly deployed, I think it is a near certainty that there would be a claim made against the parachute manufacturer and/or the last packer. I also think it highly likely that the claim would result in a large sum being awarded, almost regardless of the actual cause of the failure to deploy. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
#26
On 7/7/2011 12:15 AM, Alan wrote:
In Eric writes: On 7/6/2011 8:04 AM, wrote: Pilot rigs haven't evolved much in the last 50 years without forced obsolescence a tiny market would be even smaller. I wonder how the defenders of the 20 year policy would feel if someone bought the type certificate for their glider then grounded all of them over 20 years old for safety? I don't think they need to do to avoid liability, at least in the US. Isn't the limitation on manufacturer's liability only 18 years? It may be now, but note what was happening to general aviation manufacturing before that was changed. Back in the early '80s, most of the GA manufacturers were shutting down production. Cessna shut down single engine production in 1986. As noted on AVweb, the General Aviation Revitalization Act of 1994 (GARA) immunized makers of GA aircraft against lawsuits for defects in products older than 18 years. However, the 9th circuit court of appeals has ruled that the flight manual is part of the aircraft, so any revisions to the manual may restart the clock each time. Clearly, the manufacturer would have trouble defending not revising the manual if changes needed to be made. This may break the 18 year limit of liability. Perhaps the manufacturer will decide that, rather than wait for 18 years to go by with no revisions, that at the 20 years they will cut their liability by issuing a manual revision that says the aircraft is not airworthy after that point. That sounds very unlikely to me, as it would mean they are leaving the aircraft business - who would buy a plane from them after that? If they want out, all they have to do is sell the assets and go home. There is no reason to destroy the value of the aircraft, nor is it obvious to me the manufacturer can simply declare an aircraft "not airworthy" without showing there is a defect in it. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
BRS chutes. Why doesn't everyone use them? | Sparkorama | Soaring | 53 | January 26th 11 01:55 PM |
BRS chutes. Why doesn't everyone use them? | Scott Lamont | Soaring | 0 | January 22nd 11 01:07 PM |
BRS chutes. Why doesn't everyone use them? | 5Z | Soaring | 0 | January 22nd 11 01:34 AM |
D.C. anti-war rally on C-SPAN today at 8:15 AM on the west coast of US and at 11:15 AM on east coast - President Carter at Brandeis on C-SPAN 2's 'Book TV' today at 12:30 PM (on the west coast and at 3:30 PM on the east coast): | [email protected] | Naval Aviation | 0 | January 27th 07 02:18 PM |
Windsock Life Span | Corky Scott | Home Built | 9 | September 1st 03 12:24 PM |
