#11
On Jul 16, 6:49*am, wrote:
On Jul 14, 2:48*pm, Stephen wrote: On Jul 11, 5:34*pm, Stephen Michalik wrote: On Jul 11, 2:03*pm, Darryl Ramm wrote: Thanks Darryl and others on your replies... I spoke to CAE today and they believe it is one of 2 problems and most likely the GPS board. I'm sending the unit back for repair and will update the result as I find out. Stephen The GPS engine hardware board in the unit failed. Jeff said likely from age. Stephen I had the same thing happen to me. You will find the new GPS engine locks in much faster when you turn it on. Clay New GPS engine? Huh? The Cambridge 302 IGC approval document describes a Garmin GPS25-LVC GPS receiver. The manufacturer cannot just change this themselves and keep IGC approval of the flight recorder. The actual time to get a GPS fix depends on if it was recently operated at a different location far enough away and whether it has a currently valid satellite almanac (and a few more things I'll ignore). Typically when a GPS receiver like this is returned from a a repair facility you'll see them need to get a cold fix and therefore slower than the usual warm fix many people would see before a flight. The time to get a cold fix times with newer generation GPS receivers will be a lot faster than the rather old GPS engine used in the C302. Darryl |
not receiving digest ... | Ron Gleason | Soaring | 1 | May 19th 10 07:11 PM |
Iran Prepares for Global Nuclear War ....Iran will be on the receiving end.... | AirRaid[_5_] | Naval Aviation | 0 | April 30th 07 03:56 AM |
Start receiving MONEY with this simple system. Guaranteed. | Mr Anderson | Aviation Marketplace | 0 | February 2nd 04 11:55 PM |
Off topic question - Are you receiving viruses? | Mike Williams | Rotorcraft | 8 | September 27th 03 04:14 AM |
GPS Satellites switch off? | Eduard Gorina | Soaring | 2 | September 17th 03 02:28 AM |
