#31
On Jul 25, 6:38*pm, Tuno wrote:
Although I personally disagree with this decision, it is within the purview of the on-site contest management to decide who posts to the SSA website. QT Rules Committee And as reported by Ken Sorenson, "Logan, UT contests have apparently elected to change reporters at the contest". All that is clear, and no argument from me, but none of it explains why SSA removed the old posts. I would like to know why that additional step was taken. 2NO On censorship: It's up to the organizers to select the individual to post daily contest reports. They are within their rights to change writers or even delete posts - though it doesn't look good when they do. When you ask someone who injects color and personal opinion into his writing to post on behalf of the contest organizers, then have some marginal days with intimidating flying you are going to get the obvious injection of perspective to the commentary. On Logan as a site: I broke my beloved -27B landing in barley in a mountain valley on Day 2 of the 15M nationals. I made all the decisions myself and live with the consequences. In the end if I had flown about 2 miles farther away from landable fields I likely would have made it home, but I didn't feel comfortable with the all-or-nothing proposition that appeared to represent at the time. Logan is a very technical site and that fact is particularly apparent when the top of lift is 10,000' or lower. The spread in the scores, large numbers of outlandings and significant numbers of withdrawals - along with a couple of broken gliders - all stand as evidence of how challenging the flying can be. The challenges this year at logan fall into three broad categories: 1) The lift starts on the late side - generally after 2pm. It might go on until 7:30, but sometimes it doesn't. This makes it challenging to get a 4-hour Nationals task in when you account for launching all the gliders and giving them time to climb up. Yesterday's task shows the challenge of getting a 3 1/2 hour task in. 2) Climbing out is a challenge. The Logan ridge is 10,000 feet high and 4-5 miles from the airport. It's a steep series of ridges and canyons and you really have to rack it up (but not past 45-50 degrees or your circle get's bigger not smaller - shockingly even experienced pilots forget this). You have to work your way from one spur to the next and when you get to the top you have about a 1,000- foot working band before you are below the ridge tops and have to start over. Better weather make this less of a challenge, but in 10 days there this was the case every day this year. This year we towed to 2,500 feet to try to give pilots a better chance to get a climb, bit it exacerbates #1 when you spend the additional 25-30% in timer per tow. 3) Ridge transitions are the name of the game. There is not reliable lift in the valleys so you fly ridge to ridge. Given the nature of the terrain you may ridge soar or choose thermals in the high ground. When the top of lift is low you have to do both - climb up on one ridge and dive to the next one, ridge soar upon arrival until you can find a thermal - or ridge run for a bit. 4) There are broad swaths of terrain in the contest areas that are unattractive, either because they are in marine air, filled with water or made of lava (hardened, not molten), among other things. This is true of many sites to one degree or another. Most problem areas were briefed at various pilots' meetings. If you combine #4 with #3 you get areas like where I got into trouble where you need the ridge to work our are faced with a 15-mile glide to landable spots. When the lift doesn't go very high you end up with what amounts to a 500-1,000' working band. In my case I decided to glide toward the fields to play it safe but with the air running down instead of up in the valleys my achieved L/D was cut in half - 23:1 instead of 48:1 according to SeeYou. Which brings me to the final point... 5) It's mountain flying. Mountains are big geographic features that can have a big impact on the local weather conditions. Large areas of lift and sink that you might not find in the flatlands are the main things to think about. It's all the more critical when you are flying low-level. To me all of this adds up to a need to do a lot of homework when going to fly at a place like Logan. If the conditions are strong you likely have enough margin to mask many of the challenges, but when you are among, rather than above, the mountains you need to take care. It's a beautiful place with a great airport and a supportive community. I'd go again - I've already made a big investment in learning about how to fly there. 9B |
#32
On Jul 25, 8:09*pm, Andy wrote:
On Jul 25, 6:38*pm, Tuno wrote: Although I personally disagree with this decision, it is within the purview of the on-site contest management to decide who posts to the SSA website. QT Rules Committee And as reported by Ken Sorenson, "Logan, UT contests have apparently elected to change reporters at the contest". All that is clear, and no argument from me, but none of it explains why SSA removed the old posts. I would like to know why that additional step was taken. 2NO On censorship: It's up to the organizers to select the individual to post daily contest reports. *They are within their rights to change writers or even delete posts - though it doesn't look good when they do. *When you ask someone who injects color and personal opinion into his writing to post on behalf of the contest organizers, then have some marginal days with intimidating flying you are going to get the obvious injection of perspective to the commentary. On Logan as a site: I broke my beloved -27B landing in barley in a mountain valley on Day 2 of the 15M nationals. I made all the decisions myself and live with the consequences. *In the end if I had flown about 2 miles farther away from landable fields I likely would have made it home, but I didn't feel comfortable with the all-or-nothing proposition that appeared to represent at the time. Logan is a very technical site and that fact is particularly apparent when the top of lift is 10,000' or lower. *The spread in the scores, large numbers of outlandings and significant numbers of withdrawals - along with a couple of broken gliders - all stand as evidence of how challenging the flying can be. The challenges this year at logan fall into three broad categories: 1) The lift starts on the late side - generally after 2pm. It might go on until 7:30, but sometimes it doesn't. *This makes it challenging to get a 4-hour Nationals task in when you account for launching all the gliders and giving them time to climb up. Yesterday's task shows the challenge of getting a 3 1/2 hour task in. 2) Climbing out is a challenge. The Logan ridge is 10,000 feet high and 4-5 miles from the airport. *It's a steep series of ridges and canyons and you really have to rack it up (but not past 45-50 degrees or your circle get's bigger not smaller - shockingly even experienced pilots forget this). You have to work your way from one spur to the next and when you get to the top you have about a 1,000- foot working band before you are below the ridge tops and have to start over. Better weather make this less of a challenge, but in 10 days there this was the case every day this year. This year we towed to 2,500 feet to try to give pilots a better chance to get a climb, bit it exacerbates #1 when you spend the additional 25-30% in timer per tow. 3) Ridge transitions are the name of the game. There is not reliable lift in the valleys so you fly ridge to ridge. Given the nature of the terrain you may ridge soar or choose thermals in the high ground. When the top of lift is low you have to do both - climb up on one ridge and dive to the next one, ridge soar upon arrival until you can find a thermal - or ridge run for a bit. 4) There are broad swaths of terrain in the contest areas that are unattractive, either because they are in marine air, filled with water or made of lava (hardened, not molten), among other things. This is true of many sites to one degree or another. Most problem areas were briefed at various pilots' meetings. If you combine #4 with #3 you get areas like where I got into trouble where you need the ridge to work our are faced with a 15-mile glide to landable spots. When the lift doesn't go very high you end up with what amounts to a 500-1,000' working band. In my case I decided to glide toward the fields to play it safe but with the air running down instead of up in the valleys my achieved L/D was cut in half - 23:1 instead of 48:1 according to SeeYou. Which brings me to the final point... 5) It's mountain flying. Mountains are big geographic features that can have a big impact on the local weather conditions. Large areas of lift and sink that you might not find in the flatlands are the main things to think about. It's all the more critical when you are flying low-level. To me all of this adds up to a need to do a lot of homework when going to fly at a place like Logan. *If the conditions are strong you likely have enough margin to mask many of the challenges, but when you are among, rather than above, the mountains you need to take care. It's a beautiful place with a great airport and a supportive community. I'd go again - I've already made a big investment in learning about how to fly there. 9B Meant to say "five categories" - or in the words of Monty Python, "No one expects the Spanish Inquisition!" |
#33
On Jul 25, 9:09*pm, Andy wrote:
On Jul 25, 6:38*pm, Tuno wrote: Although I personally disagree with this decision, it is within the purview of the on-site contest management to decide who posts to the SSA website. QT Rules Committee And as reported by Ken Sorenson, "Logan, UT contests have apparently elected to change reporters at the contest". All that is clear, and no argument from me, but none of it explains why SSA removed the old posts. I would like to know why that additional step was taken. 2NO On censorship: It's up to the organizers to select the individual to post daily contest reports. *They are within their rights to change writers or even delete posts - though it doesn't look good when they do. *When you ask someone who injects color and personal opinion into his writing to post on behalf of the contest organizers, then have some marginal days with intimidating flying you are going to get the obvious injection of perspective to the commentary. On Logan as a site: I broke my beloved -27B landing in barley in a mountain valley on Day 2 of the 15M nationals. I made all the decisions myself and live with the consequences. *In the end if I had flown about 2 miles farther away from landable fields I likely would have made it home, but I didn't feel comfortable with the all-or-nothing proposition that appeared to represent at the time. Logan is a very technical site and that fact is particularly apparent when the top of lift is 10,000' or lower. *The spread in the scores, large numbers of outlandings and significant numbers of withdrawals - along with a couple of broken gliders - all stand as evidence of how challenging the flying can be. The challenges this year at logan fall into three broad categories: 1) The lift starts on the late side - generally after 2pm. It might go on until 7:30, but sometimes it doesn't. *This makes it challenging to get a 4-hour Nationals task in when you account for launching all the gliders and giving them time to climb up. Yesterday's task shows the challenge of getting a 3 1/2 hour task in. 2) Climbing out is a challenge. The Logan ridge is 10,000 feet high and 4-5 miles from the airport. *It's a steep series of ridges and canyons and you really have to rack it up (but not past 45-50 degrees or your circle get's bigger not smaller - shockingly even experienced pilots forget this). You have to work your way from one spur to the next and when you get to the top you have about a 1,000- foot working band before you are below the ridge tops and have to start over. Better weather make this less of a challenge, but in 10 days there this was the case every day this year. This year we towed to 2,500 feet to try to give pilots a better chance to get a climb, bit it exacerbates #1 when you spend the additional 25-30% in timer per tow. 3) Ridge transitions are the name of the game. There is not reliable lift in the valleys so you fly ridge to ridge. Given the nature of the terrain you may ridge soar or choose thermals in the high ground. When the top of lift is low you have to do both - climb up on one ridge and dive to the next one, ridge soar upon arrival until you can find a thermal - or ridge run for a bit. 4) There are broad swaths of terrain in the contest areas that are unattractive, either because they are in marine air, filled with water or made of lava (hardened, not molten), among other things. This is true of many sites to one degree or another. Most problem areas were briefed at various pilots' meetings. If you combine #4 with #3 you get areas like where I got into trouble where you need the ridge to work our are faced with a 15-mile glide to landable spots. When the lift doesn't go very high you end up with what amounts to a 500-1,000' working band. In my case I decided to glide toward the fields to play it safe but with the air running down instead of up in the valleys my achieved L/D was cut in half - 23:1 instead of 48:1 according to SeeYou. Which brings me to the final point... 5) It's mountain flying. Mountains are big geographic features that can have a big impact on the local weather conditions. Large areas of lift and sink that you might not find in the flatlands are the main things to think about. It's all the more critical when you are flying low-level. To me all of this adds up to a need to do a lot of homework when going to fly at a place like Logan. *If the conditions are strong you likely have enough margin to mask many of the challenges, but when you are among, rather than above, the mountains you need to take care. It's a beautiful place with a great airport and a supportive community. I'd go again - I've already made a big investment in learning about how to fly there. 9B Frank was never asked by the contest management to be the reporter for the contest therefore we did not change reporters. |
#34
![]() Posts to the SSA contest page are permanent parts of contest reporting. The Logan contest management expected that material posted to the official webpage would be factual. While blogs may embellish or exaggerate to make the material more interesting, it is important to provide true statements on the official website that do not mislead readers. Unfortunately the posts to the website had misleading statements that were beyond mild exaggeration. The statement that led to the removal of the posts was from the Day Three report (July 22, 2011): “As it turned out, a huge cloud street set up well to our north over Sherman Peak running horizon to horizon east-northeast to west- southwest that ran right through the 15m task area. ”All” we had to do was get to Sherman Peak, connect with the street, run it for 80 miles out over completely unlandable (and uninhabited) terrain, turn around and get home, and all but one 15m pilot was able to do this in some fashion or another.” While the statement makes for sensational reading and from the comments on RAS many believed it; unfortunately it was misleading and was well beyond exaggeration for effect. After reviewing Frank’s flight for that day (July 21st), it is evident that he was never more than eight miles from landable fields and this was at flight altitudes of 4500 to 9000 feet agl. You can download his KML file from the OLC and review it in Google Earth. Please notice both the many communities, farms, airports and landable fields he and the rest of the competitors flew over. You can review my July 3rd flight where I landed in the flight zone of the July 21st contest flight to see that many of the fields that are not green are also landable. Almost every valley in the flight area is filled with landable fields. In general, most of the tasking area in Logan has many airports and landable fields in all quadrants. It is one of the safest mountain sites that I have ever flown at and I have received similar comments from top pilots that have flown at Logan. It is somewhat intimidating to the new pilots that are not familiar with mountain flying, but those that embrace it come away excited about the possibilities and find they approach their flying in a different way after the experience. I encourage the readers here to do their due diligence and review flight logs and tasks in Google Earth before believing everything they read in blogs and RAS. The Logan contest management felt that while it was perfectly fine for Frank or any other blogger to write their opinions, they should not be posted as part of the official website. There were also many other bloggers at the contest and this leads to the question of how best to provide easy access to all bloggers without officially endorsing them. The best solution was to remove the posts and provide links to Frank’s and others’ blogs as part of the official daily report. Readers can easily link to the blogs and it provides a clear separation from the official report. Tim Taylor |
#35
Ted,
My understanding is that the contest organizer, who has responsibility for the contest reports, asked the SSA webmaster to remove the reports, which he did. The decision to remove the reports was made by the contest organizer. A posting elsewhere in this thread by Tim Taylor explains their rationale. As you know from your own experience as a contest organizer, putting on a contest is a huge amount of work, usually done entirely by a small group of volunteers. Those of us who are privileged to fly these contests really appreciate the effort put in by all contest organizers, however imperfect they may seem at times. It has become increasingly difficult to find the volunteers needed to host, organize, and run contests. Hopefully the folks who have become wound up over the handling of Frank's entertaining reports will give the contest organizers, and the SSA volunteers, the benefit of the doubt on this matter. The last thing we can afford to do is to run off the few SSA volunteers and contest organizers we have. There is no "them", its just "us". Ken Sorenson "Tuno" wrote in message ... Although I personally disagree with this decision, it is within the purview of the on-site contest management to decide who posts to the SSA website. QT Rules Committee And as reported by Ken Sorenson, "Logan, UT contests have apparently elected to change reporters at the contest". All that is clear, and no argument from me, but none of it explains why SSA removed the old posts. I would like to know why that additional step was taken. 2NO |
#36
On Jul 26, 7:37*am, "Ken Sorenson" wrote:
Ted, My understanding is that the contest organizer, who has responsibility for the contest reports, asked the SSA webmaster to remove the reports, which he did. The decision to remove the reports was made by the contest organizer.. A posting elsewhere in this thread by Tim Taylor explains their rationale. As you know from your own experience as a contest organizer, putting on a contest is a huge amount of work, usually done entirely by a small group of volunteers. Those of us who are privileged to fly these contests really appreciate the effort put in by all contest organizers, however imperfect they may seem at times. It has become increasingly difficult to find the volunteers needed to host, organize, and run contests. Hopefully the folks who have become wound up over the handling of Frank's entertaining reports will give the contest organizers, and the SSA volunteers, the benefit of the doubt on this matter. The last thing we can afford to do is to run off the few SSA volunteers and contest organizers we have. *There is no "them", its just "us". Ken Sorenson "Tuno" wrote in message ... Although I personally disagree with this decision, it is within the purview of the on-site contest management to decide who posts to the SSA website. QT Rules Committee And as reported by Ken Sorenson, "Logan, UT contests have apparently elected to change reporters at the contest". All that is clear, and no argument from me, but none of it explains why SSA removed the old posts. I would like to know why that additional step was taken. 2NO 2NO, The removal of the reports we done by the contest organizers, in fact I performed the actions after ALL of the contest organizations agreed to the action. There was no involvement by anyone at the SSA. We understood the risks of our decision and actions. Ron Gleason |
#37
Thank you Ron and Ken (and Tim) -- I am fine with all of these
explanations. It just strikes me as a bit extreme that the posts were removed. While I have experience as a contest organizer and manager, my sensitivity on this topic stems from much longer experience as a field reporter in sanctioned contests (both USPA and FAI). I wasn't in Logan of course, and I don't mean to second-guess the organizer's actions, but if I was doing the field reports and the organizer didn't like them, I hope I'd be given the opportunity to make a correction, as opposed to being censored! That just makes everybody look bad. 2NO (suffering from lack-of-flying syndrome ... and looking forward to flying at Logan someday) |
#38
To me all of this adds up to a need to do a lot of homework when going to fly at a place like Logan. *If the conditions are strong you likely have enough margin to mask many of the challenges, but when you are among, rather than above, the mountains you need to take care. It's a beautiful place with a great airport and a supportive community. I'd go again - I've already made a big investment in learning about how to fly there. As someone who flew Logan both last year and this year, I wanted to add a couple of things to Andy's thoughtful post: My big takeaway from the contest (at least during the Regionals week) was that Logan was a more challenging place to fly this year than "normal". Mostly it was bad timing on the part of the weather Gods - but there were a lot of things, including: 1) Weaker lift during a period of intense glider activity, especially with folks who were keen to carry a lot of water and fly hard. 2) Somewhat lower lift heights than last year 3) A bad winter causing crops to be "behind schedule" in being harvested, slightly reducing the landout options a bit 4) Contest organizers wanting to make sure that a very large field of aircraft had enough time to get organized and ready. Coupled with the late days this meant baking on the tarmac for 2 hours every day; something that I think contributed to fatigue, concentration, and frustration levels (especially after launch while crawling up the ridge in groups). 5) A very large and diverse set of pilots, including a lot of people who aren't used to mountain flying and didn't seem to be comfortable with key aspects of such flying (including when to "change gears" to fly conservatively, and planning ahead to ensure that you stop soaring with enough altitude left to reach a landout field that may be a few miles from your position). I've got some minor quibbles (such as the backup tasking that others have mentioned); but overall I think the contest staff did the best they could, including many safety briefings, strategy tips, and "data- dumps" by local experts gathered around big maps and slide-show presentations. Scoring was handled very promptly and openly. Karl S was a stern-but-reasonable CD while I was there. And although I had some frustrating days myself, I *like* the fact that this was a challenge (for both the Regional pilots and the Nats competitors). As I've said befo in my opinion there's a big difference between a "fun-fly" and a contest; especially when we're talking about National Championships! One last thing: I've seen and heard so much about the "unlandable" terrain around Logan, on this message group and other places. I am not trying to make a personal attack on those folks; but do people talk the same way about Montague? Parowan? Or (most of) Nevada? How about soaring in the Alps or New Zealand (which most pilots talk about whilst drooling)? It seems to me that anywhere you fly there are going to be unlandable areas. I was taught that part of soaring is learning to either avoid those areas, or to cease soaring and deviate to landable terrain when you get below a safe altitude. As long as proper judgement is used, unlandable terrain isn't necessarily _unsafe_ terrain. And while I have full sympathy and respect for the pilots who damaged their gliders, I'd like to point out that it wasn't the youngest pilots or least-experienced contestants at Logan who got into trouble - so its not like baby lambs were being led to slaughter (I consider myself one of those baby lambs, since this was just my 5th contest and I only have ~300 hrs in gliders). OK, OK, I'll get off the soap-box... Hope to see you all at future contests! --Noel |
#39
On Jul 23, 5:20*pm, Frank Paynter wrote:
I have been asked by the contest management here at Logan to stop posting my reports on the official SSA site, so henceforth these reports will be available only on SoaringCafe.com. *Apparently I was using the ‘U’ (Unlandable) word a little too often for their taste. *I freely admit that a lot of the areas that from this flatlander’s perspective looks unlandable may in fact be perfectly safe from the point of view of a Logan regular, but hey – I’m not completely dumb and it looked pretty scary to me! ;-). Forrest Gump: "Momma says Stupid is as Stupid does." It's obvious from the feedback that most enjoy your reporting. Thanks and keep it up soaring and reporting-wise. |
#40
On Jul 23, 11:58*pm, Mike the Strike wrote:
"Based on my experience of flying out west, 2 out of 60 is pretty much par for a contest." Mike, I'm sure you will agree with me that 2 accidents is 2 too many. All, what are we doing in this sport to prevent this from happening again? It really makes me sick to my stomach to see contestants demolish their gliders only to have it hushed up by contest management. Seeing people get hurt or killed in contests lowers the participation rate. We need to hear about the accidents in order to learn a lesson!! I personally know two pilots who quit flying in contests when they watched a glider cartwheel end over end landing in an unlandable field. Yet, the contest report for that day said nothing regarding the accident and just showed a W, F for Withdrew from contest and Flight log. If someone says a task was called over 80 miles of unlandable terrain, yet another pilot claims there's always a suitable field within 8 miles of the course line, then why aren't these suitable fields being entered into the turnpoint database? Situational awareness would greatly improve if you got low and could see the distance, direction and altituded needed to find this suitable field. Looking at the turnpoint database for Logan, it shows lots of mountain peaks for turnpoints. Nobody needs glide navigation into mountain peaks. Pilots need glide navigation into suitable fields. How about using actual suitable landing areas for turnpoints? We're not taking pictures of easily identifiable turnpoints with Kodak cameras anymore!! Maybe our accident ratio of 2 out of 60, would be much much lower if people had these suitable fields marked on their GPS. I love this sport and hate to hear of accidents happening. |
Soaring Cafe | First Week Digest | Bill Elliott | Soaring | 3 | January 11th 11 07:04 PM |
More Videos from Logan, UT Region 9 contest | Bruno[_2_] | Soaring | 5 | August 15th 10 03:58 PM |
First of Logan Region 9 Contest HD Videos | Bruno[_2_] | Soaring | 1 | July 27th 10 02:05 AM |
HD video from Logan Region 9 Contest | Bruno | Soaring | 2 | August 25th 09 04:03 AM |
Ely Region 11 Soaring contest # 711 reporting. | [email protected] | Soaring | 0 | May 31st 05 06:16 PM |
