An advertisement in QST magazine caught my eye and I wonder if some one
has used something similar to this in gliders(we don't need 25 Amps at 12 Volts): http://www.mfjenterprises.com/Produc...ctid=MFJ-4416B The idea is to keep the voltage supplied to your electrics constant even if the battery voltage drops to as low as 9 Volts (in the above example). Tony LS6-b "6N" |
On 7/27/11 7:02 PM, Tony V wrote:
An advertisement in QST magazine caught my eye and I wonder if some one has used something similar to this in gliders(we don't need 25 Amps at 12 Volts): http://www.mfjenterprises.com/Produc...ctid=MFJ-4416B The idea is to keep the voltage supplied to your electrics constant even if the battery voltage drops to as low as 9 Volts (in the above example). Tony LS6-b "6N" Tony With modern avionics/electronics you really should not need this. Modern radios, transponders, etc. have built in switch mode power supplies that effectively do the same as this device does, but usually more efficiently. These approaches are really only something to consider if you have some legacy piece of electronics that is very sensitive to voltage -- and often in those cases a bigger battery (if possible) is a better solution. Another minor downside of these type devices is the apparent sudden loss of power - but that's solved by monitoring the raw battery voltage. Darryl |
In article Tony V writes:
An advertisement in QST magazine caught my eye and I wonder if some one has used something similar to this in gliders(we don't need 25 Amps at 12 Volts): http://www.mfjenterprises.com/Produc...ctid=MFJ-4416B The idea is to keep the voltage supplied to your electrics constant even if the battery voltage drops to as low as 9 Volts (in the above example). Tony LS6-b "6N" You might want to read the reviews at http://www.eham.net/reviews/detail/7504 first. I would want to test it extensively on the ground before I tried one in an aircraft. Unfortunately, in looking for other products that do the same thing, the reviews I have found have been no better. Alan |
On Wed, 27 Jul 2011 22:02:14 -0400, Tony V wrote:
An advertisement in QST magazine caught my eye and I wonder if some one has used something similar to this in gliders(we don't need 25 Amps at 12 Volts): http://www.mfjenterprises.com/Produc...ctid=MFJ-4416B The idea is to keep the voltage supplied to your electrics constant even if the battery voltage drops to as low as 9 Volts (in the above example). Assuming you're using it to maintain 12v off a nominally 12v battery, the only problem I'd see is that once the battery drops below about 11.5v there's not a lot left in it. Maintaining 12v out of the black box is probably going to suck the last juice out of the battery pretty fast. Add on the 90% efficiency of the thing and merely by fitting it you've just increased your power drain by 11%. Bottom line: I wouldn't use one this way because I don't think it would help much. However, if you want to run a higher voltage device off a 12v battery, its a good idea. I carry a 28v R C Allen turn & slip in my Libelle, which uses a solid state 12v = 28v converter in its power cable. This works perfectly. The device is tiny - a single PCB inside heat-shrink tube and about 40mm x 15mm, so I haven't seen what on the board. However, I'd lay long odds that it contains a Maxim step-up voltage switching regulator, say a MAX 1771, a power MOSFET and 6 passive components. http://www.maxim-ic.com/datasheet/index.mvp/id/1030 The MAX1771 can handle up to 2 amps and costs $US 3.55 - that is a Buy It Now price on eBay, so I'd guess you could have a working voltage converter for $8 or less - say 12 bucks if you sprung for input and output connectors rather than simply soldering the wires on. At that price I'd also try using one to power a 14v radio off a 12v battery rather than adding an extra 2v cell. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On 7/28/2011 3:52 PM, Darryl Ramm wrote:
On 7/27/11 7:02 PM, Tony V wrote: An advertisement in QST magazine caught my eye and I wonder if some one has used something similar to this in gliders(we don't need 25 Amps at 12 Volts): http://www.mfjenterprises.com/Produc...ctid=MFJ-4416B The idea is to keep the voltage supplied to your electrics constant even if the battery voltage drops to as low as 9 Volts (in the above example). Tony LS6-b "6N" Tony With modern avionics/electronics you really should not need this. Modern radios, transponders, etc. have built in switch mode power supplies that effectively do the same as this device does, but usually more efficiently. Thanks, Darrell. The reason that I ask is that after flying for a few hours with a new 9Ahr battery, the LCDs on my radio (Dittel FSG71M) blank out when I transmit - which gets out OK. Other than the radio, I'm only running a Cambridge 302 and an iPaq. Tony V. |
On 7/29/11 4:51 PM, Tony V wrote:
With modern avionics/electronics you really should not need this. Modern radios, transponders, etc. have built in switch mode power supplies that effectively do the same as this device does, but usually more efficiently. Thanks, Darrell. The reason that I ask is that after flying for a few hours with a new 9Ahr battery, the LCDs on my radio (Dittel FSG71M) blank out when I transmit - which gets out OK. Other than the radio, I'm only running a Cambridge 302 and an iPaq. Tony V. Its hard to see what would be drawing so much power to drop the Dittel below its speced operating voltage. There was a recall/repair on some of these radios but I though that only affected the RF board, not sure that could affect the display like this but I don't know. Was yours affected? - check here http://www.cumulus-soaring.com/dittel.htm Other Dittel users can comment if they ever see this display problem at reasonable supply voltages. I've never owned a Dittel radio. I'd want to check that the 9Ah battery is not faulty or not getting fully charged (the charger may be faulty or incorrectly sized etc), something else/hidden is drawing power or the Ditel has a problem. It would be nice to do a discharge test on the battery after charging it as you normally would and see exactly what power it is storing. You can do this maually but much easier with a discharge tester like the West Mountain Radio CBT III. Improper charging is not an uncommon problem-check your charger is the right type, and sized for the battery and if it has indicators for charge/complete or float stage do they show as expected (and you still need to leave the battery on charge for many hours after that to top up the last ~10% or so). But if you can't do that at least measure the current your equipment is drawing and measure the voltage under load (all avionics on and transmit key pressed) when the Ditel starts misbehaving. I have numbers for common toys including the C302 etc. in slides at http://www.darryl-ramm.com/glider-batteries I think the radios are speced down to 9V and may work even lower, and with your setup just should not have problem after only a few hours. You would not be the first person to have something hidden behind the panel that is consuming power. Some PDAs can suck interesting amounts of power ( transponder) esp. if they have a large Li extended battery packs that are connected to the ship when discharged. A poorly designed PDA chargers might be very inefficient (but most are not). Still noe of these alone would really explain this. Maybe you have several things goign on. Certainly measure the current draw with everything turned on and see if it makes sense with what is in my slides. Also measure the current of each device. Darryl |
Tony,
I am with Darryl on this, with your seemingly modern electronics and a new 9AH battery, you "should not be having a problem". But of course you do apparently seem to be having an problem. I say apparently as you say your Dittel display disappears when you transmit but it still "... gets out OK...". This seems like a problem with your radio, not with your battery or wiring. But here are some other ideas. What is the gauge of your wiring from the battery to your instrument panel? If you are using small gauge wiring, and drawing considerable amps when transmitting, then the voltage can drop considerably between the battery and your radio. I use 12ga wiring. 14ga generally works just fine. Anything smaller and you are throwing away voltage, which we glider pilots cannot afford. So measure the voltage of your power system at the radio when you hit the transmit key. If the voltage drops considerably (i.e. from 12.5VDC to 11.5VDC) then you either have a wiring/connection issue or your battery is bad. BTW: Only use Tefzel wiring in aircraft: http://wingsandwheels.com/tefzel_coa...kers_louds.htm. Battery Testing - Testing your batteries each year is a good idea. Darryl mentions a very nice battery tester which does a quick job of determining good from bad. Unfortunately, it costs $150 which is a bit steep for a once a year effort. So here is my (slow) poor man battery testing method that should not cost more than $10-$15: http://aviation.derosaweb.net/#batterytest Good luck. Enjoy, John DeRosa johnatderosaweb.com |
On 7/31/2011 10:58 PM, John Derosa wrote:
Tony, I am with Darryl on this, with your seemingly modern electronics and a new 9AH battery, you "should not be having a problem". But of course you do apparently seem to be having an problem. I say apparently as you say your Dittel display disappears when you transmit but it still "... gets out OK...". This seems like a problem with your radio, not with your battery or wiring. So it appears. When it happened again today, I switched the 302 to the battery voltage screen and when I was transmitting (with the blank LCD display), the 302 was registering 11.6 volts. So, it appears that I have a radio or wiring problem. What is the gauge of your wiring from the battery to your instrument panel? If you are using small gauge wiring, and drawing considerable amps when transmitting, then the voltage can drop considerably between the battery and your radio. I use 12ga wiring. 14ga generally works just fine. Anything smaller and you are throwing away voltage, which we glider pilots cannot afford. So measure the voltage of your power system at the radio when you hit the transmit key. If the voltage drops considerably (i.e. from 12.5VDC to 11.5VDC) then you either have a wiring/connection issue or your battery is bad. BTW: Only use Tefzel wiring in aircraft: http://wingsandwheels.com/tefzel_coa...kers_louds.htm. I will be checking the wiring to the radio very closely. Battery Testing - Testing your batteries each year is a good idea. Darryl mentions a very nice battery tester which does a quick job of determining good from bad. Unfortunately, it costs $150 which is a bit steep for a once a year effort. So here is my (slow) poor man battery testing method that should not cost more than $10-$15: http://aviation.derosaweb.net/#batterytest This is nice. I typically test by putting a 1 Amp load on the battery (using a 1156 automotive light bulb). My charger is an accumate(http://www.accumate.com/612/), which IMHO is quite good. Thanks for the advice! Tony, LS6-b "6N" |
On 7/31/11 8:23 PM, Tony V wrote:
On 7/31/2011 10:58 PM, John Derosa wrote: Tony, I am with Darryl on this, with your seemingly modern electronics and a new 9AH battery, you "should not be having a problem". But of course you do apparently seem to be having an problem. I say apparently as you say your Dittel display disappears when you transmit but it still "... gets out OK...". This seems like a problem with your radio, not with your battery or wiring. So it appears. When it happened again today, I switched the 302 to the battery voltage screen and when I was transmitting (with the blank LCD display), the 302 was registering 11.6 volts. So, it appears that I have a radio or wiring problem. What is the gauge of your wiring from the battery to your instrument panel? If you are using small gauge wiring, and drawing considerable amps when transmitting, then the voltage can drop considerably between the battery and your radio. I use 12ga wiring. 14ga generally works just fine. Anything smaller and you are throwing away voltage, which we glider pilots cannot afford. So measure the voltage of your power system at the radio when you hit the transmit key. If the voltage drops considerably (i.e. from 12.5VDC to 11.5VDC) then you either have a wiring/connection issue or your battery is bad. BTW: Only use Tefzel wiring in aircraft: http://wingsandwheels.com/tefzel_coa...kers_louds.htm. I will be checking the wiring to the radio very closely. Battery Testing - Testing your batteries each year is a good idea. Darryl mentions a very nice battery tester which does a quick job of determining good from bad. Unfortunately, it costs $150 which is a bit steep for a once a year effort. So here is my (slow) poor man battery testing method that should not cost more than $10-$15: http://aviation.derosaweb.net/#batterytest This is nice. I typically test by putting a 1 Amp load on the battery (using a 1156 automotive light bulb). My charger is an accumate(http://www.accumate.com/612/), which IMHO is quite good. Thanks for the advice! Tony, LS6-b "6N" It actually has to be _really_ thin wire to drop significant voltage at transmit current draws (because that current is just not that high - with modern radios typically about a bit over 1 - 1.5 amp @ ~12VDC transmit draw, say worse case 2 A all up, you can draw that through 10 feet of 24 AWG wire (finer than you should find in a glider) and only drop around 0.25 volt. So its worth checking the wiring and using heavier wiring can be good practice, but thickness of wiring causing this problem is kinda unlikely. One thing I would look out for if the wiring seems suspect is corrosion. Especially hidden behind heat shrink tubing and inside poorly made crimp connection. So if you can't sort anything else out carefully inspect connectors. Sometimes it hides in places like inline fuse housings and their connections etc. But overall I'm also suspecting your radio. It also may be worth thinking if this effect is temperature dependent (happens after the radio bakes in the sun for a while?). I've seen LCD displays exhibit all sorts of weird problems when they get hot enough. Darryl |
On Jul 31, 9:33*pm, Darryl Ramm wrote:
On 7/31/11 8:23 PM, Tony V wrote: On 7/31/2011 10:58 PM, John Derosa wrote: Tony, I am with Darryl on this, with your seemingly modern electronics and a new 9AH battery, you "should not be having a problem". But of course you do apparently seem to be having an problem. I say apparently as you say your Dittel display disappears when you transmit but it still "... gets out OK...". This seems like a problem with your radio, not with your battery or wiring. So it appears. When it happened again today, I switched the 302 to the battery voltage screen and when I was transmitting (with the blank LCD display), the 302 was registering 11.6 volts. So, it appears that I have a radio or wiring problem. What is the gauge of your wiring from the battery to your instrument panel? If you are using small gauge wiring, and drawing considerable amps when transmitting, then the voltage can drop considerably between the battery and your radio. I use 12ga wiring. 14ga generally works just fine. Anything smaller and you are throwing away voltage, which we glider pilots cannot afford. So measure the voltage of your power system at the radio when you hit the transmit key. If the voltage drops considerably (i.e. from 12.5VDC to 11.5VDC) then you either have a wiring/connection issue or your battery is bad. BTW: Only use Tefzel wiring in aircraft: http://wingsandwheels.com/tefzel_coa...kers_louds.htm. I will be checking the wiring to the radio very closely. Battery Testing - Testing your batteries each year is a good idea. Darryl mentions a very nice battery tester which does a quick job of determining good from bad. Unfortunately, it costs $150 which is a bit steep for a once a year effort. So here is my (slow) poor man battery testing method that should not cost more than $10-$15: http://aviation.derosaweb.net/#batterytest This is nice. I typically test by putting a 1 Amp load on the battery (using a 1156 automotive light bulb). My charger is an accumate(http://www.accumate.com/612/), which IMHO is quite good. Thanks for the advice! Tony, LS6-b "6N" It actually has to be _really_ thin wire to drop significant voltage at transmit current draws (because that current is just not that high - with modern radios typically about a bit over 1 - 1.5 amp @ ~12VDC transmit draw, say worse case 2 A all up, you can draw that through 10 feet of 24 AWG wire (finer than you should find in a glider) and only drop around 0.25 volt. So its worth checking the wiring and using heavier wiring can be good practice, but thickness of wiring causing this problem is kinda unlikely. One thing I would look out for if the wiring seems suspect is corrosion. Especially hidden behind heat shrink tubing and inside poorly made crimp connection. So if you can't sort anything else out carefully inspect connectors. Sometimes it hides in places like inline fuse housings and their connections etc. But overall I'm also suspecting your radio. It also may be worth thinking if this effect is temperature dependent (happens after the radio bakes in the sun for a while?). I've seen LCD displays exhibit all sorts of weird problems when they get hot enough. Darryl- Hide quoted text - - Show quoted text - My FSG -2T did the same thing out of the box. This was with a new 14v 10ah battery, and 14 ga wire. Dittel acknowledged it was defective and repaired it free of charge. |
Oshkosh Camping - Battery Power | Tom McQuinn | Owning | 3 | June 11th 07 12:19 AM |
Power setting table and best economy/best power... | xerj | Piloting | 29 | October 20th 05 02:44 AM |
$15 Regulator for Onboard PC | Jim Vincent | Soaring | 0 | July 14th 05 06:46 PM |
battery charger to get through Piper power port? | Kyler Laird | Owning | 16 | March 20th 05 12:08 AM |
Rectifier/Regulator | Bill | Home Built | 0 | November 13th 04 04:54 PM |
