Our club's Junior has a headrest that is built into the seatpan that is
incredibly uncomfortable (at the maximum up position it hits me right about at the shoulder blades, and pushes me forward, even with a thick pillow on the seat back). Are all Juniors like this? Is there a mod to the seat that fixes this? -- Mike Schumann |
On Fri, 29 Jul 2011 21:34:43 -0500, Mike Schumann wrote:
Our club's Junior has a headrest that is built into the seatpan that is incredibly uncomfortable (at the maximum up position it hits me right about at the shoulder blades, and pushes me forward, even with a thick pillow on the seat back). Are all Juniors like this? Is there a mod to the seat that fixes this? Our club's pair have no headrest at all or any means of fitting one. The seat pans end at the lip of an open topped storage area thats behind them and intended for canopy covers, etc. though I've never used it or seen it used. This lip is at the same height as the battery shelf or slightly lower. Its well below the metal tube across the front of the battery shelf. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Sat, 30 Jul 2011 11:37:51 +0000 (UTC), Martin Gregorie
wrote: On Fri, 29 Jul 2011 21:34:43 -0500, Mike Schumann wrote: Our club's Junior has a headrest that is built into the seatpan that is incredibly uncomfortable (at the maximum up position it hits me right about at the shoulder blades, and pushes me forward, even with a thick pillow on the seat back). Are all Juniors like this? Is there a mod to the seat that fixes this? Our club's pair have no headrest at all or any means of fitting one. The seat pans end at the lip of an open topped storage area thats behind them and intended for canopy covers, etc. though I've never used it or seen it used. This lip is at the same height as the battery shelf or slightly lower. Its well below the metal tube across the front of the battery shelf. The headrest was designed for a person wearing a parachute. When I am not wearing a chute I have a two inch thick energy absorbing foam cushion, made up of three layers of different density foam, that I use behind my back when I fly the junior. Works well and is very comfortable. Cumulus Soaring has the foam. |
I seem to recall wording in the pilot's manual along the lines of "if no parachute use cushion of the 10cm thick"
Cheers, Ben |
On 8/4/2011 8:42 AM, Ben C wrote:
I seem to recall wording in the pilot's manual along the lines of "if no parachute use cushion of the 10cm thick" Cheers, Ben You would need a 12" thick cushion to overcome the headrest. -- Mike Schumann |
Speaking about foam, this place was the source of a much marked up
supply from "spruce" same stuff just a lot cheaper... http://www.sunmatecushions.com/dsi/ |
| Thread Tools | |
| Display Modes | |
| Ka-6 Headrest | vontresc | Soaring | 1 | May 15th 08 11:28 PM |
| US Team, Day 8 Junior WGC | John Seaborn | Soaring | 1 | August 8th 07 04:08 PM |
| The Junior US Team | [email protected] | Soaring | 0 | January 21st 07 09:33 PM |
| Grob headrest | nmskies | Soaring | 3 | May 18th 06 05:56 AM |
| Junior Camp | Garret | Soaring | 0 | March 2nd 04 10:18 PM |
