battery power regulator
Old August 2nd 11, 03:11 PM posted to rec.aviation.soaring
Westbender
Default battery power regulator
Are you using circuit breakers instead of fuses? That might be worth
looking into. Breakers will cause a slight drop in voltage, but maybe
you have a bad one causing a larger problem.
Old August 2nd 11, 09:33 PM posted to rec.aviation.soaring
weersch[_2_]
It is unbelievable what crappy electrical installations you can find
in gliders.
In my 1997 ship, somebody installed a 25 wire printer cable as a power
and signalling backbone under the seatpan.
Nice to be able to disconnect the panel at the DB25 connector if
needed, but...
I had continuous problems with my voltage dropping off soon after
launch to something like 11 Volts and my Dittel FSG71M starting to
blink.
I also ran a Terra250 and GPSMAP195 continuously.
After the batteries tested good on capacity, I checked the wiring in
more detail.
My ship has 3 battery positions (front, main and tail)
They were clever enough to combine 3 strands of the printer cable for
the positive terminal of each battery position.
I could not believe my eyes when I found out that they were running
ALL ground (power and signalling) through a single strand of the 25
wire printer cable.
If I were religious, I would have thanked God that the whole thing did
not go up in fire in flight.
My first project was to install a new separate power and ground
backbone with 12AWG Tefzel.
After that my power supply has been rock steady and pushing the PTT
button has hardly any effect.
Last winter I have replaced all of the remainder of the printer cable
(signalling) with Tefzel.
In the mean time also power hogs like the Terra has been replaced by a
Trig and the GPSMAP195 by a Ipaq310.
Then there is the never ending saga about batteries.
There are 2 use modes that substantially shorten the life time/
capacity of a battery (holds for most battery chemistries, but
particularly Lead Acid)
- Deep discharge
- Over charge
Most common glider batteries (like the PowerSonic 7AH) are completely
empty at 10.5 Volts at usual glider current draw (~1-2 Amps).
See the PowerSonic spec sheet.
Discharging to 9 Volts (at 1-2 Amps) is just damaging the battery.
With a reasonable AC mains charger like a Battery Tender or similar
2/3 stage charger, over-charging should never be a problem.
However, unregulated solar panel charging is a shortcut to premature
end of life for the battery.
As always on this forum, there are a hundred different opinions and a
lot of yelling about who is right or wrong.
I try to speak only about my personal approach and leave decision
making to the reader.
My approach is KISS.
I have plenty of battery capacity on board.
I have a good fat power supply (and ground) backbone in star
configuration.
I switch all 3 batteries in parallel.
I have no need for elaborate wiring schemes for switching of batteries
or separate batteries for separate equipment like transponder
I don't deep-discharge batteries (below 12 Volts) to prolong life time
of the batteries.
I have no need for voltage converters to try to maintain 12 volts from
a battery that is already empty (and damage the battery by doing so).
I charge all batteries immediately after each flight. Each battery on
a separate Battery Tender.
The FSG71M, Trig, LNAV, Ipaq310, Etrex are running happily and I am
sure the PowerFlarm will soon join without any problem.
Works well for me, but if you want to follow a different approach,
that is fine too.
Hans Van Weersch
Old August 2nd 11, 11:46 PM posted to rec.aviation.soaring
Westbender
Bad circuit breaker?
Old August 2nd 11, 11:57 PM posted to rec.aviation.soaring
Tony V
I have a 5 Amp fuse at the battery and 2 Amp fuses on the panel for the
individual components. Hans makes a very good case for checking the
wiring. :-)
Tony
Old August 3rd 11, 04:53 AM posted to rec.aviation.soaring
Morgans[_4_]
- Deep discharge
- Over charge
My experience has been that leaving one sit around in a discharged condition
will kill one permanently dead, just as quick as the other two reasons
listed above.
-- Jim in NC
Old August 3rd 11, 09:58 PM posted to rec.aviation.soaring
Tony V
Is anybody *really* buying the 7AH battery? For just a little more
money, you can get a 9AH battery with the same size and shape -
http://www.voltdepot.com/product/27042.html
Tony
http://home.comcast.net/~verhulst/SOARING
Old August 4th 11, 03:11 AM posted to rec.aviation.soaring
Morgans[_4_]
It seems to me that the 7AH used to be the most readily available and
economical, but as of late, the other sizes are easy to get and economical.
I suppose the internet market is mainly responsible for that phenomenon.
-- Jim in NC
Old August 10th 11, 05:39 AM posted to rec.aviation.soaring
Mike the Strike
money, you can get a 9AH battery with the same size and shape -http://www..voltdepot.com/product/27042.html
-- Jim in NC
I and a couple of colleagues have found the commonly-used push-on
battery connectors are often a source of high contact resistance that
can be solved by soldering them.
Mike
Oshkosh Camping - Battery Power Tom McQuinn Owning 3 June 11th 07 12:19 AM
Power setting table and best economy/best power... xerj Piloting 29 October 20th 05 02:44 AM
$15 Regulator for Onboard PC Jim Vincent Soaring 0 July 14th 05 06:46 PM
battery charger to get through Piper power port? Kyler Laird Owning 16 March 20th 05 12:08 AM
Rectifier/Regulator Bill Home Built 0 November 13th 04 04:54 PM
