F-106 Speed record questions....
Old February 21st 04, 02:03 PM
Pete
"Tarver Engineering" wrote
If your F-105 is capable of doing something inside its flight envelope, it
is normal operation. You have to remember that I have been harrassed here
for years over claiming our F-106s were capable of mach 2.3 without
damaging
the airplane.
An example of an abnormal operation is the cobra manouver, as the flight
controls are altered from normal operation.
As I said...a very 'interesting' definition of the word normal.
Pete
  #52
Old February 21st 04, 07:02 PM
John R Weiss
"Tarver Engineering" wrote...
How are the flight controls "altered from normal operation"?
What part of the cobra maneuver is outside the airplane's flight envelope?
How do you define "flight envelope" in context?
  #53
Old February 21st 04, 07:06 PM
Tarver Engineering
"John R Weiss" wrote in message
news:rXNZb.375545$na.567325@attbi_s04...
it
The operator must disable the control system augmentation in order to do a
cobra manouver.
The airplane will not do a cobra manouver with the control's augmentation
on.
I define it the same way as you would an F-18 in "cable actuated system"
mode.
  #54
Old February 21st 04, 09:20 PM
Tarver Engineering
"Moose" wrote in message
Tarver, you are brown-eyed. If you really were in the 194th you'll know
exactly what that means.
I was at the 144th FIW.
Well John, if you were at the 144th FIW then 'YOU WERE" with the 194th
FIS.
Did you go on TDY to Castle to pull alert duty in 1983 while the 318th FIS
was converting to F-15's?
Nope, I was out in '80. I was in the CAMS squadron of the 144th FIW.
We did have to drag quite a bit of Castle's F-106 duty in the 1970's,
because their CAMS squadron crumbled. We were a top burner of JP-4 in USAF.
  #55
Old February 22nd 04, 02:21 AM
John R Weiss
"Tarver Engineering" wrote in message
cobra manouver.
on.
mode.
I don't define "flight envelope" in any context with reference to any F-18
system mode...
So, what was the "normal operation" mode of the F-106 flight controls?
By your definition/description of "flight envelope," any maneuver or regime an
airplane can enter with any control input, using "normal" control authority is a
"normal operation."
Using that definition, any maneuvers prohibited by the Operator's Handbook or
other limitations would be considered "normal" if they were achievable using the
"normal" flight control mode. So, do you consider as "normal operation" any
departure from controlled flight, spin (even if entered inadvertently, in an
aircraft in which intentional spins are prohibited), or extended inverted flight
(even if it causes oil or fuel starvation to the engine)? Many airplanes can
enter these flight regimes with flight controls in "normal" configurations, but
few pilots would consider them "normal operations" in most airplanes.
  #56
Old February 22nd 04, 02:38 AM
Tarver Engineering
news:umUZb.378753$na.569282@attbi_s04...
envelope, it
flight
a
cobra manouver.
envelope?
augmentation
on.
mode.
system mode...
You should, the F-18 unaugmented is a real tail dragger and I don't mean a
wheel.
I never worked on the F-106's flight controls.
regime an
authority is a
"normal operation."
or
Nope, the operator's handbook describes the flight envelope.
Consider for a moment that you are a French pilot making a low slow pass
over a runway in an early A-320. The airplane has no such normal operation
for a low slow pass over a runway, but only to land, or go around.
  #57
Old February 22nd 04, 05:47 PM
B2431
Date: 2/21/2004 8:21 PM Central Standard Time
Message-id: umUZb.378753$na.569282@attbi_s04
it
cobra manouver.
on.
mode.
system mode...
an
is a
"normal operation."
flight
but
You were expecting an honest, straight and/or knowledgable responce from
tarver?
Dan, U.S. Air Force, retired
  #58
Old February 23rd 04, 03:05 AM
John R Weiss
"B2431" wrote...
tarver?
No...
But I'm an incurable optimist, hoping for one eventually!
  #59
Old February 23rd 04, 03:54 AM
John R Weiss
cobra manouver.
on.
mode.
an
is a
"normal operation."
But you just told us the flight envelope is described by the airplane's ability
to perform a maneuver or enter a flight regime using a "normal" control
configuration! Which is it -- defined by a control mode or defined by an
operator's handbook (I will assume that includes a "Dash-1" for USAF airplanes
and NATOPS for USN airplanes and FAA approved Flight Handbook [FHB} for
Transport category aircraft)?
If the operator's handbook, how is the "flight envelope" described? In the
General Limitations and Specifications" section or "Maximum Airspeed Limits
Chart" in the Limitations section of an FHB? Something else? Something more?
  #60
Old February 23rd 04, 04:37 AM
Tarver Engineering
news:WPe_b.42094$4o.58808@attbi_s52...
envelope, it
flight
do a
cobra manouver.
augmentation
on.
system"
mode.
regime
an
authority
is a
"normal operation."
Handbook or
ability
configuration!
Sure.
The POH is part of the Type Certificate.
Are you claiming the Dash 1 for an F-106 disagrees with a mach 2.3 F-106?
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 1st 04 02:31 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
bush rules! Be Kind Military Aviation 53 February 14th 04 04:26 PM
Edwards air show B-1 speed record attempt Paul Hirose Military Aviation 146 November 3rd 03 05:18 PM
