Tubes in tail of Jantar 41s Standard
Old August 18th 11, 03:49 PM posted to rec.aviation.soaring
David Coucke
Default Tubes in tail of Jantar 41s Standard
I have recently acquired a Jantar 41a. I was inspecting the rudder
assembly and found two 3/8 inch tygon tubes with what looked link
copper plug assemblies on the ends. I should have taken a picture.
Does anyone know what these are for. They are attached to the vertical
stab just forward of the lower rudder hinge point.
Old August 18th 11, 04:58 PM posted to rec.aviation.soaring
JC
They are water traps for the Pitot and TE lines.
Regards,
Juan Carlos
Old August 19th 11, 04:10 PM posted to rec.aviation.soaring
David Coucke
Regards,
Juan Carlos
Thanks,
I was wondering about these things. That makes perfect sense now.
Old August 20th 11, 10:08 PM posted to rec.aviation.soaring
guy
Look behind your panel. You probably have a couple of brass water
traps there too.
Guy "DDS"
Jantar Standard Canopy jmarc Soaring 9 August 22nd 17 05:13 AM
Jantar Standard 41b N41BZ dam zaw Soaring 4 May 5th 11 01:01 PM
WTB: Standard Jantar or ASW-19 Kevin Christner Soaring 2 January 9th 11 06:51 PM
Standard Jantar 48-3 & One-Man Assembly John[_27_] Soaring 6 July 20th 10 03:31 PM
Jantar Standard 3 Miguel Lavalle Soaring 9 November 19th 03 01:01 AM
