I spent a bit of time on the SSA website trying to find out if "Position Recorders" (not an IGC Approved Flight Recorder) are allowed for Silver badges. The info from 2010 seems to indicate that Position Recorders are not allowed for Silver badges, unless someone has in addition a barograph. Did I read this correctly? Is this likely to change in the future or do I need to order an IGC approved FR from Santa? Second question - Would and Out & Return of 60km qualify for a Silver badge? Can't seem to find a clarification on the SSA website (beside the definition of Silver = 50+km). Thanks, B |
On Sep 10, 10:17*pm, Bastoune wrote:
I spent a bit of time on the SSA website trying to find out if "Position Recorders" (not an IGC Approved Flight Recorder) are allowed for Silver badges. The info from 2010 seems to indicate that Position Recorders are not allowed for Silver badges, unless someone has in addition a barograph. Did I read this correctly? Is this likely to change in the future or do I need to order an IGC approved FR from Santa? Second question - Would and Out & Return of 60km qualify for a Silver badge? Can't seem to find a clarification on the SSA website (beside the definition of Silver = 50+km). Thanks, B I believe the information which you seek is on the FAI gliding website. The FlywithCE recorder is approved in the US as a position recorder. I *believe* that for the Silver you have to have one leg of at least 50 km so a 60 km out and return would not qualify. spend some time with the sporting code and the SSA badge and record guide and your OO. The paperwork is one of the biggest obstacles to the badge but is not difficult if you understand what is needed before you attempt the flight. have fun! |
Bastoune wrote:
I spent a bit of time on the SSA website trying to find out if "Position Recorders" (not an IGC Approved Flight Recorder) are allowed for Silver badges. The info from 2010 seems to indicate that Position Recorders are not allowed for Silver badges, unless someone has in addition a barograph. Did I read this correctly? Is this likely to change in the future or do I need to order an IGC approved FR from Santa? Second question - Would and Out & Return of 60km qualify for a Silver badge? Can't seem to find a clarification on the SSA website (beside the definition of Silver = 50+km). No. The silver distance flight is a 50km leg. A simple 60 km O&R had 30 km legs. But it is not just any 50km leg, and many flight claims fail because of pilots not paying attention to the 1% altitude rule or not understanding flight declaration requirements, not properly making declarations (always make a paper declaration that overrides any electronic one), or not properly entering OZs etc. on more complex silver distance flights. The silver badge also has duration and altitude achievement requirements that you can do on the same or separate flights. You are going about this the wrong way by reading the SSA website. You really have to get the FAI sporting code section 3 and the seperate annex C OO and pilots guide and read those. Start here http://www.fai.org/gliding/sc3 Notice the new October 2011 SC3 rules. You also technically are supposed to read the approval documents for the particular flight recorder (e.g. the recorder may need sealing to the aircraft etc.). The SSA website has useful information, links and forms etc. But you have to read the rules. And especially some well intentioned efforts to simplify or clarify the rules in SSA documents sometimes actually complicates this more or results in invalid flights. The FAI rules will also clarify flight recorder etc. requirements. It is usually easier to fly with an IGC recorder but it is for example it is entirely possible to do a straight out silver distance with no recorder of any type (the tow pilot attests to the release altitude and the finish altitude is the landing elevation). There is a lot of stuff to trip up a newcomer but after hitting your head against this for a while it will start to make sense, either that or it's the concussion settling in. In SC3 read the definitions section very carefully and refer to those formal definitions as you read the main text. Find a competent OO, somebody who actually understands the FAI rules in detail and go over your plans and procedures with them well before the flight. Darryl |
On Sep 10, 8:17*pm, Bastoune wrote:
I spent a bit of time on the SSA website trying to find out if "Position Recorders" (not an IGC Approved Flight Recorder) are allowed for Silver badges. The info from 2010 seems to indicate that Position Recorders are not allowed for Silver badges, unless someone has in addition a barograph. Did I read this correctly? Is this likely to change in the future or do I need to order an IGC approved FR from Santa? Second question - Would and Out & Return of 60km qualify for a Silver badge? Can't seem to find a clarification on the SSA website (beside the definition of Silver = 50+km). Thanks, B The 60km (30 out 30 back) will not qualify as others have stated. Certain position only recorders may be used for the silver badge, but you must also have a recording barograph. Find an experienced mentor in the flying group or club. Some clubs are now maintaining an approved data logger for club pilots to borrow. Some club member may have a portable logger you can use. The SSA web site has a list of approved position only loggers, they also have a Silver Badge two page guide. T |
On Sep 11, 4:48*pm, T wrote:
Certain position only recorders may be used for the silver badge, but you must also have a recording barograph. I'm not sure that's true. I suspect the tug pilot certifying that you released less than 500m above the landing point may be good enough (or even higher if your actual flight is more than 50 km?) |
Leaving aside the issue of creating a valid task: There is as of now only one GPS Position Recorder approved by the SSA for Badge attempts, and that is FlyWithCE. I know that we posted this information last year, but I too can't find it on the SSA Website, sorry. We'll get that fixed. As others have mentioned, you still need to carry a "traditional" Barograph recording pressure-based readings. As it stands, there have been no claims using this method in the US to date and very few in several other active gliding countries, largely due to the complexities introduced in having to manage two separate devices.
Please email me or reach out to Rollin Hasness, "The Badge Dude" ) for official clarifications on Badge and Record issues. Erik Mann (P3) Chair, SSA Badge and Record Committee |
Darryl Ramm wrote:
[snip] The FAI rules will also clarify flight recorder etc. requirements. It is usually easier to fly with an IGC recorder but it is for example it is entirely possible to do a straight out silver distance with no recorder of any type (the tow pilot attests to the release altitude and the finish altitude is the landing elevation). Geez which twit wrote this? What I should have said is it's possible to do the silver distance without a flight or position recorder - but that still needs a barograph for proving flight continuity. The duration flight can be done with just OO observation. Maybe to my point that trying to simplify/explain these rule scan be dangerous and you really need to study the actual rules. Darryl |
On Sep 11, 6:58*am, Papa3 wrote:
Leaving aside the issue of creating a valid task: * There is as of now only one GPS Position Recorder approved by the SSA for Badge attempts, and that is FlyWithCE. * I know that we posted this information last year, but I too can't find it on the SSA Website, sorry. * We'll get that fixed. * As others have mentioned, you still need to carry a "traditional" Barograph recording pressure-based readings. * As it stands, there have been no claims using this method in the US to date and very few in several other active gliding countries, largely due to the complexities introduced in having to manage two separate devices. * Just a minor point of clarification, IGC rules permit approval of "position recorders" which have integral pressure altitude recording capability, and therefore can be used without a separate barograph. For example, some FLARM devices are not IGC approved flight recorders, and have been approved by various countries as combined position recorders and barographs... Marc |
All, Thank you very much to all for your inputs. I got quite a few answers and additional leads to further study the subject (FAI website, SSA badge team, etc). I appreaciate the heads-up about studying the rules well ahead. It seems that half of the acheivement of the badge is understanding the rule book! Sincerely, B |
On Sep 11, 8:58*am, Papa3 wrote:
Leaving aside the issue of creating a valid task: * There is as of now only one GPS Position Recorder approved by the SSA for Badge attempts, and that is FlyWithCE. * I know that we posted this information last year, but I too can't find it on the SSA Website, sorry. * We'll get that fixed. * As others have mentioned, you still need to carry a "traditional" Barograph recording pressure-based readings. * As it stands, there have been no claims using this method in the US to date and very few in several other active gliding countries, largely due to the complexities introduced in having to manage two separate devices. * Please email me or reach out to Rollin Hasness, "The Badge Dude" ) for official clarifications on Badge and Record issues. * Erik Mann (P3) Chair, SSA Badge and Record Committee Erik, I did submit a state record claim last fall using a barograph/ FlywithCE. most of our club badge work this season has been in pursuit of gold badges and diamond goal. |
| Flight Recorder for SSA Badges | Carl6703[_2_] | Soaring | 35 | November 20th 10 09:23 PM |
| CFI-G and Badges, racing | glider[_2_] | Soaring | 14 | March 3rd 10 04:45 PM |
| IFR allowed here? | SOS[_3_] | Piloting | 3 | June 2nd 08 02:49 PM |
| Diamond Badges | Nyal Williams | Soaring | 8 | November 27th 06 07:08 AM |
| Badges ? ... We don't need no stinkin' badges | Doug Snyder | Soaring | 36 | September 21st 05 09:26 AM |
