Transponder: Mode-C or Mode-S?
Old September 12th 11, 04:54 AM posted to rec.aviation.soaring
Morteza Ansari
Default Transponder: Mode-C or Mode-S?
I recently bought a new bird and need to put a transponder in it. The
choice was obvious (until I took a closer look). Trig TT21 seems like
a great choice: small footprint, built-in encoder, 1090ES ADS-B out,
and descent price. However a bit more looking revealed more questions
than answers. It seems it requires an ISO GPS and one could not use
typical GPS sources we have in gliders, it is not clear if the ADS-B
out work with PowerFLARM (at least from what I have heard), and the
biannual testing cost 2-3x as much as mode-C.
Any thoughts/suggestions from more knowledgable folks?
Cheers,
Morteza
Old September 12th 11, 06:04 AM posted to rec.aviation.soaring
Darryl Ramm
Cheers,
Morteza
The TT-21 as a Transponder utterly blows away any other transponder
available in the USA for use in gliders. it's power consumption, split
box install options, built in encoder, etc. are totally compelling by
themselves.
You should think of this as a Mode-S transponder today. That does not
use/need any GPS source. The 1090ES data-out capability is really there
for future use. And exactly what features/compliance you are aiming for
there is a longer discussion. You should think of ADS-B as a future
thing, not something here today. Many ADS-B devices require upgrades to
meet the 2020 mandate specs, and to meet this full spec (remember
gliders are exempt) you must use aviation (not consumer) style GPS
sources.
You cannot currently install any ADS-B data-out in any certified
aircraft including certified gliders without a STC approval, and since
the FAA is unlikely to grant an STC for an install with a non
Aviation/WAAS GPS that would today mean spending several $k to include
that GPS-and finding somebody to develop the STC. Those GPS prices will
fall in future and the STC requirement will go away. But if the FCC ever
allows a field approval install for a non-aviation GPS as a data-source
on a certified glider who knows (but don't hold your breath). This while
area is a mess at the moment and just not worth most glider pilots
losing sleep over.
Technically sophisticated folks who understand this stuff and who fly
experimental gliders today have other options including using
non-certified GPS sources. Setting this up is described in the Trig
manuals. If you are having to ask questions about this my inclination is
you should just install the TT-21 as a Mode-S transponder today.
I do not understand your specific concern about compatibility with
PowerFLARM. You need to clue us in to "what you have heard" if you want
cogent comment on that. PowerFLARM today will see/display other 1090ES
data-out equipped aircraft but will not provide an alarm for any threats
with those aircraft. That is coming in a future update. None of that is
specific to using a TT-21.
There are _very_ few 1090ES data-in equipped aircraft around right now
so this is not a big issue and other PowerFLARM equipped gliders will
see you via FLARM-FLARM anyhow. The basic Mode-S (or Mode-C) transponder
by contrast is seen by ATC, by TCAS which is widely used in airliners
and private jets, military transports, many tactical military aircraft
etc. and TCAD in some GA aircraft and by PCAS systems used widely in
lower end GA aircraft.
It is the 21st century buying a Mode C transponder makes _no_ sense. You
might be able to find a different test provider - not all uplift so
much for a Mode-S. There is no valid reason for such an inflated cost.
Some will do great deals to come to the gliderport/ramp and test a whole
fleet of gliders in one day.
Darryl
Old September 12th 11, 12:55 PM posted to rec.aviation.soaring
John Smith
Just be aware that the TT21 is a class 2 tansponder, i.e. not certified
for use above 15,000 feet, and therefore not suited for gliders. Buy the
TT22 instead which is class 1.
Old September 12th 11, 01:57 PM posted to rec.aviation.soaring
jcarlyle
Using the same logic, don't buy anything other than V rated tires for
your car, as the common S rating is only good for 112 mph (180 kph).
-John
Old September 12th 11, 02:57 PM posted to rec.aviation.soaring
Darryl Ramm
certified for use above 15,000 feet, and therefore not suited for
gliders. Buy the TT22 instead which is class 1.
This has been discussed here a lot before. the power difference will
make no practical difference. By all means pay slightly more and install
the TT22 but the important thing is for folks that fly in busy airspace
near airliners etc. to have a transponder (and even an older Mode C
transponder works fine fir that). Most transponders installed in gliders
in the USA appear to be class 2.
Darryl
Old September 12th 11, 03:07 PM posted to rec.aviation.soaring
Stefan[_3_]
Am 12.09.11 14:57, schrieb jcarlyle:
If I wanted to drive with 112 mph (180 kph), then you'd be perfectly
correct. Glider pilots on the other hand tend to want to climb as high
as they can. In fact, the possibility to get a clearance to climb has
been the main reason for me to buy a transponder. So it would have been
pretty pointless to buy a class 2 transponder.
As always YMMV, but at least one should be aware of this limitation
before spending money on a class 2 transponder.
Old September 12th 11, 03:46 PM posted to rec.aviation.soaring
jim wynhoff
Except for the fact that the folks on the ground that grant the
clearance don't know or care whether you've a Class 1 or Class 2
transmitter as long as they are receiving your signal. They also
don't care about you when you are more than 40 miles out, and if 135
watts won't get you 40 miles, something's wrong with your
installation. A properly installed* Class 2 with a dipole antenna in
a fiberglass (not carbon) fuselage glider will get more radiated power
out than most GA with metal fuselages and the 1/4 wave monopole
antenna they are forced to use. If you've got a carbon fuselage,
you're stuck with the 1/4 wave.
* a major contributor to lost outpout power is the cable from the
transceiver to the antenna. Don't use RG-58. It's unsuitable for L-
band.
Old September 12th 11, 04:32 PM posted to rec.aviation.soaring
John Smith
The price of a TT22 vs TT21 is about $2500 vs $2300 (approx.). This $200
to $300 gap isn't nearly big enough for me to even start to think about
going the illegal route. As always YMMV.
Old September 12th 11, 06:28 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
What regulation makes it illegal for a glider to use the TT21 between
15,000 and 18,000'? Does it make a difference if the glider is licensed
"Experimental"?
Even if it is illegal, can we at least agree it is entirely suitable for
it's intended purpose: providing ATC and TCAS a glider's position and
altitude?
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
Old September 13th 11, 02:40 AM posted to rec.aviation.soaring
JS
Out of four different transponder and encoder combinations I've used
in gliders (Garmin/TransCal, Terra/Terra, 2x Becker/ACK, 2x Trig) the
Trig has proven to have the least power consumption.
The Trig is easy to install if you buy your own D-Sub connectors or
a crimp tool for the included ones, or have someone with a crimp tool
build the harness for you.
The small Trig control panel may fit in a corner of the panel you
thought unusable.
RG58 antenna cable worked fine for me (even with a TNC to BNC
adapter), but total cable length is less than 10' / 3m. For longer
runs you'll do better with something lower loss.
Joshua and Oakland have had no trouble getting radar contact with
the Trigs.
At the three avionics shops I called about Mode S, cost was the same
to certify Mode C or S transponders.
I believe the Trig takes less time if any adjustments are needed, but
in my experience they haven't required adjustment. The altimeter is
the most likely thing to require adjustment.
And it's Scottish, so it can't be crap!
Wanted: Mode C Transponder Robert[_6_] Soaring 3 November 30th 10 05:20 AM
Mode S transponder display to ATC? paul kgyy Instrument Flight Rules 65 September 29th 08 04:56 AM
Garrecht Mode S transponder - USA? Eric Greenwell Soaring 3 August 20th 07 09:05 PM
New transponder mode S vs. mode C Tom N. Soaring 39 November 7th 06 07:40 AM
WTB: Mode C Transponder Chris Batcheller Aviation Marketplace 0 February 21st 04 01:31 PM
