LX NAV offers new V7 Vario
Old October 26th 11, 11:26 PM posted to rec.aviation.soaring
Craig[_2_]
Default LX NAV offers new V7 Vario
On Oct 26, 3:04*pm, Morteza Ansari wrote:
Thanks for the info, looks like a pretty good option. Is there any
functionality that you would be missing if you pair it with other
loggers vs. a Nano? *For example if using it with a Colibri, can the
Oudie download flights or set the task or waypoints?
Cheers,
Morteza
If this allows use of PowerFlarm for the GPS input and interfaces with
PDAs running LK800 or XCSoar it's a very attractive option.
Looking forward to seeing the manual.
Thanks,
Craig
Old October 27th 11, 12:40 AM posted to rec.aviation.soaring
Brad[_2_]
Cheers,
Morteza
Thanks,
Craig
Just talked to Richard about the V7....................this will go in
to my panel eventually. I really like the idea of pitot/static driven
wind calculations, since like Tony, my purely driven GPS wind is not
really that accurate and not at all on final glide.
Anyone looking for a nice SB-8??
Brad
Old October 27th 11, 01:08 AM posted to rec.aviation.soaring
Richard[_9_]
Cheers,
Morteza
Thanks,
Craig
Brad- Hide quoted text -
- Show quoted text -
Craig,
I did about 15 hours of flight testing this fall with a similar
setup. PowerFlarm, LX1606 (similar to the V7), Craggy Aero
Ultimate Le, SeeYou PNA. It worked great. The software only shows
PF target at this time. Programming on the flight software will be
require to show the PCAS and ADS-B targets. LK8000 and StrePla will
also show flarm targets.
System examples see:
http://www.craggyaero.com/ultimate_systems.htm
I am sure it will work equally as well with the Oudie, PDA, or PNA
devices.
thanks,
Richard
www.craggyaero.com
Old October 27th 11, 01:54 AM posted to rec.aviation.soaring
Craig[_2_]
Cheers,
Morteza
Thanks,
Craig
Craig,
setup. * *PowerFlarm, LX1606 (similar to the V7), *Craggy Aero
Ultimate Le, *SeeYou PNA. * It worked great. * The software only shows
PF target at this time. *Programming on the flight software will be
require to show the PCAS and ADS-B targets. *LK8000 and StrePla will
I am sure it will work equally as well with the Oudie, *PDA, or PNA
devices.
thanks,
Richardwww.craggyaero.com
Thanks Richard,
That's very encouraging for those of us looking to move into more
modern gear without breaking the bank.
Cheers,
Craig
Old October 27th 11, 09:55 PM posted to rec.aviation.soaring
Paul Remde
Yes.
Paul Remde
Cumulus Soaring, Inc.
"Eurofighter" wrote in message
Can the V7 be combined with a Colibri and an Oudie?
I know that the Colibri and the Oudie communicate well and allow for
task declaration from the Oudie to the Colibri and igc download from
Colibri to the Oudie.
Will this work if I connect a V7 between them?
Thank you!
Eurofighter
Old October 29th 11, 03:25 PM
Eurofighter Eurofighter is offline
Junior Member
First recorded activity by AviationBanter: Oct 2011
SeeYou Mobile has a menu just for configuring the LX1600.
Can that menu be used also for the V7 or Naviter will have to release an update?
Old October 29th 11, 08:46 PM posted to rec.aviation.soaring
Richard[_9_]
On Oct 29, 7:25*am, Eurofighter Eurofighter.
update?
Eurofighter
EF,
I think it might require some programming. I sent an email to both
LXNAV and Naviter to find out.
Richard
www.craggyaero.com
Old October 30th 11, 01:41 AM posted to rec.aviation.soaring
Paul Remde
Hi,
If I remember correctly, the LX1600 did not have any control knobs or other
user-interface - therefore it was necessary to configure it and change the
MacCready on it with a PDA.
Since the LXNAV V7 has a knob / push button user-interface that can do all
setup and in-flight changes, there is no need for SeeYou to have a special
setup menu for it.
Paul Remde
update?
Eurofighter
Old October 30th 11, 01:28 AM posted to rec.aviation.soaring
Richard[_9_]
On Oct 29, 5:41*pm, "Paul Remde" wrote:
Hi,
setup menu for it.
Paul Remde
update?
Eurofighter- Hide quoted text -
Paul,
Many things can be change on the Old LX1600 & New LX1606 on two
pages of the SeeYou Mobile software. Pushing buttons and twirling
knobs is very tedious in comparison. The V7 also has two way
communication with the software so it would make sense that pages of
SeeYou may be developed to set up the V7. I beleive the V7 will need
to be defined as an input Device for the SeeYou software, so that will
require some programming. This is the case with other variometers
such as the CAI 302, Tasman, Borgelt, Westerboer, etc.
For those that don't use in flight navigation software it is nice that
the settings can be changed with the knob. But their are many
advantages to setup pages in the software.
Polar. MC +/- & Vol +/- is also much easier to change in the SeeYou
software by Nav Boxes. Especially when you have a large sunlight
readable screen like the Ultimate Le. No need to go two places for
changes.
Lets see what LXNAV & SeeYou say before jumping to conclusions.
Richard
www.craggyaero.com
Old October 30th 11, 11:21 AM posted to rec.aviation.soaring
johngalloway[_2_]
Does the same apply to the new little Colibri 11?
If so that would make it a much better match that the Nano as it would
be a nuisance to have to remove the Nano and hand it over to control
for scoring or to have to transfer the flight log to a card via a
PC. Much more desirable to download the log through the V7 to a card
in a PDA. It would be ironic if the LX Navigation company data
recorder were to be a better match for an LX NAV company variometer
than their own data recorder!
John Galloway
On Oct 27, 8:55*pm, "Paul Remde" wrote:
Yes.
Paul Remde
Thank you!
Eurofighter
WJRFlyboy (was: Only One Offers It) Mxsmanic Piloting 21 April 2nd 08 03:04 PM
Request for help concerning fraudulent offers to buy sailplanes Ted Wagner Soaring 0 February 16th 05 05:40 AM
New Co-Op Airline Offers Cheaper Fares if . . . Jim Fisher Piloting 1 February 12th 04 04:27 AM
New Co-Op Airline Offers Cheaper Fares Brian Burger Home Built 1 February 11th 04 06:09 PM
New Co-Op Airline Offers Cheaper Fares Brian Burger Piloting 1 February 11th 04 06:09 PM
