Fine example of Tarver Engineering release for service
Old February 26th 04, 03:31 AM
running with scissors
Default Fine example of Tarver Engineering release for service
A fine example of the quality results of Tarver Engineering work. As
singed off by John Tarver with applicable 8130.
http://www.aart-jan.net/images/aart_...egtuigwrak.jpg
photograph courtesy of Aart-Jan, (its not tarver in the pic, it's
Aart's father inspecting the fine work completed by John "the splap"
Tarver).
Old February 26th 04, 06:23 AM
Tarver Engineering
"running with losers" wrote in
message om...
"Tarver Engineering" wrote:
"Gord Beaman" wrote in message
"Jim Knoyle" wrote:
Hang on here a second now Jim, you still need two samples. As Dan
says you need 'static pressure' to read the altitude from and you
need 'pitot pressure' (ram air pressure) as well as the static
pressure to derive the airspeed reading from. Sounds like you're
saying that you can read 'both' from just the 'ram air pressure'
alone. Or did I misunderstand you?
Jim has finally figued out what a pitot tube is, but somehow he still wants
to be correct in his archive troll. It is a great paradox.
I know...ain't life a bitch John
-Gord.
Old February 26th 04, 04:39 PM
Was that before or after the first flight? ;-)
Tarver).
Old February 26th 04, 04:56 PM
fudog50
Ummm,
I performed dozens of the old FAR 91.171 (pitot/static annual
checks) and 91.172 (mode 'C' checks) in the early 90's on Pipers,
Cessna, Grumman, Lanceair, Beech, you name it. Also performed all the
calibration and repair necessary, (the lines, indicators, ports, pitot
tubes, etc.) I worked a part time job at a GA avionics shop at Palo
Alto.
IIRC, the only indicator that had both pitot and static inputs
was the VSI/Rate of climb indicator and the internal bellows in the
gauge performed the differential action. Airspeed has pitot inputs
only. Baro Alt. has static port input only. Wish I could draw you a
diagram on here, it would explain everything.
On Wed, 25 Feb 2004 22:23:23 -0800, "Tarver Engineering"
message om...
Old February 26th 04, 05:58 PM
Tarver Engineering
"fudog50" wrote in message
only.
Fascinating, tell us more.
Old February 26th 04, 06:59 PM
Jim Knoyle
message om...
wants
Ummm,
Alto.
Since posting rubbish like he posted below, no amount of diagrams
have helped. It's a case of "That's my story and I'm sticking to it!"
Revealing that in my 37 years up the road at SFO I had done easily
hundreds of low range pitot/static leak tests resulting in the replacement
of dozens of pitot tubes/probes/masts or whatever Tarver wants to
call those pointy things up front, only brought about months of fraud
claims and all of the other bits splaps is well known for.
Requoting Gord's question to me out of context is only his latest.
Pt *still* equals (altitude pressure) + (impact pressure).
JK
http://home.att.net/~j.knoyle/the_ta...hronicles.html
GREAT MOMENTS IN ADA:
"That is the case with all modern transports Gord. Pitot tubes are only
used
for flight test back up instrumentation for modern transports; pitot tubes
have a nasty habbit of atracting mud bees and are therefore not reliable
enough for revenue these past few decades."
-- John Tarver, Skylight Avionics, December 26, 2001
Old February 26th 04, 07:15 PM
"Tarver Engineering" wrote in message ...
message om...
snipping posts to claim that other people posted waht someone else
entirely posted.
pathetic, childish, immature, and the sure sign of your desparte need
to obfuscate your stupidity
Old February 26th 04, 08:20 PM
Dave Holford
Tarver).
If ever a picture cried out for a caption, this one does.
Dave
Old February 26th 04, 08:57 PM
Dan Luke
good idea for a thread...
Old February 26th 04, 09:06 PM
Robert Moore
Ummmm.....I think that you definately DO NOT recall correctly!
Static Pressure feeds Altimeter, Airspeed, and VSI.
Pitot Pressure feeds only Airspeed.
The Pitot Pressure from the Pitot Tube is a combination of Static
and RAM pressure. The bellows inside the airspeed indicator
uses the ambient static pressure from the static port to cancel
out the static component from the Pitot Tube leaving only the RAM
component to move the airspeed needle.
Bob Moore
Fine example of Tarver Engineering release for service running with scissors Instrument Flight Rules 64 March 3rd 04 05:01 AM
Fine example of Tarver Engineering release for service running with scissors Instrument Flight Rules 7 February 28th 04 05:07 PM
To Tarver Engineering fudog50 Military Aviation 2 January 9th 04 07:15 PM
About death threats and other Usenet potpourri :-) Dudley Henriques Military Aviation 4 December 23rd 03 07:16 AM
FS: Aviation History Books Neil Cournoyer Military Aviation 0 August 26th 03 08:32 PM
