refinishing Ventus 2cm- wing profile
Old October 30th 11, 10:40 PM posted to rec.aviation.soaring
Default refinishing Ventus 2cm- wing profile
Can anyone help with the wing profile data for a Ventus 2cm? I need
the numerical data and if possible someone who could make templates on
a CNC. I have contacted US dealer with no response. Ken
Old October 30th 11, 11:16 PM posted to rec.aviation.soaring
Stephen[_3_]
a CNC. I have contacted US dealer with no response. *Ken
Isn't this wing the same as V2b except for the added tips? S9
Old October 31st 11, 12:11 AM posted to rec.aviation.soaring
the Ventus c model has 2 sets of wing tips,15m and 18m. I'am not sure
if it is the same as a Ventus 2b
Old October 31st 11, 12:58 AM posted to rec.aviation.soaring
the Ventus c model has 2 sets of wing tips,15m and 18m. I'am not sure if it is the same as a Ventus 2b David Lednicer's site shows a different airfoil for a Ventus 2 and a Ventus 2b no mention of a Ventus 2c.
Old October 31st 11, 01:07 AM posted to rec.aviation.soaring
Bob Kuykendall
Round in front, pointy in back, and smooth over the top and under the
bottom. That will do what needs to be done.
Thanks, Bob K.
Old October 31st 11, 02:03 AM posted to rec.aviation.soaring
Thanks, Bob K.
I have profiled several sets of wings and what Bob says is essentially
correct. I would profile the first 6 inches and fair the rest.
Getting the existing wing to "as-designed" is probably impossible
because the factory probably did not get it to that state when it was
built. Typically, the wing is too thick and the leading edge too
blunt.
Old October 31st 11, 02:51 PM posted to rec.aviation.soaring
Rick Walters[_2_]
Ken
SH does not publish their airfoil data, or glide polars for that
matter.
The Ventus airfoil has changed in subtle ways since the 1981 a/b model
introduction.
The most notable changes have been a sharper leading edge and a
thinner profile near the wingtip,
which showed up on the V2a/b and C models. Take Bob's advice and sand,
smooth, and polish.
Rick
Old October 31st 11, 03:53 PM posted to rec.aviation.soaring
Dave Nadler
matter.
introduction.
smooth, and polish.
Rick
Note also that the airfoils (even on the original
Ventus) are tailored for the Reynolds number change
towards the tip. One well-known expert measured the
coordinates near the root and just scaled them down,
reprofiled the wing using the (incorrect) airfoils
near the tip, and reported an (incorrectly measured)
performance improvement !
If you didn't get the coordinates from SH, beware
of any profile you might obtain...
So, smooth and pray ;-)
See ya, Dave "YO electric"
Old October 31st 11, 05:16 PM posted to rec.aviation.soaring
Gary Boggs
Ah, the joys of sanding... No better way to bond with your ship.
Similar in many ways to good foreplay...
Sorry.
Boggs
Old November 1st 11, 09:25 AM posted to rec.aviation.soaring
BruceGreeff
The joys of ever advancing computer computational power.
As things have become possible to calculate so the glider wings get more
complex. The current crop of 18m ships are currently approaching thirty
profiles over the ~8.7m of wing...
They generally blend the transition from one to the next, but you
certainly can't measure a station and extrapolate further out or inboard.
Yes they are not all made in CNC machined steel female mounds like the
JS1 - and even there I am sure there is manufacturing variation, but you
would have to think carefully before re-profiling significantly. Easy to
disimprove things.
Ken
matter.
introduction.
smooth, and polish.
Rick
Bruce Greeff
T59D #1771 & Std Cirrus #57
Interesting biplane project... look at the wing profile Bob Kuykendall Home Built 15 December 5th 08 01:58 PM
Yet Another wing Refinishing question shkdriver Soaring 5 November 5th 08 11:41 PM
LS3A Wing Profile Data Robert Fidler Soaring 14 October 27th 08 09:59 PM
Wing Leading Edge Refinishing Jan Eldem[_2_] Soaring 4 June 17th 08 02:40 PM
ASW27 wing profile templates basils27 Soaring 0 June 29th 05 11:46 AM
