Why not use the F-22 to replace the F/A-18 and F-14?
Old February 26th 04, 04:36 AM
Doug \Woody\ and Erin Beal
On 2/25/04 2:21 PM, in article , "Michael
Zaharis" wrote:
Doug "Woody" and Erin Beal wrote:
I've got time in lots of jets with autothrottles, so spare me the preaching
to the choir. I bring up the autothrottle issue on the Airbus because of
their famous mishap with a jet that turned out to be the "world's most
expensive chainsaw" a few years back. That same throttle automation was
responsible for a Russian Airbus doing a wingover about 10 years ago too.
--Woody
The autothrottle was not the issue on the Airbus "tree harvesting"
accident at Mulhouse. High-bypass engines take a finite amount of time
to spool up, autothrottle or not. If you get too low, too slow, then
decide to goose the throttle too late, you won't get the thrust you need
in time, regardless of the throttle mapping.
http://aviation-safety.net/database/1988/880626-0.htm
Just read it. Sorry, folks, I was misinformed.
--Woody
  #132
Old February 26th 04, 04:51 AM
John R Weiss
"Tarver Engineering" wrote...
The days of turning off the autopilot and flying the
airplane yourself are long gone.
For the F-22, yep.
For the F/A-18, mostly.
For the F-14, nope!
For other airplanes in service, not even close!
  #133
Old February 26th 04, 04:57 AM
John R Weiss
"Michael Zaharis" wrote...
It's not only a function of high-bypass engines! The J-65 engines in the older
model A-4s had about a 13-second spool-up time, and the centrifugal-flow engines
in the old F-9s were even worse!
Some people were spoiled by the J-85, J-79 and other later-generation turbojets
that had great spool-up times. The J-52 was not as good, but a far cry better
than the J-65! The high-bypass turbofan just took ONE engine performance factor
back to the "stone age" of jet propulsion...
  #134
John R Weiss
According to the ASN Accident Description, "Go-around power was added at
14.45:35"
The pilot was past the end of the runway by then and into an unmapped part
of the A-320's flight control system.
What is "an unmapped part of the A-320's flight control system" supposed to
mean?!?
Just prior to the pilot adding go-around power, the airplane was in an
aerodynamic regime that had been encountered many times previously -- airspeed
between stall and Vref, with a slight rate of descent (approx 375 fpm, from last
datapoint), engines at idle. How could it be that the flight control system was
"unmapped" in that aerodynamic regime?!?
I am quite certain that the A-320's certification included slow flight and
approaches to stalls, and that its flight control system is well able to handle
them.
I suppose this is an addendum to your claims in another thread that
If your F-105 is capable of doing something inside its flight envelope,
it is normal operation.
and
An example of an abnormal operation is the cobra manouver, as the flight
controls are altered from normal operation.
and
Nope, the operator's handbook describes the flight envelope.
I don't think you have a clue as to what a flight envelope really is!
  #135
Old February 26th 04, 05:28 AM
Guy Alcala
snip
and
John, you're statement above implies that 'he who must not be named' has a clue
about something. Do you wish to rephrase? ;-)
Guy
  #136
Old February 26th 04, 06:00 AM
B2431
14.45:35"
mean?!?
airspeed
last
was
handle
them.
and
and
Sure he does, he thinks it's the little envelope they give you with your
boarding pass.
Dan, U. S. Air Force, retired
  #137
Old February 26th 04, 06:40 AM
Tarver Engineering
"John R Weiss" wrote in message
news:j1f%b.60182$4o.83386@attbi_s52...
at
14.45:35"
part
to
mean?!?
Airbus hadn't programmed their A-320 to do what the operator commanded.
airspeed
from last
system was
That is a good question.
handle
them.
Then you have departed from reality.
  #138
Tarver Engineering
"Guy Alcala" wrote in message
snip
flight
and
clue
That would be a fact.
  #139
Old February 26th 04, 06:42 AM
Tarver Engineering
news:aXe%b.122167$jk2.532687@attbi_s53...
For the F-22, yep.
For the F-106, yep.
This is not some new idea that snuck up on you Weiss.
"C-175 SoCal Beware" Original Poster Replies Bill Berle Aviation Marketplace 8 July 8th 04 07:01 AM
More LED's Veeduber Home Built 19 June 9th 04 10:07 PM
Replace fabric with glass Ernest Christley Home Built 38 April 17th 04 11:37 AM
RAN to get new LSD class vessel to replace 5 logistic vessels ... Aerophotos Military Aviation 10 November 3rd 03 11:49 PM
Air Force to replace enlisted historians with civilians Otis Willie Military Aviation 1 October 22nd 03 09:41 AM
