Found this PNA on the K6 website. Nice specs and price, especially
for those of us who already have a paid-for copy of SeeYouMobile on our PDAs and don't really want to pay for it again when moving up to an Oudie... Anybody have any experience with it? Seems almost identical to the Oudie, except for greater screen resolution. Curious about whether is is any better (or worse) in sunlight... Kirk 66 |
I'm using a WayteQ x950HD, running XCSoar.
Having looked at it alongside an Oudie you'd be hard pushed to tell the difference if the labels were covered. Sunlight readbility is pretty much the same. Needs 3.3v applied to pin4 of the USB mini-b connector for the USB port to work as a traditional serial port, and needs an RS232 to TTL converter to convert the levels. My biggest problem here in the UK was locating a USB lead with all 5pins conected to feed the 3.3v signal to pin 4. Software wise, if you want to run the WayteQ in "Portrait" rather than "Ladscape" mode then you'll need to update the screen driver & use a screen rotation utility. If you're happy with a soldering iron then it makes a considerable saving over an Oudie. Lots of background info can be found on the XCSoar & LK8000 forums. Regards Kevin At 17:42 27 November 2011, kirk.stant wrote: Found this PNA on the K6 website. Nice specs and price, especially for those of us who already have a paid-for copy of SeeYouMobile on our PDAs and don't really want to pay for it again when moving up to an Oudie... Anybody have any experience with it? Seems almost identical to the Oudie, except for greater screen resolution. Curious about whether is is any better (or worse) in sunlight... Kirk 66 |
Kevin Neave wrote:
Software wise, if you want to run the WayteQ in "Portrait" rather than "Ladscape" mode then you'll need to update the screen driver & use a screen rotation utility. XCSoar doesn't need the utility - this feature is built-in. You only need a display driver that allows rotating the screen (i.e. a driver update may still be needed if the stock driver can't do it). Max |
Did anybody managed to update the screen driver?
I would like to use it in portrait mode and so far I wasn't able to rotate it. thank you Quote:
I downloaded the Driver from...
http://kpr3712.npage.de/downloads_89312177.html The instructions in the "ReadMe" file say to copy the Driver to the SD card, but I copied it to \ResidentFlash\init and installed from there. I used the screen rotation utility from... http://www.jostjahn.de/pna/ScreenRotate.zip Which seemed to work on my WayteQ Hope this helps Kevin At 12:35 14 January 2012, Eurofighter wrote: Did anybody managed to update the screen driver? I would like to use it in portrait mode and so far I wasn't able to rotate it. thank you |
It worked!
Thank you! |
