#51
Hi!
"Kevin Brooks" writes: If Strix were such a great system it would have been picked up by more nations than just Sweden and Switzerland (not sure that having two of the biggest neutrals buy it is much of an endorsement!). Despite claims otherwise, it will be subject to decoying with properly set up IR emitters. And it only has a 7 klick range, which is not going to do much in the interdiction role. If you try to fire it while your forces are in the close fight, there is a significant fratricide risk. I do not know how good Strix is compared with other equivalent systems but that it has too short range for interdiction is as irrelevant that noticing that a vehicle mounted TOW has to short range for interdiction. It seems obvious that the Strix at least will fit everywhere you have mortar fire support. It enables the grunts calling for mortar fire support to call for tank kills instead of mortar rounds that merely scratches armour paint. The extra training needed ought to be trivial, no new communications systems needed and no new logistics needed. The fratricide risk ought to be of the same kind as for ordinary mortar fire, dont call down fire on your friends. It seems reasonable that it is a weapon that is good for supporting infantry defending against armour, supporting wehicles finding armour at a reasonable distance and that it is bad to call on during short range vehicle to vehicle combat. (It would of course be very nifty with a IFF system that can handle that but such a system could easily be more expensive then the weapon proper. ) The IR detector and decoy arms race has probably no true winners, a system used for decades must surely be upgraded several times? I have absolutelly no idea if strix needs such an upgrade but it ought to be easier to upgrade the detector or CPU or software of a functioning system then starting from scratch. Best regards, -- Titta gärna på http://www.lysator.liu.se/~redin och kommentera min politiska sida. Magnus Redin, Klockaregården 6, 586 44 LINKöPING, SWEDEN Phone: Sweden (0)70 5160046 |
#52
![]() "Magnus Redin" wrote in message ... Hi! "Kevin Brooks" writes: If Strix were such a great system it would have been picked up by more nations than just Sweden and Switzerland (not sure that having two of the biggest neutrals buy it is much of an endorsement!). Despite claims otherwise, it will be subject to decoying with properly set up IR emitters. And it only has a 7 klick range, which is not going to do much in the interdiction role. If you try to fire it while your forces are in the close fight, there is a significant fratricide risk. I do not know how good Strix is compared with other equivalent systems but that it has too short range for interdiction is as irrelevant that noticing that a vehicle mounted TOW has to short range for interdiction. Not in this argument it is not. The poster was claiming that we should be able to forego attack helo operations in favor of systems like Strix for the deep attack role--and Strix is NOT a deep attack asset, by any definition. Don't take this as an outright condemnation of Strix, just its inability to *replace* the attack helo. It seems obvious that the Strix at least will fit everywhere you have mortar fire support. It enables the grunts calling for mortar fire support to call for tank kills instead of mortar rounds that merely scratches armour paint. The extra training needed ought to be trivial, no new communications systems needed and no new logistics needed. OK, belay the "outright condemnation bit" for a second--if it is so good, and has been around since 1994, why have only Sweden and Switzerland ordered it? The fratricide risk ought to be of the same kind as for ordinary mortar fire, dont call down fire on your friends. It seems reasonable that it is a weapon that is good for supporting infantry defending against armour, supporting wehicles finding armour at a reasonable distance and that it is bad to call on during short range vehicle to vehicle combat. (It would of course be very nifty with a IFF system that can handle that but such a system could easily be more expensive then the weapon proper. ) True enough. But it appears the Brits cancelled their similar Merlin effort years ago, and the US has yet to actively seek a mortar fired anti-tank killer capability, having other systems that can do the job (and if it has to be done by arty, then a FIST or COLT with assigned laser designator can do the job with Copperhead). Brooks The IR detector and decoy arms race has probably no true winners, a system used for decades must surely be upgraded several times? I have absolutelly no idea if strix needs such an upgrade but it ought to be easier to upgrade the detector or CPU or software of a functioning system then starting from scratch. Best regards, -- Titta gärna på http://www.lysator.liu.se/~redin och kommentera min politiska sida. Magnus Redin, Klockaregården 6, 586 44 LINKöPING, SWEDEN Phone: Sweden (0)70 5160046 |
#53
On Fri, 27 Feb 2004 10:10:14 -0500, "Kevin Brooks"
wrote: "Thomas Schoene" wrote in message hlink.net... Kevin Brooks wrote: snip How many smart AT packages have we fielded for the arty systems? None, other than Copperhead, which has a mixed record. We have tested some, and gotten to the almost-ready-to-field stage, but not actually fielded them. Not true. The Army fielded and used the SADARM artillery-fired AT submunitions in Iraq last year. The 3ID(M) After Action report says they fired over 120 rounds with 48 targets killed. Thanks; I had thought that program was axed a couple of years back. It was, but there was still a quantity of LRIP rounds in stock, so they were sent out to see how they fared. --- Peter Kemp Life is short - drink faster |
#54
Hi!
"Kevin Brooks" writes: Not in this argument it is not. The poster was claiming that we should be able to forego attack helo operations in favor of systems like Strix for the deep attack role--and Strix is NOT a deep attack asset, by any definition. Don't take this as an outright condemnation of Strix, just its inability to *replace* the attack helo. Oh, I obviously dident read enough of the thread. Replacing attack helicopters with mortar rounds is of course an impossible idea even if they are 100% accurate. OK, belay the "outright condemnation bit" for a second--if it is so good, and has been around since 1994, why have only Sweden and Switzerland ordered it? The cold war ended and everybody but USA has lowered their military spending significantly? And the USA dont like to buy foreign high-tech weapons if it can be avoided. Nobody bought our exelent self propelled "Bandkanon" howitzer either and it could fire 14 155mm rounds in 45 seconds in 1966. Perhaps its like that howitzer, too expensive and somewhat before its time? But I do not know what the strix rounds cost. True enough. But it appears the Brits cancelled their similar Merlin effort years ago, and the US has yet to actively seek a mortar fired anti-tank killer capability, having other systems that can do the job (and if it has to be done by arty, then a FIST or COLT with assigned laser designator can do the job with Copperhead). I do not know why the Merlin project was cancelled, it was a significantly smaller round, perhaps it was not possible to get it all to fit in such a small package? Good for you that you have plenty of other systems for killing armour. Best regards, -- Titta gärna på http://www.lysator.liu.se/~redin och kommentera min politiska sida. Magnus Redin, Klockaregården 6, 586 44 LINKöPING, SWEDEN Phone: Sweden (0)70 5160046 |
#55
![]() "M" *@*.* wrote in message ... Kevin Brooks How many smart AT packages have we fielded for the arty systems? None, other than Copperhead, which has a mixed record. We have tested some, and gotten to the almost-ready-to-field stage, but not actually fielded them. That *may* change with the new GMLRS (guided MLRS)...there was some talk about fielding a smart submunition package for it and for ATACMS. But there are non-US systems, like the Swedish Strix, which is a 120mm mortar fired guided AT round. At least on paper, it seems very formidable with autonomous guidance, target search and prioritization, and a decent-sized top-attack warhead. The Brittish 80mm Merlin was rather similar, although mm-wave radar rather than IR, but I recall that it was cancelled. I find it surprizing that the US hasn't adopted any smart artillery rounds, except the Copperhead, which really isn't all that smart (non-autonomous). Especially considering the hype that was there already in the 80's about cargo rockets with autonomous AT-munitions that would render massed MBT usage obsolete (again ![]() such munitions. Perhaps the fact that none was fielded has something to do with the end of the cold war. Speculatively, if it was seen that the AH's (etc) that they already had were sufficient to deal with any armour threat out there? Otoh, it's interesting that Sweden would come up with such a round. Do they perhaps see it the other way around, as a substitute for the attack helos they don't have? From all reports the SADARM rounds performed_very_well in the Iraq-2 war. Unfortunately, almost all of them have been expended and evidently there are no plans to reopen production. The Army is soliciting non-development proposals for rounds to restock. There's a fair amount of activity in course-correcting artillery rounds. The cheapest is so-called "1D", range-only correction. A smart fuze deploys an airbrake after so many revolutions of the round. For some of them, the number of revolutions is uplinked to the round after it leaves the muzzle, based on muzzle velocity measurements. The 1-D fuzes reduce the range part of the error ellipse which is the largest part of total error. There are also "1.5D" and "2D" correcting shells in development that can correct cross-range errors as well. All of these are "non-smart" in that there is no terminal target sensing but like GMLRS, the decrease in CEP will increase lethality against hard targets. Based on the standard equations for SSKP against hard targets using blast overpressure as the kill mechanism, lethality goes up as CEP^2. I'm not sure how applicable that model is since blast normally won't kill armor but it's an indicator. |
#56
![]() "Kevin Brooks" wrote True enough. But it appears the Brits cancelled their similar Merlin effort years ago, and the US has yet to actively seek a mortar fired anti-tank killer capability, having other systems that can do the job (and if it has to be done by arty, then a FIST or COLT with assigned laser designator can do the job with Copperhead). Do you have any idea how many Copperheads are still in inventory? Martin built about 4-5000 rounds before production was cancelled and I understood that substantial numbers were expended in Iraq-1. |
#57
![]() "Magnus Redin" wrote in message ... Hi! "Kevin Brooks" writes: Not in this argument it is not. The poster was claiming that we should be able to forego attack helo operations in favor of systems like Strix for the deep attack role--and Strix is NOT a deep attack asset, by any definition. Don't take this as an outright condemnation of Strix, just its inability to *replace* the attack helo. Oh, I obviously dident read enough of the thread. Replacing attack helicopters with mortar rounds is of course an impossible idea even if they are 100% accurate. OK, belay the "outright condemnation bit" for a second--if it is so good, and has been around since 1994, why have only Sweden and Switzerland ordered it? The cold war ended and everybody but USA has lowered their military spending significantly? And the USA dont like to buy foreign high-tech weapons if it can be avoided. Nobody bought our exelent self propelled "Bandkanon" howitzer either and it could fire 14 155mm rounds in 45 seconds in 1966. Perhaps its like that howitzer, too expensive and somewhat before its time? But I do not know what the strix rounds cost. I'd say it was because in this case Sweden exhibited that trait that we ourselves have had to avoid (sometimes not so successfully ourselves, I'd admit) and bought a nifty weapon designed to help counter the anticipated hordes of Soviet armored vehicles you might have faced if the balloon had ever actually gone up--but they did it after the threat was largely dissipated. Apparently the old "Cold War Mindset" when it came to weapons procurement after the demise of the Warsaw Pact threat is not a purely American disease... :-) The US had a number of deep strike artillery anti-armor weapons in the development pipeline--most were subsequently cancelled. Brooks True enough. But it appears the Brits cancelled their similar Merlin effort years ago, and the US has yet to actively seek a mortar fired anti-tank killer capability, having other systems that can do the job (and if it has to be done by arty, then a FIST or COLT with assigned laser designator can do the job with Copperhead). I do not know why the Merlin project was cancelled, it was a significantly smaller round, perhaps it was not possible to get it all to fit in such a small package? Good for you that you have plenty of other systems for killing armour. Best regards, -- Titta gärna på http://www.lysator.liu.se/~redin och kommentera min politiska sida. Magnus Redin, Klockaregården 6, 586 44 LINKöPING, SWEDEN Phone: Sweden (0)70 5160046 |
#58
![]() "Paul F Austin" wrote in message ... "Kevin Brooks" wrote True enough. But it appears the Brits cancelled their similar Merlin effort years ago, and the US has yet to actively seek a mortar fired anti-tank killer capability, having other systems that can do the job (and if it has to be done by arty, then a FIST or COLT with assigned laser designator can do the job with Copperhead). Do you have any idea how many Copperheads are still in inventory? Plenty. How many 1000 to 2000 tank armies are you planning on fighting? And as Tom has pointed out, we apparently have at least some SADARM rounds as well. Martin built about 4-5000 rounds before production was cancelled and I understood that substantial numbers were expended in Iraq-1. As I recall it, the number used during ODS was less than 400. Please correct me if I am wrong--I read the actual number a year or so ago but can't recall where. I did see where the 1st CAV fired a grand total of 30. Brooks |
#59
![]() "Paul F Austin" wrote in message ... snip There's a fair amount of activity in course-correcting artillery rounds. The cheapest is so-called "1D", range-only correction. A smart fuze deploys an airbrake after so many revolutions of the round. For some of them, the number of revolutions is uplinked to the round after it leaves the muzzle, based on muzzle velocity measurements. The 1-D fuzes reduce the range part of the error ellipse which is the largest part of total error. There are also "1.5D" and "2D" correcting shells in development that can correct cross-range errors as well. All of these are "non-smart" in that there is no terminal target sensing but like GMLRS, the decrease in CEP will increase lethality against hard targets. Based on the standard equations for SSKP against hard targets using blast overpressure as the kill mechanism, lethality goes up as CEP^2. I'm not sure how applicable that model is since blast normally won't kill armor but it's an indicator. They are worthless against armor unless you acheive a direct hit; even a direct strike by a DPICM round against a MBT is unlikely to give you a kill. You have to have either a terminally guided round such as Copperhead or a terminally guided submunition like SADARM to kill tanks. Even Excalibur, except in its SADARM version, which is now moot, is not a tank killer with its reported 10 meter CEP (against a stationary MBT, that would require what, a minimum of maybe eight to twelve rounds to give you a reasonable assurance of hitting it?). Then there is the sensor-to-shooter time lag to overcome against a moving target, which necessitates the use of a terminally guided munition. Brooks |
#60
![]() "Peter Kemp" wrote in message ... On Fri, 27 Feb 2004 10:10:14 -0500, "Kevin Brooks" wrote: "Thomas Schoene" wrote in message hlink.net... Kevin Brooks wrote: snip How many smart AT packages have we fielded for the arty systems? None, other than Copperhead, which has a mixed record. We have tested some, and gotten to the almost-ready-to-field stage, but not actually fielded them. Not true. The Army fielded and used the SADARM artillery-fired AT submunitions in Iraq last year. The 3ID(M) After Action report says they fired over 120 rounds with 48 targets killed. Thanks; I had thought that program was axed a couple of years back. It was, but there was still a quantity of LRIP rounds in stock, so they were sent out to see how they fared. Yeah, that agrees with what I have found on the web thus far. Thanks for the update. Brooks --- Peter Kemp Life is short - drink faster |
Army ends 20-year helicopter program | Garrison Hilliard | Military Aviation | 12 | February 27th 04 07:48 PM |
Warszaw Pact War Plans ( The Effects of a Global Thermonuclear War ...) | Matt Wiser | Military Aviation | 0 | December 7th 03 08:20 PM |
French block airlift of British troops to Basra | Michael Petukhov | Military Aviation | 202 | October 24th 03 06:48 PM |
About French cowards. | Michael Smith | Military Aviation | 45 | October 22nd 03 03:15 PM |
Ungrateful Americans Unworthy of the French | The Black Monk | Military Aviation | 62 | October 16th 03 08:05 AM |
