Jantar Std 3 parts wanted
Old December 16th 11, 08:12 PM posted to rec.aviation.soaring
BillT
Default Jantar Std 3 parts wanted
Need a canopy & undercarriage assembly. New or used ok. Having
difficulty contacting the manufacturer. Any help / suggestions greatly
appreciated. Thanks, Bill
Old December 16th 11, 08:23 PM posted to rec.aviation.soaring
Mike the Strike
appreciated. Thanks, *Bill
Having once owned a Jantar-1, which I believe has the same
undercarriage as the Standard, I wonder how you could have broken it?
It is hardly under-engineered!
However, I don't think the design ever changed, so it should be common
to a lot of models.
There was also a European outfit (Polish?) refurbing Jantars not too
long ago, including retrofitting a one-piece canopy.
Mike
Old December 16th 11, 08:55 PM posted to rec.aviation.soaring
Andrzej Kobus
Why don't you just call the dealer?
www.windpath.ca
Old December 16th 11, 09:03 PM posted to rec.aviation.soaring
RL
Try Windpath in Canada, the North American SZD - www.windpath.ca
The SZD-59 is still in production and is the Jantar Std 3 fuselage.
Bob
Old December 17th 11, 12:42 AM posted to rec.aviation.soaring
sisu1a
I've got a wheel/bearing/brake/tire assy, but not an extra fork/
spindle, although I have the factory drawings for the fork if you
need. If I remember right, it was a $2-$3k part new, being made out of
some 20 jigged & TIG'd pieces of chromoly. A 6 month wait as well...
-paul
Old December 18th 11, 08:48 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
You might be able to get some gear parts from this person. Has an ad
on segelflug.de. Look for "Damaged SZD-48-1 Parts" mid way down the
second page under the "clubclass" heading. Link to pictures of what
is for sale.
https://picasaweb.google.com/1088759424922
15005935/D7378
Don't think he can help you with the canopy, though.
JANTAR STD wanted [email protected] Soaring 3 November 17th 08 07:57 PM
Wanted SZD Jantar STD 2 wing tip [email protected] Soaring 1 May 27th 06 10:48 PM
Jantar STD 41-A parts szd41a Soaring 4 January 16th 06 11:57 PM
KLX-100 parts wanted mah Aviation Marketplace 1 December 30th 05 03:57 PM
Jantar Std 3 wanted eR Soaring 1 May 18th 04 05:32 PM
