#21
On Dec 19, 6:51*am, Dave Nadler wrote:
On Saturday, December 17, 2011 12:51:02 PM UTC-5, Dave Nadler wrote: Hi Folks - Anybody else had this problem ? http://www.nadler.com/Antares/Cobra_...orn_hinge_clos... I've got replacement pins from Spindelberger and replacement rear corner channels, but I'm thinking about an insert so all the loads aren't taken in a thin bit of channel... Thanks, Best Regards, Dave "YO electric" PS: ~55k miles on the trailer. OK, lets recap, from thread here and private emails. As it says above: I have NEW REPLACEMENT aluminum pins and NEW REPLACEMENT (undrilled) corner channels from Spindelberger. I do not want to repeat the problem by using these as used originally. The structure (pins/channel) is STRONG enough, but the aluminum pin on the thin aluminum corner channel wears excessively. Aluminum-on-aluminum is NOT GOOD. Suggestions so far via email and in this thread: A bushing (as suggested by T8 and others) reduces wear with a better fit and materials that wear less; anything is better than aluminum-on-aluminum. A replacement pin of steel (drill stock or cut bolt with a couple holes through it for mounting; no complicated machining required) will not wear out so easily. A steel insert, block or 1/4" plate bolted to inside of channel, will give better wear and more surface. A tube insert (all the way through the corner channel) can do likewise. Add a plastic cap on the outside to keep the dirt out. Easy to make and install (before riveting in replacement corner channel); no complicated machining required. Notes on more modern Cobra trailers: The bottom of the existing corner channel is not open; the sidewall extrusion is cut leaving this area blocked. You cannot just slide a reinforcement part in from the bottom; you have to remove the corner channel (bunch of rivets). The skids are mounted forward of the rear corner channel. Further thoughts ? Thanks in advance, Best Regards, Dave "YO electric" http://www.onlinecontest.org/olc-2.0....html?dsId=217.... Dave, you already have lots of good advice but here's another idea. http://www.popsci.com/diy/gallery/20...-plans?image=4 Metal filled epoxy like this is just as strong as aluminum. It could be used inside the frame tubes to re-size the holes. If you coated the new pins with mold release compound and clamped the door in perfect alignment while the epoxy set up, you'd have a tight, rattle free fit. The fix would probably last as long as the rest of the trailer. If it didn't, it's easy to repeat the repair. |
Can't use that, product doesn't even have
the word "Miracle" in the name. Might work for winch bearings though. |
On Dec 19, 7:38*am, Steve Koerner wrote:
Dave- Removing the rivets on the corner channel and reinstalling it with new rivets is not a big deal. *That only took a few minutes to accomplish. Keep in mind that aluminum and bronze aren't very compatible from a corrosion standpoint. The aluminum is going to be sacrificial to the bronze. Since you've got lots of aluminum and only a little bronze it isn't horrible, but a stainless bushing is a better choice if you're going to stay with the aluminum pins. Cheers, Craig |
"JJ Sinclair" wrote in message : On Dec 18, 8:07*pm, Steve Koerner wrote: Joe -- making some kits sounds like a great idea. *Please make one for YO so he doesn't try to stick a bushing in that aluminum channel. For a long time I had intended to do a write-up on this mod but I never got to it. *I wish I had. *I didn't locate any pictures but I did locate my dimensioned sketch that I made at the time of fabrication. *From the date on the page,I did this in '06. *Th sketch is crude but it should be all you need to make the block that goes into the channel. * The block is 1.00" X .74" X 4.00". *It has 3 M8 tapped holes in the bottom and the reamed .501" hole in the side. *I suppose there is the possibility that the skids are located at different longitudinal locations on various trailers -- so that would need to be checked first. *It looks like I didn't make any sketch of the part that goes on the door -- I'm thinking it was just an obvious duplication of the existing part there but with the .500" steel pin in place of the aluminum metric size pin. If anyone makes one of these, you should put some grease on the pin or in the hole when you put it together. I have posted the sketch hehttp://www.box.com/shared/3ul281v6y0aek31gmva5 Steve Koernerwww.wingrigger.com Back to the 'why' is the rear door hinge getting all chewed up? I'm thinking the culprit is the heavy ramp (with jack ('s). The rear door locks the ramp in place with a bolt that extends into the door when it is closed. I have found (and fixed) the hole in the door that holds the ramp, to be severely elongated, why? The ramp & jack are bumping up and down causing the elongation. This becomes a jack-hammer and the destructive action doesn't stop with elongating the ramp to door lock. I believe it is undoubtedly causing the door hinge galling. Recommend a 1/16 wall, steel plate with bolt hole drilled in center, be pop- riveted over the elongated hole. Set the new plate so it holds the ramp & jack firmly against the floor. Then fix the hinge pins ala Steve & Joe's recommendation. A good winter project, JJ Hmmm? What about out-of-round or out-of-balance tires? Maybe a lot of vibration going on back there... Just a thought.... Zero One |
Tires balanced, no visible motion in rear view mirrors...
I don't think so... Best Regards, Dave |
I'm going to use bushings in the corner channels and
a steel (ideally stainless) hinge pin. The pin won't wear out, and if the bushings wear they're just a few minutes to replace. Anybody up for making replacement pin kits ? Here's a rough (I know, very rough) sketch: http://www.nadler.com/Antares/CobraRearDoorHinge_4.pdf Joe ? Steve ? Alternatively, can anyone recommend a favorite internet machine shop ? Happy Holidays, Best Regards, Dave "YO electric" PS: Wear on pins is only on one side: door moving downwards when closed, or upwards when open. I think most likely I've caused this by cranking trailer nose up against door opened on ground to steady rear of trailer(instead of using the cranky rear jack stands)... |
| Thread Tools | |
| Display Modes | |
| Worm Hole no Need for Black Hole | Michael Baldwin, Bruce | Products | 2 | May 8th 07 12:04 PM |
| Beat up / worn out Arrow valuation | Chuck | Owning | 20 | May 12th 05 12:01 AM |
| worn injector? | [email protected] | Owning | 4 | February 17th 05 07:16 AM |
| T-hangar's bi-fold door: Convert to a motorized opening door? | Peter R. | Piloting | 16 | August 21st 04 02:06 AM |
| 172 door hinges: right way, wrong way, my way??? | Mike Z. | Owning | 4 | April 6th 04 09:07 PM |
