How wings work video
Old January 25th 12, 04:51 PM posted to rec.aviation.soaring
Frank Whiteley
Default How wings work video
http://www.physorg.com/news/2012-01-wings.html
Old January 25th 12, 04:56 PM posted to rec.aviation.soaring
Frank Whiteley
Default How wings REALLY work video
The real topic;^)
Old January 26th 12, 02:01 AM posted to rec.aviation.soaring
jim wynhoff
I've tried to open it a couple times now, and it hangs my PC.
Old January 26th 12, 04:17 AM posted to rec.aviation.soaring
Mark628CA
My computer hangs up also. "Thanks" for this.
MM
Old January 26th 12, 04:20 AM posted to rec.aviation.soaring
Frank Whiteley
MM
Hmm, absolutely no issues following the link. Did you copy and paste
the URL? It's just an embedded flash video in a web site.
Frank
Old January 26th 12, 04:28 AM posted to rec.aviation.soaring
Tony V
Actually, it's a video about how wings don't work. :-)
Tony
Old January 26th 12, 05:26 PM posted to rec.aviation.soaring
Bill D
The video appears to be made with a desktop 2D smoke tunnel commonly
used in WW2 pilot training. After the war these devices found their
way into high school science labs. They were never intended to be
anything more than a qualitative visualization tool since they
operated at a Reynolds number far too low to be meaningful for full-
size aircraft. However, they did produce a convincing illustration of
flow separation at stall as the little airfoil shape was rotated to
increase the angle of attack.
The little smoke tunnel was composed of two glass plates about half an
inch apart and about 10" square sealed top and bottom. An electric
fan pulled air horizontally through the space between them at a couple
of feet per second. At the intake side, a kerosene smoke generator
comprised of an electrically heated pot of kerosene fed smoke into a
"rake" made of thin brass tubes which produced the neat parallel
streams of smoke. There was a finger operated valve to "pulse" the
streams of smoke. Various shapes could be placed in the "test
section" and rotated to any angle to help students visualize the
airflow around them. There was also a lamp house and lens which
converted the "wind tunnel" into a projection system so a classroom
full of seated students could watch the demonstration.
They were huge fun to play with but the EPA would never approve the
air pollution they produced in a classroom.
Old January 26th 12, 06:35 PM posted to rec.aviation.soaring
Brad[_2_]
But, if it's for the children it should be okay!
Brad
Old January 26th 12, 07:42 PM posted to rec.aviation.soaring
jim wynhoff
MM
Hmm, absolutely no issues following the link. *Did you copy and paste
the URL? *It's just an embedded flash video in a web site.
Frank
Yes, on two different computers, one running XP, and one running 7,
with the same result. The webpage displays, then after a short time,
fades to the 'not responding' pallette.
Old January 27th 12, 12:13 AM posted to rec.aviation.soaring
Frank Whiteley
MM
Frank
http://www.youtube.com/watch?v=UqBmdZ-BNig without the Physorg article.
Light gun work with ATC COMS - Video [email protected] Piloting 5 July 15th 09 03:20 AM
Pattern work - Video [email protected] Piloting 9 March 21st 09 04:00 AM
Pattern work - Video A Lieberma[_2_] Owning 0 March 19th 09 11:00 PM
Pattern work - Video [email protected] Instrument Flight Rules 0 March 19th 09 11:00 PM
Wings - how does it work? Guy Elden Jr. Piloting 6 August 18th 04 09:20 PM
