Flarm with Firmware 1.20 update
Old January 27th 12, 06:44 AM posted to rec.aviation.soaring
Ramy
Default Flarm with Firmware 1.20 update
On Jan 26, 5:06*pm, T8 wrote:
On Jan 26, 5:39*pm, Sean Fidler wrote:
Evan,
That is all you can do. *Your unit will be here in the spring. *That is intelligent.
FLARM is proven in Europe. *There is no question that it fundamentally improves safety in very much the same way that GPS improved navigation and radio's improved communication. *No need to wait until 2013 for measurement.
I completely disagree with you that US operations have no earthly reason to use FLARM. *I find that statement embarrassing for soaring. *All it takes is once. *All it takes is one glider and one tow plane. *All it takes is one glider and one airplane flying by the airport. *Should they not have radio's? *Should the not have parachutes? *Safety paint?
Maybe I wasn't clear -- what I took exception to was the idea of
mandating Flarm in a sparse, relatively isolated club environment,
giving the example of a club with 20 ops/day. *Indeed, there are nordo
gliders, and still a fair amount of nordo power traffic (antiques) in
such places. *I'm not defending this, merely pointing out that some
folks choose to do it this way still.
In areas of high traffic -- contests especially -- I am enthusiastic
about Flarm and hope to see it widely if not universally adopted.
-Evan Ludeman / T8
Evan, we lost a glider pilot and tow pilot just couple of years ago
in a pattern over a private strip belonging to a club with less than
20 ops per day. IIRC, this was the only op that day. To those who
insist they don't need powerflarm where they fly, I can only ask one
thing, please stay away from where I fly...
Ramy
Old January 27th 12, 08:18 AM posted to rec.aviation.soaring
Three Uniform
Folks,
I think quite some energy is wasted here on negative thinking. Like
bitching about the government (you get the government you deserve,
i.e. voted for) or the mandating discussions ("you stay out of my
cockpit", "No, you stay out of my airspace").
PowerFlarm will proliferate. I think it is key to facilitate that
proliferation as quickly as possible.
As others said, in our Region 11 we have experienced in our close
circles the Hawker-ASG29 mid-air and the Pawnee-ASW27 midair in the
landing pattern.
Fortunately the current experiences with the portable are very
encouraging. I would like to congratulate and thank the PowerFlarm
team for the progress booked up till now.
However, working in the High Tech electronics industry myself, I am
very concerned about the schedule for the brick, taking into account
that many people are waiting for the brick. By lack of any status info
from the PowerFlarm team and knowing schedule slips (as we have also
seen with the portable), I concur with an earlier observation that the
brick could easily slip into 2013 season. Leaving many of us exposed
to the higher risk for another season.
I think it would be good if we could focus our energy on how we could
help/stimulate the PowerFlarm team to
- keep us updated on the status and schedule of the brick
- publish the specification of the brick and display such
that we can prepare wiring during the winter for easy mid-season drop-
in.
- complete development of the brick as soon as possible.
3U
Old January 27th 12, 02:36 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Evan, we lost a glider pilot and tow pilot *just couple of *years ago
20 ops per day. *IIRC, this was the only op that day. To those who
Ramy- Hide quoted text -
- Show quoted text -
Well said, Ramy. Let me add that the glider had (and used) his
aircraft radio to make a "entering the pattern" call. He also had a
transponder and a PCAS....................the tow plane wasn't alerted
to the gliders presence because he nothing, no radio, no transponder,
no PCAS! Time to stop this needless carnage!
Williams Soaring has just equipped its entire fleet, including tow
planes, with Power Flarm. Most private pilots flying out of Williams
have purchased Power Flarm also.
JJ
Old January 27th 12, 02:59 PM posted to rec.aviation.soaring
Derek Mackie
3U: Bravo! Well said.
Derek
Old January 27th 12, 03:30 PM posted to rec.aviation.soaring
Sean Fidler
+2
Old January 27th 12, 03:45 PM posted to rec.aviation.soaring
Paul Remde
Hi,
Many good points below.
I'm sure we will all learn much more about the status of the PowerFLARM
Brick at the SSA Convention in a few days. I will update my FLARM web page
as soon as possible. I agree that we need them to be delivered ASAP. FLARM
knows that too. They have put delivery of the Brick units ahead of work on
the IGC flight recorder in the Portable unit. The good news is that the
PowerFLARM Portable units are working very nicely and I'm pretty sure that
90% of the software and hardware is the same in the Brick.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"Three Uniform" wrote in message
Folks,
landing pattern.
in.
3U
Old January 28th 12, 12:05 AM posted to rec.aviation.soaring
Chris
Evan Ludeman wrote:
To Chris over in Europe... the US situation is rather different in
that a) the US is geographically huge and b) the US glider population
is very small. Glider clubs that launch eight gliders for a total of
perhaps 20 flights on a "busy" day account for a lot of US soaring.
While this is correct, think about what all glider pilots are searching all
the time: lift. As soon as you find a good thermal, the chance is that
another joins you very soon. Circling in thermals can get you very close to
other gliders, even if the airspace around you is empty. My near miss
happened at a small competition, we had a 250 km triangle. Even when we
crossed the starting line at different times we met each other again and
again, sometimes 5 or more gliders circling together at the same altitude.
When then the Flarm shriekes and flashes at another glider coming from
behind you can make a sharp turn out of the circle. Better loose some 20m
than your wing.
Another near miss happened at our airfield in the landing pattern, when an
inexperienced pilot came heading straight against another one who was on
correct course. They did not have Flarm and could avoid a crash in the last
second.
What does it help when there are only 10 gliders in a 1000km radius, but one
that flies directly into your cockpit? Collisions happen where there are
reasons to be at the same place, like traffic patterns and thermals.
Happy landings
  #28
Old January 28th 12, 01:26 AM posted to rec.aviation.soaring
Andy[_10_]
JJ
And some of us have donated portable PowerFlarm units for use by those
of you who don't see $1500 as worth the reduction in collision risk.
At least then you can stop being a hazard to the rest of us who do see
the value. You don't even have to look at it or learn how to use it.
Simply turn it on and forget it. Just please don't give the finger to
the person who offers you one at a contest.
9B
  #29
Old January 28th 12, 01:49 AM posted to rec.aviation.soaring
Chris Nicholas[_2_]
In the UK, most glider collisions take place in or close to the
pattern/circuit at gliding sites. Most are with other gliders or tugs
from the same site. A few are with unrelated powered aircraft. (Little
sky, lot of bullets.)
Hardly any are while on cross country flights away from the home site.
(Big sky, few bullets.)
Before we had Flarm, we had 20 fatalities in 23 years, mostly of
glider pilots. We now have over 25 percent of UK glider with Flarm,
and most of those are in the quarter of the England (southern eastern
sector) where most gliding is done.
Is it a coincidence that fatal collisions have not featured as
prominently in the UK accident figures (none since 2009, and that was
a non-Flarm glider colliding with a non-Flarm powered aircraft – both
pilots in the latter were killed) since Flarm grew from a few to over
25 percent uptake? And the most recent (non-fatal) collision of which
I know, in 2011, had no Flarm help in avoiding it? I think it is too
soon for it to be statistically significant, but to me it looks
hopeful.
As for those who say another instrument in the cockpit is too much and
keeps your head down even more, sorry but that is rubbish. Virtually
everyone who flies with it has realized we were not looking out well
enough before, and the bleeps make you look harder. If it goes into
alarm mode – collision imminent if you don’t do something – you are
very glad indeed to have the warning. Been there, done it,
Ditto PCAS.
But, sadly, the unbelievers will remain unconvinced. Those of us old
enough to remember the car seat belt saga will recall those who
opposed them saying they would rather have the chance of being thrown
clear than be strapped in. (Ever hear of many people being so thrown
clear of an otherwise fatal car crash?)
As for those who have no room, yes that can happen. A pity. But the
small Swiss Flarm can go elsewhere in the cockpit than on the panel.
Transponders? For Minden etc., great. But transponders do not detect
each other. Two air cadet aircraft collided in the UK in 2009, killing
both instructors and both cadets - 4 dead. Both aircraft had
transponders. Unless you also have PCAS or better, or have radar
service, they are useless at glider/glider, glider/power, or even
power/power collision avoidance. (Very few UK gliders have
transponders, and most including mine are inhibited by regulations
requiring expensive and/or impractical official modifications and
certification issues, as well as cost etc.. I can’t have one in my
glider, and I had a hole in the instrument panel ready for it.)
My advice to people in thr UK is to get Flarm, and when you do so, get
as many of your buddies at the same gliding site to get them too. You
are all each other’s greatest collision risk, near your own base. In
the USA? Well, where have your glider/glider collisions mostly been?
Chris N.
  #30
Old January 28th 12, 01:55 AM posted to rec.aviation.soaring
Chris Nicholas[_2_]
By the way, if anyone wants a copy of a paper I did on Lookout, Flarm,
PCAS etc., send me an email to which I can reply with an attachment. I
am not an expert, but it was the best I could pull together, with some
help from others including data from people on r.a.s.
Chris N
PowerFLARM Portable - Firmware Update Available - Mode C Traffic Now Supported Paul Remde Soaring 24 January 22nd 12 01:50 AM
FLARM UPDATE? Stephen Michalik Soaring 6 March 20th 11 04:24 PM
FLARM firmware release schedule Andy[_1_] Soaring 11 January 5th 11 06:09 PM
Garmin GPS496 Firmware Update John Smith Piloting 0 July 23rd 08 02:38 AM
Garmin 196 firmware update v3.1 released Aloft Piloting 0 August 13th 03 12:50 AM
